  4. 动态接触角的问题
动态接触角的问题
36 帖子 13 发布者 54.8k 浏览
  • P 离线
    P 离线
    Peng
    @东岳
    东岳老师,我把代码中的dimensionedInternalField() 替换成了volScalarField::Internal(),但还是报错 ‘Foam::volScalarField’ “is not a base of Foam::dynamicKistlerAlphaContactAngleFvPatchScalarField’。”
    代码替换:
    //   << " of field " << this->dimensionedInternalField().name()
          //   << " in file " << this->dimensionedInternalField().objectPath()
               << " of field " << this->volScalarField::Internal().name()
               << " in file " << this->volScalarField::Internal().objectPath()
    编译报错:
    error: ‘Foam::volScalarField’ {aka ‘Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>’} is not a base of ‘const Foam::dynamicKistlerAlphaContactAngleFvPatchScalarField’
      153 |             << " of field " << this->volScalarField::Internal().name()
    这个错误是因为基类缺少了啥或者少声明了什么变量么?
    新手入门,求老师指点一二,十分感谢! 如有需要我可以附上源文件。
    附详细代码块如下:
    // * * * * * * * * * * * * * * * Member Functions  * * * * * * * * * * * * * //
    tmp<scalarField> dynamicKistlerAlphaContactAngleFvPatchScalarField::theta
        const fvPatchVectorField& Up,
        const fvsPatchVectorField& nHat
    ) const
        //eb - Lookup and return the patchField of dynamic viscosity of mixture
        //     and surface tension
        if((muName_ != "muEffKistler") || (sigmaName_ != "sigmaKistler"))
            FatalErrorIn
                "dynamicKistlerAlphaContactAngleFvPatchScalarField"
                << " muEffKistler or sigma set inconsitently, muEffKistler = "
                << muName_ << ", sigmaKistler = " << sigmaName_ << '.' << nl
                << "    Set both muEffKistler and sigmaKistler according to the "
                << "definition of dynamicKistlerAlphaContactAngle"
                << "\n    on patch " << this->patch().name()
                << exit(FatalError);
    详细报错:
    dynamicKistlerAlphaContactAngle/dynamicKistlerAlphaContactAngleFvPatchScalarField.C: In member function ‘virtual Foam::tmp<Foam::Field<double> > Foam::dynamicKistlerAlphaContactAngleFvPatchScalarField::theta(const fvPatchVectorField&, const fvsPatchVectorField&) const’:
    dynamicKistlerAlphaContactAngle/dynamicKistlerAlphaContactAngleFvPatchScalarField.C:153:54: error: ‘Foam::volScalarField’ {aka ‘Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>’} is not a base of ‘const Foam::dynamicKistlerAlphaContactAngleFvPatchScalarField’
    dynamicKistlerAlphaContactAngle/dynamicKistlerAlphaContactAngleFvPatchScalarField.C:154:53: error: ‘Foam::volScalarField’ {aka ‘Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>’} is not a base of ‘const Foam::dynamicKistlerAlphaContactAngleFvPatchScalarField’
      154 |             << " in file " << this->volScalarField::Internal().objectPath()
    dynamicKistlerAlphaContactAngle/dynamicKistlerAlphaContactAngleFvPatchScalarField.C: In member function ‘virtual void Foam::dynamicKistlerAlphaContactAngleFvPatchScalarField::write(Foam::Ostream&) const’:
    dynamicKistlerAlphaContactAngle/dynamicKistlerAlphaContactAngleFvPatchScalarField.C:249:27: error: no matching function for call to ‘writeEntry(const char [6], Foam::Ostream&)’
      249 |     writeEntry("value", os);
    FatalErrorIn
    直接删掉
    P 1 条回复 最后回复
  • P 离线
    P 离线
    Peng
    @东岳 好的,先这样做吧,谢谢!
