OpenFoam中的溃坝算例加入自适应网格计算一定时间步后出现的问题
请问各位大佬有没有曾经遇到过算例计算过程中提示“浮点数例外 (核心已转储)”
 ,谢谢帮忙解答!
 我最近在学习interFOAM求解器相关知识,目前向使用interFOAM求解器加上自适应网格计算两相流问题,在利用OpenFoam自带算例修改无报错后,开始利用interDyMFoam进行求解。但何运算基本在0.3s附近出现下图中的错误中断(of2.3.1和of7中都出现了该报错)
 而且还有一个问题,但何运行计算到0.3s附近出现该错误,双核并行0.1s,四个核时亦不就中断了。无自适应时算例能正常计算。
 麻烦各位大哥有知道y原因的帮忙回答一下,谢谢!
OpenFoam-2.3.1 Interface Courant Number mean: 0.0038340104 max: 0.84420783 Courant Number mean: 0.037028394 max: 0.99652771 deltaT = 5.2872478e-05 Time = 0.31246054 Selected 124 cells for refinement out of 273070. Refined from 273070 to 273938 cells. Selected 83 split points out of a possible 32348. Unrefined from 273938 to 273357 cells. Execution time for mesh.update() = 3.39 s DICPCG: Solving for pcorr, Initial residual = 1, Final residual = 9.8048258e-06, No Iterations 389 time step continuity errors : sum local = 5.4228827e-10, global = -2.51365e-13, cumulative = 0.00017816493 smoothSolver: Solving for alpha.water, Initial residual = 0.00055204007, Final residual = 6.4208784e-09, No Iterations 2 Phase-1 volume fraction = 0.13010958 Min(alpha1) = -9.3530875e-08 Max(alpha1) = 1.0000001 MULES: Correcting alpha.water MULES: Correcting alpha.water Phase-1 volume fraction = 0.13010958 Min(alpha1) = -1.3561514e-05 Max(alpha1) = 1.0000079 GAMG: Solving for p_rgh, Initial residual = 0.033205248, Final residual = 0.00014731475, No Iterations 2 #0 Foam::error::printStack(Foam::Ostream&) at ??:? #1 Foam::sigFpe::sigHandler(int) at ??:? #2 in "/lib/x86_64-linux-gnu/libc.so.6" #3 at tensorField.C:? #4 in "/home/vaseatar/OpenFOAM/OpenFOAM-2.3.1/platforms/linux64GccDPOpt/bin/interDyMFoam" #5 in "/home/vaseatar/OpenFOAM/OpenFOAM-2.3.1/platforms/linux64GccDPOpt/bin/interDyMFoam" #6 in "/home/vaseatar/OpenFOAM/OpenFOAM-2.3.1/platforms/linux64GccDPOpt/bin/interDyMFoam" #7 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6" #8 in "/home/vaseatar/OpenFOAM/OpenFOAM-2.3.1/platforms/linux64GccDPOpt/bin/interDyMFoam"上面图片好像没有显示,抱歉!这里添加一下报错误的文本 OpenFoam-7 Courant Number mean: 0.0742364 max: 0.985473 Interface Courant Number mean: 0.0103739 max: 0.761644 deltaT = 0.000210711 Time = 0.331036 Selected 20 cells for refinement out of 36008. Refined from 36008 to 36148 cells. Selected 7 split points out of a possible 4206. Unrefined from 36148 to 36099 cells. DICPCG: Solving for pcorr, Initial residual = 1, Final residual = 9.59577e-06, No Iterations 208 time step continuity errors : sum local = 1.48015e-09, global = 1.6711e-12, cumulative = 0.000723778 smoothSolver: Solving for alpha.water, Initial residual = 0.00142426, Final residual = 1.32652e-09, No Iterations 3 Phase-1 volume fraction = 0.130119 Min(alpha.water) = -4.43817e-11 Max(alpha.water) = 1 MULES: Correcting alpha.water MULES: Correcting alpha.water Phase-1 volume fraction = 0.130119 Min(alpha.water) = -3.77094e-05 Max(alpha.water) = 1 DICPCG: Solving for p_rgh, Initial residual = 0.0515556, Final residual = 0.0021802, No Iterations 2 time step continuity errors : sum local = 0.000166589, global = -9.96186e-07, cumulative = 0.000722782 DICPCG: Solving for p_rgh, Initial residual = 0.00314206, Final residual = 0.000140061, No Iterations 10 time step continuity errors : sum local = 1.0632e-05, global = -3.56508e-07, cumulative = 0.000722425 DICPCG: Solving for p_rgh, Initial residual = 0.000874623, Final residual = 9.92427e-08, No Iterations 170 time step continuity errors : sum local = 7.53188e-09, global = -2.18209e-10, cumulative = 0.000722425 ExecutionTime = 431.97 s ClockTime = 432 s Courant Number mean: 0.0750393 max: 0.990053 Interface Courant Number mean: 0.0104568 max: 0.765205 deltaT = 0.000210711 Time = 0.331247 Selected 20 cells for refinement out of 36099. Refined from 36099 to 36239 cells. Selected 12 split points out of a possible 4220. Unrefined from 36239 to 36155 cells. DICPCG: Solving for pcorr, Initial residual = 1, Final residual = 8.95937e-06, No Iterations 199 time step continuity errors : sum local = 1.55988e-09, global = 1.04349e-11, cumulative = 0.000722425 smoothSolver: Solving for alpha.water, Initial residual = 0.00142307, Final residual = 1.50653e-09, No Iterations 3 Phase-1 volume fraction = 0.130116 Min(alpha.water) = -4.43604e-11 Max(alpha.water) = 1 MULES: Correcting alpha.water MULES: Correcting alpha.water Phase-1 volume fraction = 0.130116 Min(alpha.water) = -4.22756e-05 Max(alpha.water) = 1 DICPCG: Solving for p_rgh, Initial residual = 0.0570999, Final residual = 0.00183939, No Iterations 3 #0 Foam::error::printStack(Foam::Ostream&) at ??:? #1 Foam::sigFpe::sigHandler(int) at ??:? #2 ? in "/lib/x86_64-linux-gnu/libc.so.6" #3 ? at tensorField.C:? #4 ? in "/home/vaseatar/OpenFOAM/OpenFOAM-7/platforms/linux64GccDPInt64Opt/bin/interFoam" #5 ? in "/home/vaseatar/OpenFOAM/OpenFOAM-7/platforms/linux64GccDPInt64Opt/bin/interFoam" #6 ? in "/home/vaseatar/OpenFOAM/OpenFOAM-7/platforms/linux64GccDPInt64Opt/bin/interFoam" #7 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6" #8 ? in "/home/vaseatar/OpenFOAM/OpenFOAM-7/platforms/linux64GccDPInt64Opt/bin/interFoam"
