  4. 射流算例速度发散了,有谁知道怎么解决吗
射流算例速度发散了,有谁知道怎么解决吗
12 帖子 4 发布者 19.7k 浏览
    mark
    *--------------------------------*- C++ -*----------------------------------*\
    |  \\    /   O peration     | Version:  2.4.0                                 |
        format      ascii;
        class       dictionary;
        location    "system";
        object      fvSchemes;
    ddtSchemes
        default         Euler;
    gradSchemes
        default         Gauss linear;
    divSchemes
        default          Gauss upwind;
        div(phi,alpha)  Gauss vanLeer;
        div(phirb,alpha) Gauss linear;
        div(rhoPhi,U)  Gauss upwind;
        div(phi,thermo:rho.fuel) Gauss upwind;
        div(phi,thermo:rho.air) Gauss upwind;
        div(rhoPhi,T)  Gauss upwind;
        div(rhoPhi,K)  Gauss upwind;
        div(phi,p)      Gauss upwind;
        div(phi,k)      Gauss upwind;
        div((muEff*dev2(T(grad(U))))) Gauss linear;
    laplacianSchemes
        default         Gauss linear uncorrected;
    interpolationSchemes
        default         linear;
    snGradSchemes
        default         uncorrected;
    fluxRequired
        default         no;
        p_rgh;
        pcorr;
    mark
        format      ascii;
        class       dictionary;
        location    "system";
        object      fvSolution;
    solvers
        alpha.fuel
            nAlphaCorr      1;
            nAlphaSubCycles 1;
            cAlpha          1;
        ".*(rho|rhoFinal)"
            solver          diagonal;
        pcorr
            solver          GAMG;
            preconditioner
                preconditioner  GAMG;
                tolerance       1e-05;
                relTol          0;
                smoother        GaussSeidel;
                nPreSweeps      0;
                nPostSweeps     2;
                nFinestSweeps   2;
                cacheAgglomeration true;
                nCellsInCoarsestLevel 10;
                agglomerator    faceAreaPair;
                mergeLevels     1;
            tolerance       1e-05;
            relTol          0;
            maxIter         100;
        p_rgh
            solver          GAMG;
            tolerance       1e-07;
            relTol          0.01;
            nPreSweeps      0;
            nPostSweeps     2;
            nFinestSweeps   2;
            mergeLevels     1;
        p_rghFinal
            solver          GAMG;
            preconditioner
                tolerance       1e-07;
                relTol          0;
                nVcycles        2;
                nPreSweeps      2;
                nPostSweeps     2;
                nFinestSweeps   2;
                mergeLevels     1;
            tolerance       1e-07;
            relTol          0;
            maxIter         20;
        "(U|T|k|B|nuTilda).*"
            solver          smoothSolver;
            tolerance       1e-08;
            relTol          0;
    "e.*"
            tolerance       1e-8;
            relTol          0;
            minIter         1;
    PIMPLE
        momentumPredictor yes;
        transonic       yes;
        nOuterCorrectors 5;
        nCorrectors     1;
        nNonOrthogonalCorrectors 2;
        residualControl
            U
              tolerance 1e-07;
              relTol    0;
            p_rgh
              tolerance 1e-07;
              relTol    0;
            T
              tolerance 1e-07;
              relTol    0;
            k
              tolerance 1e-07;
              relTol    0;
    relaxtionFactors
        fields
           p_rgh 0.4;
           p_rghFinal 1;
        equations
           "(U|T|k|B|nuTilda)" 0.4;
           "(U|T|k|B|nuTilda)Final" 1;
    Much appreciated if you provide more information and enforce the operation depicted in this thread.
    mark
    写于 最后由 mark 编辑
    大口进,小口出
    mark
    写于 最后由 wwzhao 编辑
    速度
        format      ascii;
        class       volVectorField;
        object      U;
        INLET
            type            zeroGradient;
        WALL
            type            zeroGradient;
        OUTLET
            type            zeroGradient;
    mark
    写于 最后由 wwzhao 编辑
        format      ascii;
        class       volScalarField;
        object      p;
    internalField   uniform 3e+06;
        INLET
            type            fixedValue;
            value           uniform 100e+6;
        WALL
            type            zeroGradient;
        OUTLET
            type            zeroGradient;
    mark
    写于 最后由 wwzhao 编辑
    /*------------none--------------------*- C++ -*----------------------------------*\
        format      ascii;
        object      p_rgh;
        INLET
            type            fixedValue;
            value           uniform 100e+06;
        WALL
            type            zeroGradient;
        OUTLET
            type            zeroGradient;
    mark
    写于 最后由 wwzhao 编辑
        format      ascii;
        object      alpha.fuel;
    internalField   uniform 0;
        INLET
            type            fixedValue;
            value           uniform 1;
        WALL
            type            zeroGradient;
        OUTLET
            type            zeroGradient;
    mark
    速度和压力设置不对?
    evensunE 1 条回复 最后回复
  • chpjz0391C 离线
    chpjz0391C 离线
    chpjz0391
    请把log文件的信息贴出来。
  • evensunE 离线
    evensunE 离线
    evensun
    在 中回复了 mark 最后由 编辑
    @mark 今天李老师在课上说,如果进出口速度都设为零梯度的话,进出口的压力好像是都需要给定的
