  3. CFD彩虹条
  4. VMware Ubuntu1804
VMware Ubuntu1804
已定时 已固定 已锁定 已移动 CFD彩虹条
26 帖子 5 发布者 31.8k 浏览
    我用了1天Ubuntu-1910+vmware-15
    原本感觉越高版本越臃肿越卡,但感觉速度快了很多,不清楚是Ubuntu-1910又花了还是vmware-15优化了
    神发现,你们试试吧
    P 1 条回复 最后回复
  • P 离线
    P 离线
    Peng
    @东岳 东岳老师,您最新更新的 Ubuntu-1910 + OpenFOAM-7 + OpenFOAM-v1912 + ParaView 里面的ParaView 是 5.7版本,不是官方默认的ParaView 5.6,如何设置一下,可以通过paraFoam 直接启动ParaView5.7呀 ! paraview 5.7.png
    在 中回复了 Peng 最后由 编辑
    @Peng 需要按照这个自己编译一下,http://dyfluid.com/docs/install.html 中的paraFoam安装,我测试过没问题
    你用paraview就行,如果不用拉格朗日粒子的话,paraview更快更稳定
    你那面感觉速度如何?我这面感觉比之前的版本快很多
  • P 离线
    P 离线
    Peng
    @东岳 东岳老师,到第二步./makeParaView 的时候出现了下面的问题:
    Downloading ParaView-5.7.0
    ./makeParaView: 112: curl: not found
    Download unsuccessful
    ParaView download failed.  Re-run to retry download
    usage: makeParaView [OPTION] [CMAKE-OPTION]
    options:
      -rebuild          for repeated builds (-make -install) *use with caution*
      -rendering MODE   rendering backend engine (current value: OpenGL2)
                            modes: OpenGL OpenGL2
      -mesa             with mesa (if not already enabled)
      -mpi              with mpi (if not already enabled)
      -python           with python (if not already enabled)
      -cmake PATH       with the cmake version corresponding to the cmake path given
      -qmake PATH       with the Qt version corresponding to the qmake path given
      -qt               with extra Qt gui support (if not already enabled)
      -qt-VER           with Qt version corresponding to
                            $WM_THIRD_PARTY_DIR/platforms/linux64Gcc/qt-VER/bin/qmake
      -gcc              force g++ instead of the value from $WM_CXX
      -verbose          verbose output in Makefiles
      -version VER      specify an alternative version (current value: 5.7.0)
      -major   VER      specify an alternative major version for special builds
      -mesa-include DIR
                        location of mesa headers (current value: /usr/include/GL)
      -mesa-lib PATH    path to mesa library     (current value: /usr/lib64/libOSMesa.so)
      -python-lib PATH  path to python library   (current value: automatic)
      -python-include DIR
                        path to python include directory (current value: automatic)
      -help
    The -no-FEATURE option can be disable these features (if not already disabled):
      mesa mpi python qt
    CMake options start with a capital letter and contain an '='.
    For example,
        makeParaView BUILD_TESTING=ON
    to add tests
    For finer control, the build stages can be selected or deselected individually:
      -config    -no-config
      -make      -no-make
      -install   -no-install
    * Make and install paraview-5.7.0 located under
          $WM_THIRD_PARTY_DIR/ParaView-5.7.0
      ->  $WM_THIRD_PARTY_DIR/platforms/linux64Gcc/paraview-5.7.0
    感觉没有开始编译。。。:xinlei:
    准备工作还需要进行这一步:
    sudo apt-get install curl
    P 小 3 条回复 最后回复
  • P 离线
    P 离线
    Peng
    @东岳 搞定啦,正在下载,编译,谢谢!
    现在是官方支持ParaView 5.7了么,为什么自动下载的是5.7,还是您哪里做了些改动呢。。。昨天我自己编译安装下载的是5.6
    官方的5.7
    P 1 条回复 最后回复
  • P 离线
    P 离线
    Peng
    @东岳 4K 高分屏幕,paraview里面图标和标题栏太小,促使我想换个新版本试试这个问题有没有解决
  • P 离线
    P 离线
    Peng
    @东岳 谢谢:xinxin:
    在 中回复了 Peng 最后由 编辑
    @Peng 在 VMware Ubuntu1804 中说:
    我18年的时候用的paraview就解决了啊,忘记什么版本了
    现在肯定解决了,
  • P 离线
    P 离线
    Peng
    @东岳 在 VMware Ubuntu1804 中说:
    @东岳 睡醒一觉发现又出问题了,编译不过去。。。,问题如下:
    CMake Error at /home/dyfluid/OpenFOAM/ThirdParty-7/ParaView-5.7.0/CMake/ParaViewClient.cmake:526 (message):
      Failed to convert servermanager XML: xmlpatterns: could not exec
      '/usr/lib/qt5/bin/xmlpatterns': No such file or directory
    make[2]: *** [Plugins/AcceleratedAlgorithms/CMakeFiles/AcceleratedAlgorithms_doc.dir/build.make:66: Plugins/AcceleratedAlgorithms/paraview_help/AcceleratedAlgorithms_doc.xslt] Error 1
    make[1]: *** [CMakeFiles/Makefile2:23530: Plugins/AcceleratedAlgorithms/CMakeFiles/AcceleratedAlgorithms_doc.dir/all] Error 2
    make[1]: *** Waiting for unfinished jobs....
    [  6%] Building CXX object VTK/ThirdParty/vtkm/vtkvtkm/vtk-m/vtkm/cont/CMakeFiles/vtkm_cont.dir/internal/VariantArrayHandleContainer.cxx.o
    [  6%] Building CXX object VTK/ThirdParty/vtkm/vtkvtkm/vtk-m/vtkm/cont/CMakeFiles/vtkm_cont.dir/Field.cxx.o
    [  6%] Building CXX object VTK/ThirdParty/vtkm/vtkvtkm/vtk-m/vtkm/cont/CMakeFiles/vtkm_cont.dir/FieldRangeCompute.cxx.o
    [  6%] Building CXX object VTK/ThirdParty/vtkm/vtkvtkm/vtk-m/vtkm/cont/CMakeFiles/vtkm_cont.dir/FieldRangeGlobalCompute.cxx.o
    [  6%] Building CXX object VTK/ThirdParty/vtkm/vtkvtkm/vtk-m/vtkm/cont/CMakeFiles/vtkm_cont.dir/MultiBlock.cxx.o
    [  6%] Building CXX object VTK/ThirdParty/vtkm/vtkvtkm/vtk-m/vtkm/cont/CMakeFiles/vtkm_cont.dir/PointLocator.cxx.o
    [  6%] Building CXX object VTK/ThirdParty/vtkm/vtkvtkm/vtk-m/vtkm/cont/CMakeFiles/vtkm_cont.dir/PointLocatorUniformGrid.cxx.o
    [  6%] Building CXX object VTK/ThirdParty/vtkm/vtkvtkm/vtk-m/vtkm/cont/CMakeFiles/vtkm_cont.dir/RuntimeDeviceInformation.cxx.o
    [  6%] Building CXX object VTK/ThirdParty/vtkm/vtkvtkm/vtk-m/vtkm/cont/CMakeFiles/vtkm_cont.dir/StorageVirtual.cxx.o
    [  6%] Building CXX object VTK/ThirdParty/vtkm/vtkvtkm/vtk-m/vtkm/cont/CMakeFiles/vtkm_cont.dir/Timer.cxx.o
    [  6%] Building CXX object VTK/ThirdParty/vtkm/vtkvtkm/vtk-m/vtkm/cont/CMakeFiles/vtkm_cont.dir/serial/internal/ArrayManagerExecutionSerial.cxx.o
    [  6%] Building CXX object VTK/ThirdParty/vtkm/vtkvtkm/vtk-m/vtkm/cont/CMakeFiles/vtkm_cont.dir/serial/internal/DeviceAdapterAlgorithmSerial.cxx.o
    [  6%] Building CXX object VTK/ThirdParty/vtkm/vtkvtkm/vtk-m/vtkm/cont/CMakeFiles/vtkm_cont.dir/serial/internal/DeviceAdapterRuntimeDetectorSerial.cxx.o
    [  6%] Building CXX object VTK/ThirdParty/vtkm/vtkvtkm/vtk-m/vtkm/cont/CMakeFiles/vtkm_cont.dir/serial/internal/ExecutionArrayInterfaceBasicSerial.cxx.o
    [  6%] Building CXX object VTK/ThirdParty/vtkm/vtkvtkm/vtk-m/vtkm/cont/CMakeFiles/vtkm_cont.dir/tbb/internal/DeviceAdapterRuntimeDetectorTBB.cxx.o
    [  6%] Building CXX object VTK/ThirdParty/vtkm/vtkvtkm/vtk-m/vtkm/cont/CMakeFiles/vtkm_cont.dir/openmp/internal/DeviceAdapterRuntimeDetectorOpenMP.cxx.o
    [  6%] Building CXX object VTK/ThirdParty/vtkm/vtkvtkm/vtk-m/vtkm/cont/CMakeFiles/vtkm_cont.dir/cuda/internal/DeviceAdapterRuntimeDetectorCuda.cxx.o
    [  6%] Linking CXX static library ../../../../../../../lib/libvtkm_cont-pv5.7.a
    [  6%] Built target vtkm_cont
    make: *** [Makefile:130: all] Error 2
    Command exited with non-zero status 2
    472.23user 51.13system 4:37.84elapsed 188%CPU (0avgtext+0avgdata 574040maxresident)k
    113184inputs+294992outputs (214major+9706377minor)pagefaults 0swaps
    P 1 条回复 最后回复
  • P 离线
    P 离线
    Peng
    @同学博 @东岳
    Ubuntu 18 永久设置分辨率1920x1080:
    https://blog.csdn.net/geekqian/article/details/82965319
    这个帖子亲测有效
  • P 离线
    P 离线
    Peng
    在 中回复了 Peng 最后由 编辑
    @东岳 东岳老师,重新按照教程里的步骤(http://dyfluid.com/docs/install.html :2.2. 编译版paraFoam)编译安装成功了,但是安装的是paraview 5.6.0,而不是5.7.0。
    问题是Layout内的图标太小,看不清。如图所示:WeChat Screenshot_20200104195442.png
    用的电脑是 Microsoft Surface Studio,如何解决这个问题呢?
    同学博同 1 条回复 最后回复
    那几个图标就是那么大的,你经常用那几个图标么?
    P 1 条回复 最后回复
  • P 离线
    P 离线
    Peng
    @东岳 好吧,那就这样吧:papa:
  • 同学博同 离线
    同学博同 离线
    同学博
    在 中回复了 Peng 最后由 编辑
    @Peng 才看到 谢谢!:baobao:
  • 小 离线
    小 离线
    小火人
    @李东岳 2021-10-05 00 28 15.png 东岳老师,我在ubuntu-16.04.6-desktop-i386上面安装of-8,在编译paraview时提示这个异常,查了好久仍没弄明白,想请教下:140:
    另外有个疑问,就是我看paraview官网都是64位的,i386的ubuntu不能使用paraview吗?我下载解压后,双击bin\paraview没反应:haqi:
    在 中回复了 小火人 最后由 编辑
    @小火人 为什么不直接用绿色版paraview呢
