  4. 涡量如何在代码中引用?
涡量如何在代码中引用?
8 帖子 3 发布者 7.9k 浏览
  • 荷 离线
    荷 离线
    荷兰后腰阿贾克斯
    各位春节好~
    我想在LESdeltas中植入个方程如下:
    根据maxDeltaxyz改动了如下:(会报错)
    void Foam::LESModels::TestDeltaxyz::calcDelta()
        const fvMesh& mesh = momentumTransportModel_.mesh();
        const volVectorField& U = momentumTransportModel_.U();
        label nD = mesh.nGeometricD();
        const cellList& cells = mesh.cells();//get faces list
        const pointField& pc = mesh.points();//get point coordinates
        scalarField hmax(cells.size());
        forAll(cells,celli)
            scalar deltaMaxTmp = 0.0;
            const labelList& meshPoints = mesh.cellPoints()[celli];
            const vector & Ux = U.internalField()[celli];//不知道这么写对不对
            const vectorField& vorticity = fvc::curl(Ux);//how can i get the vorticity?
            const vectorField& nv = (vorticity/mag(vorticity));//normal vorticity
            const vector nvi = nv[celli];
            forAll(meshPoints, pointi)//   i
                label pointI = meshPoints[pointi];
                const point& rn = pc[pointI];
                vector  ln =  nvi ^ rn;
                     forAll(meshPoints, pointj)//   j
                            label pointJ = meshPoints[pointj];
                            const point& rm = pc[pointJ];
                            vector lm =  nvi ^ rm;
                            scalar tmp = mag(ln - lm);
                            if (tmp > deltaMaxTmp)
                                deltaMaxTmp = tmp;
            hmax[celli] = deltaCoeff_*deltaMaxTmp;
    关于涡量的引入有什么方法吗?以及我的循环方式可行吗?
    我尝试加入fvc.h文件,想通过对速度求curl,但目前仍然无法使用,怎样写才能使它正常工作呢?
    祝好
    你要对U做curl,所以应该是const volVectorField vort = fvc::curl(U);
    荷 2 条回复 最后回复
  • 荷 离线
    荷 离线
    荷兰后腰阿贾克斯
    @李东岳 感谢李老师的指点!
    但是现在编译遇到的报错仍和之前一样,提示我no matching function for call to curl
    error:no matching function for call to “curl(const vector&)”
    in file......note:candidate:template<class Type>  Foam::tmp::<Foam::GeometricField<Type, Foam::fvpatchField,Foam::volMesh>> Foam::fvc::curl(const Foam::GeometricField<Type, Foam::fvPatchField, Foam::volMesh>&)
               curl
    ....other
    速度Ux的引入是正确的吗?我该如何使其工作?
  • 荷 离线
    荷 离线
    荷兰后腰阿贾克斯
    @李东岳 东岳老师您好,目前进展卡在速度的引入上
    forAll(cells,celli)
            const volVectorField& uCell = U[celli];
            const volVectorField& vorticity = fvc::curl(uCell);
    编译显示速度场无效初始化
    error: invalid initialization of reference of type ‘const volVectorField& {aka const Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh>&}’ from expression of type ‘const Foam::Vector<double>’
    所以 速度 该怎么正确引入到写的代码里呢?感激不尽!
    vector uCell(U[celli]);
    cresendo
    想请问这是哪篇文献呢?:140:
    荷 1 条回复 最后回复
  • 荷 离线
    荷 离线
    荷兰后腰阿贾克斯
    在 中回复了 cresendo 最后由 编辑
    @cresendo shur2015年的一篇文献,An Enhanced V ersion of DES with Rapid Transition from RANS to LES in Separated Flows
    你也做DES吗?
    cresendo
    在 中回复了 荷兰后腰阿贾克斯 最后由 编辑
    @荷兰后腰阿贾克斯 嗯嗯,谢谢老哥了:xinxin3:
