OpenFOAM如何输出场的最小值这个文件?
我想监测温度场的最小值随时间的变化情况。能否直接有工具输入最小值的文件?
 我用的OpenFOAM5.x,尝试采用cellSource来输出,将functions加入至controlDict文件中。但运行计算后并没有输出结果,百思不得其解。
 您的任何建议,都万分感谢!functions { cellSource1 { type cellSource; function ObjectLibs ("libfieldFunctionObjects.so"); enabled true; outputControl outputTime; log true; valueOutput true; source all; operation min; fields ( T ); } }
@东岳 谢谢东岳老师能回复我,开心。下面是你说的时间步log吧。我设的时间步长是240s。 Create time Create mesh for time = 0 SIMPLE: convergence criteria field P tolerance 1e-05 field U tolerance 1e-05 field nuTilda tolerance 1e-05 Reading field p Reading transportProperties Calculating Time = 240 Calculating the Saturation Calculating the pressure head DICPCG: Solving for p, Initial residual = 0, Final residual = 0, No Iterations 0 Calculating the velocity Calculating lamT DILUPBiCG: Solving for T, Initial residual = 0.550522, Final residual = 8.33185e-07, No Iterations 48 ExecutionTime = 34.74 s ClockTime = 41 s Time = 480 Calculating the Saturation Calculating the pressure head DICPCG: Solving for p, Initial residual = 0, Final residual = 0, No Iterations 0 Calculating the velocity Calculating lamT DILUPBiCG: Solving for T, Initial residual = 0.0427664, Final residual = 8.02042e-07, No Iterations 45 ExecutionTime = 37.47 s ClockTime = 44 s Time = 720 Calculating the Saturation Calculating the pressure head DICPCG: Solving for p, Initial residual = 0, Final residual = 0, No Iterations 0 Calculating the velocity Calculating lamT DILUPBiCG: Solving for T, Initial residual = 0.0180619, Final residual = 8.65532e-07, No Iterations 41 ExecutionTime = 39.39 s ClockTime = 46 s Time = 960 Calculating the Saturation Calculating the pressure head DICPCG: Solving for p, Initial residual = 0, Final residual = 0, No Iterations 0 Calculating the velocity Calculating lamT DILUPBiCG: Solving for T, Initial residual = 0.0128672, Final residual = 9.31796e-07, No Iterations 39 ExecutionTime = 40.97 s ClockTime = 47 s Time = 1200 Calculating the Saturation Calculating the pressure head DICPCG: Solving for p, Initial residual = 0, Final residual = 0, No Iterations 0 Calculating the velocity Calculating lamT DILUPBiCG: Solving for T, Initial residual = 0.0098683, Final residual = 8.24145e-07, No Iterations 38 ExecutionTime = 42.45 s ClockTime = 49 s
第一次发帖求助,就能得到东岳老师的回复,真的非常感谢!
 (1)是根据laplacianFOAM稍微改了下的求解器,但是如果是探针probe的话是可以运算出结果的。那cellSource不运行function的话,我需要怎么改下求解器吗
 (2)还想请教下,算例边界条件设置的问题,左图是压力,右图是温度。
 左图压力上下边界条件均为zero flux,右侧问题上下右边界条件为zero conductive flux。对于zero flux和zero conductive flux,边界条件是不是应设置为symmetryPlane,还是zeroGradient。我计算出的结果差别很大,不知道问题出在哪里,所以想确定下是不是我边界条件设置的不对。
@东岳 第一次发帖求助,就能得到东岳老师的回复,真的非常感谢!
