  4. 阿里云ECS初体验
阿里云ECS初体验
19 帖子 3 发布者 22.3k 浏览
    Samuel-Tu
    ecs上ThirdParty那个文件一直安不上。ThirdParty应该是Paraview吧,不安对计算没影响吧?我是安的OpenFOAM-1806.
    因为我看东岳流体上的安装教程先安OpenFOAM,再安的ThirdParty.如果只需要计算,应该不需要安ThirdParty吧
    在 中回复了 Samuel-Tu 最后由 编辑
    @Samuel-Tu 除了图形雷后处理,其他需要,比如并行分解
    Samuel-Tu
    一直安不上,我是按wiki里的步骤安的,不知道啥原因,能不能帮我看下
    Python information:
        executable     : /usr/bin/python
        version        : 2.7
        include path   : /usr/include/python2.7
        library        : /usr/lib/x86_64-linux-gnu/libpython2.7.so.1.0
    Using qmake=/usr/bin/qmake
    ParaView_SOURCE_DIR=/root/OpenFOAM/ThirdParty-v1806/ParaView-v5.5.2
    ParaView_BUILD_DIR=/root/OpenFOAM/ThirdParty-v1806/build/linux64Gcc/ParaView-5.5.2
    ParaView_DIR=/root/OpenFOAM/ThirdParty-v1806/platforms/linux64Gcc/ParaView-5.5.2
    Build stages selected
        -patch    true
        -config   true
        -make     true
        -install  true
    Features selected
        mesa      false
        mpi       true
        python    true
        qt        true
    Version information
        paraview  5.5.2
        major     5.5
        build     Release
        qt        5.5.1
    patch for paraview-5.5.2 was already applied
    Using cmake=/usr/bin/cmake
    Configuring paraview-5.5.2 (major version: 5.5)
        MPI    support : true
        Python support : true
        MESA   support : false
        GL2  rendering : true
        QT dev support : true
        Source         : /root/OpenFOAM/ThirdParty-v1806/ParaView-v5.5.2
        Build          : /root/OpenFOAM/ThirdParty-v1806/build/linux64Gcc/ParaView-5.5.2
        Target         : /root/OpenFOAM/ThirdParty-v1806/platforms/linux64Gcc/ParaView-5.5.2
        cmake          : /usr/bin/cmake
        Build suffix   : none
    /usr/bin/cmake -DCMAKE_INSTALL_PREFIX=/root/OpenFOAM/ThirdParty-v1806/platforms/linux64Gcc/ParaView-5.5.2 -DBUILD_SHARED_LIBS=ON -DBUILD_TESTING=OFF -DPARAVIEW_INSTALL_DEVELOPMENT_FILES=ON -DPARAVIEW_USE_MPI=ON -DVTK_USE_MPI=ON -DPARAVIEW_ENABLE_PYTHON=ON -DPYTHON_INCLUDE_DIRS=/usr/include/python2.7 -DPYTHON_LIBRARY=/usr/lib/x86_64-linux-gnu/libpython2.7.so.1.0 -DVTK_RENDERING_BACKEND=OpenGL2 -DPARAVIEW_BUILD_QT_GUI=ON -DPARAVIEW_QT_VERSION=5 -DCMAKE_BUILD_TYPE=Release /root/OpenFOAM/ThirdParty-v1806/ParaView-v5.5.2
    -- The C compiler identification is GNU 5.4.0
    -- The CXX compiler identification is GNU 5.4.0
    -- Check for working C compiler: /usr/bin/gcc
    -- Check for working C compiler: /usr/bin/gcc -- works
    -- Detecting C compiler ABI info
    -- Detecting C compiler ABI info - done
    -- Detecting C compile features
    -- Detecting C compile features - done
    -- Check for working CXX compiler: /usr/bin/g++
    -- Check for working CXX compiler: /usr/bin/g++ -- works
    -- Detecting CXX compiler ABI info
    -- Detecting CXX compiler ABI info - done
    -- Detecting CXX compile features
    -- Detecting CXX compile features - done
    -- Could NOT find Git (missing:  GIT_EXECUTABLE)
    -- Could not use git to determine source version, using version 5.5.2
    -- Looking for a Fortran compiler
    -- Looking for a Fortran compiler - NOTFOUND
    -- Performing Test VTK_UNDEFINED_SYMBOLS_ALLOWED - Success
    -- Performing Test HAVE_GCC_ERROR_RETURN_TYPE
    -- Performing Test HAVE_GCC_ERROR_RETURN_TYPE - Success
