  3. In solid-water flow
In solid-water flow
6 帖子 2 发布者 5.4k 浏览
  • K 离线
    K 离线
    kimy
    How to switch off the turbulent model for particles?
  • K 离线
    K 离线
    kimy
    In pheonics, IPSA can be used to simulate this two phase flow. However, how to realise it in Openfoam. Could you please give me some helps?
    simulationType  laminar;
    What is IPSA
    K 1 条回复 最后回复
  • K 离线
    K 离线
    kimy
    @东岳 IPSA is interphase slip agebrism in phoenics, it is very simple way to simulate, compared with openfoam.
  • K 离线
    K 离线
    kimy
    Why we should give the pressure value in the internalField? Inversly, there is no need to set value for the single phase turbulent flow.
    The left figure is for the two phase flow, the other for the single phase.
    @kimy 在 In solid-water flow 中说:
    Never heard of that
    That's internal field, a good approximation is good for convergence. From your depiction I feel you need to learn more about the general CFD knowledge. You can definitely feel that the lacking of CFD theory is holding you back now
