  2. CFD彩虹条
  3. 英语记录
英语记录
已定时 已固定 已锁定 已移动 CFD彩虹条
1 帖子 1 发布者 1.4k 浏览
    I want to keep my bike close by, so I can fix it
    I want to take off (remove) the bike wheel
    Allen key
    It doesn't fit
    Move over, scoot over, can I get passed, please
    She likes more and more like me everyday
    I rarely (don't often) watch TV
    Why did you set the temperature to 20 degrees
    Dont rush me
    I want to get rid of the extra oil
    I can take some, I will finish what's left
    She has a loose tooth, and its goin to fall out
    She is not fully awake, she is a bit groggy
    She is the one who loves me the most, she loves me the most
    Put on the striped onesie
    Move forwards and backwards
    Her ton nail is broken
    This is her first time seeing it
    This drink is non-alcoholic, you can have a sip
    Take a big step forward
    A loose thread
    Lift my leg and put it down
    Stick out your tongue
    She is lying on her side
    I did it all in one go
    Do you mind if I add her to our chat?
    Please comment on the sentences above
    Look at the lines on your arm. You leaned against something, that left lines on your arm.
    Pull the handle to open the wardrobe
    She just wants to be held up one your shoulder, she just wants to be held close to your chest
    I am afraid of the dark
    When she is sleeping, how does she know who is beside her
    She does not care about anything, she is not easily bothered by things, she has high tolerance. I have a high pain tolerance.
    If someone's ideas can be easily influenced by others,
    She does not want to lean back
    Give yourself a round of applause
    Candy wrapper
    I am meshing the pataya???
    Are u scared of mosquitoes biting you?
    Do you hear me calling you?
    Another spoonful
    How about I weigh you?