    -- Looking for pthread.h
    -- Looking for pthread.h - found
    -- Looking for pthread_create
    -- Looking for pthread_create - not found
    -- Looking for pthread_create in pthreads
    -- Looking for pthread_create in pthreads - not found
    -- Looking for pthread_create in pthread - found
    -- Found Threads: TRUE
    -- Performing Test Support for 64 bit file systems
    -- Performing Test Support for 64 bit file systems - Success
    -- Group Rendering modules: vtkGeovisCore;vtkInteractionStyle;vtkInteractionImage;vtkInteractionWidgets;vtkRenderingLOD;vtkRenderingAnnotation;vtkRenderingContext2D;vtkRenderingVolume;vtkRenderingCore;vtkRenderingFreeType;vtkRenderingLabel;vtkRenderingImage;vtkIOExport;vtkViewsInfovis;vtkViewsContext2D;vtkViewsCore
    -- Group Imaging modules: vtkInteractionImage;vtkRenderingImage;vtkImagingSources;vtkImagingHybrid;vtkImagingMorphological;vtkImagingStatistics;vtkImagingColor;vtkImagingMath;vtkImagingStencil;vtkImagingGeneral;vtkImagingFourier;vtkFiltersImaging
    -- Group Web modules: vtkWebGLExporter;vtkWebCore;vtkWebPython
    -- Group MPI modules: vtkdiy2;vtkParallelMPI4Py;vtkParallelMPI;vtkIOParallelNetCDF;vtkIOMPIParallel;vtkIOMPIImage;vtkFiltersParallelMPI;vtkFiltersParallelGeometry;vtkFiltersParallelDIY2;vtkFiltersParallelVerdict
    -- Group StandAlone modules: vtkInfovisCore;vtkInfovisLayout;vtkParallelCore;vtkCommonDataModel;vtkCommonMisc;vtkCommonTransforms;vtkCommonComputationalGeometry;vtkCommonCore;vtkCommonSystem;vtkCommonExecutionModel;vtkDomainsChemistry;vtkChartsCore;vtkIOEnSight;vtkIOLegacy;vtkIOAMR;vtkIOTecplotTable;vtkIOImport;vtkIOInfovis;vtkIOXML;vtkIOParallel;vtkIOVideo;vtkIOLSDyna;vtkIOSQL;vtkIOExodus;vtkIOPLY;vtkIONetCDF;vtkIOGeometry;vtkIOParallelXML;vtkIOCore;vtkIOXMLParser;vtkIOImage;vtkIOMovie;vtkIOMINC;vtkImagingSources;vtkImagingHybrid;vtkImagingMorphological;vtkImagingStatistics;vtkImagingColor;vtkImagingMath;vtkImagingStencil;vtkImagingCore;vtkImagingGeneral;vtkImagingFourier;vtkFiltersSources;vtkFiltersAMR;vtkFiltersVerdict;vtkFiltersGeneric;vtkFiltersTopology;vtkFiltersSMP;vtkFiltersHybrid;vtkFiltersParallel;vtkFiltersStatistics;vtkFiltersProgrammable;vtkFiltersExtraction;vtkFiltersHyperTree;vtkFiltersFlowPaths;vtkFiltersGeometry;vtkFiltersTexture;vtkFiltersCore;vtkFiltersGeneral;vtkFiltersImaging;vtkFiltersPoints;vtkFiltersPython;vtkFiltersSelection;vtkFiltersParallelImaging;vtkFiltersModeling
    -- Group Qt modules: vtkRenderingQt;vtkGUISupportQt;vtkGUISupportQtSQL;vtkViewsQt;vtkPVVTKExtensionsRendering;pqWidgets
    -- Group Tk modules: vtkRenderingTk
    -- Group Views modules: vtkViewsGeovis;vtkViewsContext2D
    -- Group ParaViewCore modules: smTestDriver;vtkPVClientServerCoreCore;vtkPVCommon;vtkPVServerManagerCore;vtkPVServerImplementationCore;vtkPVVTKExtensionsCore
    -- Group ParaViewRendering modules: vtkPVClientServerCoreRendering;vtkPVServerManagerRendering;vtkPVServerImplementationRendering;vtkPVVTKExtensionsRendering
    -- Group ParaViewQt modules: pqApplicationComponents;pqComponents;pqCore;pqWidgets
    -- Backend OpenGL2 modules: vtkRenderingOpenVR;vtkRenderingVolumeOpenGL2;vtkRenderingOculus;vtkRenderingGL2PSOpenGL2;vtkRenderingOpenGL2;vtkRenderingLICOpenGL2;vtkRenderingContextOpenGL2;vtkDomainsChemistryOpenGL2;vtkIOExportOpenGL2;vtkImagingOpenGL2
    -- Enabling modules for OpenGL2.