    xinxinzhou1995
    在 中回复了 Peng 最后由 李东岳 编辑
    @Peng 你好啊,我也在用kistler动态接触角模型,参考的Edin的代码以及MahdiNabil的代码,我的求解器以及lib都编译通过了,但是在运算case的时候报错了,我想请问你遇到这个问题了吗?我用的版本是of4x
    *] --> FOAM FATAL ERROR:
     request for volScalarField muEffKistler from objectRegistry region0 failed
     available objects of type volScalarField are
    * interfaceProperties:K
    * alpha.water
    * p_rgh
    * nu
    * nu1
    * nu2
    * alpha.air
    P 1 条回复 最后回复
  • P 离线
    P 离线
    Peng
    在 中回复了 xinxinzhou1995 最后由 编辑
    @xinxinzhou1995 我没有用这个版本额,我用的高版本的还是有问题,你的问题解决了吗?
    他这个问题是求解需要调用muEffKistler这个volScalarField,但是代码里并没有,因此报错。还是有代码部分的问题
    xinxinzhou1995
    在 中回复了 Peng 最后由 编辑
    @Peng我的动态接触角模型在of4x和of7都是同一个问题,都是这个muEffkistler找不到,但是我的确是求解器和lib都编译通过了,我一直找不出原因。
    fireztwF 1 条回复 最后回复
  • fireztwF 离线
    fireztwF 离线
    fireztw
    @xinxinzhou1995 我也是编译成功了,但不知道边界条件里除了要给定前进和后退接触角,还有什么需要定义的吗?这个muName和sigmaName,以及muEffKistler和sigmaKistler的关系是什么样的呢,怎么给定呢?
    P 1 条回复 最后回复
  • fireztwF 离线
    fireztwF 离线
    fireztw
    在 中回复了 Peng 最后由 编辑
    @Peng 大神能否分享一下fluent 的udf实现方法,openfoam里我在低版本里可以用了(做了一些修改),非常感谢
    P 1 条回复 最后回复
  • P 离线
    P 离线
    Peng
    在 中回复了 fireztw 最后由 编辑
    @fireztw 在 动态接触角的问题 中说:
    留个邮箱,发给你
    fireztwF P Y C P 7 条回复 最后回复
    感谢分享!:146:
  • fireztwF 离线
    fireztwF 离线
    fireztw
    在 中回复了 Peng 最后由 编辑
    @Peng zhangtw2000@126.com
    非常感谢
  • P 离线
    P 离线
    penghui_tan
    在 中回复了 Peng 最后由 编辑
    @Peng 大神能不能也分享一下fluent中动态接触角 的udf实现方法给我,十分感谢。penghui0410@foxmail.com
    zgqsn
    写于 最后由 zgqsn 编辑
    @Peng 大神能麻烦也发我一份udf吗,被接触角困扰好久:136:,我的邮箱是769873738@qq.com,十分感谢!
    Yu_Tian
    在 中回复了 Peng 最后由 编辑
    @Peng 大佬,同求接触角模型,595269271@qq.com,感谢感谢:140:
    永远学习,永远进步
    cfd小学生
    在 中回复了 Peng 最后由 编辑
    @peng 大神!能分享一下fluent里面的UDF么!万分感谢!2602182578@qq.com
  • P 离线
    P 离线
    peiyi
    在 中回复了 Peng 最后由 编辑
    @peng 大神,我也需要这个Kistler的udf,能否也发我一份,万分感谢
  • P 离线
    P 离线
    peiyi
    @fireztw 大神能否分享一下这个在openfoam里的这个Kistler的代码呀,非常非常感谢
  • P 离线
    P 离线
    peiyi
    在 中回复了 Peng 最后由 编辑
    @peng 大佬,忘了说邮箱了,我邮箱是peiyiliao123@126.com,万谢
  • 姜 离线
    姜 离线
    姜磊
    在 中回复了 Peng 最后由 编辑
    @peng
    能麻烦您分享一下fluent中动态接触角的udf吗,最近在研究凝结换热的问题,不知道怎么描述生成的液滴接触角,十分感谢!
    邮箱 1653666461@qq.com
    B 1 条回复 最后回复