    -- Checking whether header cstdio is available
    -- Checking whether header cstdio is available - yes
    -- Checking for Large File Support
    -- Checking for Large File Support - yes
    -- Checking whether C++ compiler has 'long long'
    -- Checking whether C++ compiler has 'long long' - yes
    -- Checking whether C++ compiler has '__int64'
    -- Checking whether C++ compiler has '__int64' - no
    -- Checking whether wstring is available
    -- Checking whether wstring is available - yes
    -- Checking whether C compiler has ptrdiff_t in stddef.h
    -- Checking whether C compiler has ptrdiff_t in stddef.h - yes
    -- Checking whether C compiler has ssize_t in unistd.h
    -- Checking whether C compiler has ssize_t in unistd.h - yes
    -- Checking whether C compiler has clock_gettime
    -- Checking whether C compiler has clock_gettime - yes
    -- Checking whether CXX compiler has setenv
    -- Checking whether CXX compiler has setenv - yes
    -- Checking whether CXX compiler has unsetenv
    -- Checking whether CXX compiler has unsetenv - yes
    -- Checking whether CXX compiler has environ in stdlib.h
    -- Checking whether CXX compiler has environ in stdlib.h - no
    -- Checking whether CXX compiler has utimes
    -- Checking whether CXX compiler has utimes - yes
    -- Checking whether CXX compiler has utimensat
    -- Checking whether CXX compiler has utimensat - yes
    -- Checking whether CXX compiler struct stat has st_mtim member
    -- Checking whether CXX compiler struct stat has st_mtim member - yes
    -- Checking whether CXX compiler struct stat has st_mtimespec member
    -- Checking whether CXX compiler struct stat has st_mtimespec member - no
    -- Looking for include files sys/types.h, ifaddrs.h
    -- Looking for include files sys/types.h, ifaddrs.h - found
    -- Checking whether CXX compiler has rlimit64
    -- Checking whether CXX compiler has rlimit64 - yes
    -- Checking whether CXX compiler has atol
    -- Checking whether CXX compiler has atol - yes
    -- Checking whether CXX compiler has atoll
    -- Checking whether CXX compiler has atoll - yes
    -- Checking whether CXX compiler has _atoi64
    -- Checking whether CXX compiler has _atoi64 - no
    -- Looking for C++ include execinfo.h
    -- Looking for C++ include execinfo.h - found
    -- Checking whether backtrace works with this C++ compiler
    -- Checking whether backtrace works with this C++ compiler - yes
    -- Looking for C++ include dlfcn.h
    -- Looking for C++ include dlfcn.h - found
    -- Checking whether dladdr works with this C++ compiler
    -- Checking whether dladdr works with this C++ compiler - yes
    -- Looking for C++ include cxxabi.h
    -- Looking for C++ include cxxabi.h - found
    -- Checking whether cxxabi works with this C++ compiler
    -- Checking whether cxxabi works with this C++ compiler - yes
    -- Checking whether CXX compiler has getloadavg
    -- Checking whether CXX compiler has getloadavg - yes
    -- Checking whether <ext/stdio_filebuf.h> is available
    -- Checking whether <ext/stdio_filebuf.h> is available - yes
    -- Checking for builtin __sync_add_and_fetch
    -- Checking for builtin __sync_add_and_fetch -- success
    -- Check if the system is big endian
    -- Searching 16 bit integer
    -- Looking for sys/types.h
    -- Looking for sys/types.h - found
    -- Looking for stdint.h
    -- Looking for stdint.h - found
    -- Looking for stddef.h
    -- Looking for stddef.h - found
    -- Check size of unsigned short
    -- Check size of unsigned short - done
    -- Using unsigned short
    -- Check if the system is big endian - little endian
    -- Performing Test VTK_HAS_STD_ISNAN
    -- Performing Test VTK_HAS_STD_ISNAN - Success
    -- Performing Test VTK_HAS_STD_ISINF
    -- Performing Test VTK_HAS_STD_ISINF - Success
    -- Performing Test VTK_HAS_STD_ISFINITE
    -- Performing Test VTK_HAS_STD_ISFINITE - Success
    -- Looking for isnan
    -- Looking for isnan - found
    -- Looking for isinf
    -- Looking for isinf - found
    -- Looking for isfinite
    -- Looking for isfinite - found
    -- Looking for finite
    -- Looking for finite - found
    -- Looking for fenv.h
    -- Looking for fenv.h - found
    -- Looking for feenableexcept
    -- Looking for feenableexcept - found
    -- Performing Test COMPILER_HAS_HIDDEN_VISIBILITY
    -- Performing Test COMPILER_HAS_HIDDEN_VISIBILITY - Success
    -- Performing Test COMPILER_HAS_HIDDEN_INLINE_VISIBILITY
    -- Performing Test COMPILER_HAS_HIDDEN_INLINE_VISIBILITY - Success
    -- Performing Test COMPILER_HAS_DEPRECATED_ATTR
    -- Performing Test COMPILER_HAS_DEPRECATED_ATTR - Success
    -- Looking for getsockname in socket
    -- Looking for getsockname in socket - not found
    -- Checking for getsockname with socklen_t
    -- Checking for getsockname with socklen_t -- 1
    -- Looking for SO_REUSEADDR
    -- Looking for SO_REUSEADDR - found
    -- Performing Test standard_math_library_linked_to_automatically
    -- Performing Test standard_math_library_linked_to_automatically - Success
    -- Performing Test COMPILER_SUPPORT_WERROR
    -- Performing Test COMPILER_SUPPORT_WERROR - Success
    -- Performing Test COMPILER_SUPPORT_pedantic
    -- Performing Test COMPILER_SUPPORT_pedantic - Success
    -- Performing Test COMPILER_SUPPORT_Wall
    -- Performing Test COMPILER_SUPPORT_Wall - Success
    -- Performing Test COMPILER_SUPPORT_Wextra
    -- Performing Test COMPILER_SUPPORT_Wextra - Success
    -- Performing Test COMPILER_SUPPORT_Wundef
    -- Performing Test COMPILER_SUPPORT_Wundef - Success
    -- Performing Test COMPILER_SUPPORT_Wcastalign
    -- Performing Test COMPILER_SUPPORT_Wcastalign - Success
    -- Performing Test COMPILER_SUPPORT_Wcharsubscripts
    -- Performing Test COMPILER_SUPPORT_Wcharsubscripts - Success
    -- Performing Test COMPILER_SUPPORT_Wnonvirtualdtor
    -- Performing Test COMPILER_SUPPORT_Wnonvirtualdtor - Success
    -- Performing Test COMPILER_SUPPORT_Wunusedlocaltypedefs
    -- Performing Test COMPILER_SUPPORT_Wunusedlocaltypedefs - Success
    -- Performing Test COMPILER_SUPPORT_Wpointerarith
    -- Performing Test COMPILER_SUPPORT_Wpointerarith - Success
    -- Performing Test COMPILER_SUPPORT_Wwritestrings
    -- Performing Test COMPILER_SUPPORT_Wwritestrings - Success
    -- Performing Test COMPILER_SUPPORT_Wformatsecurity
    -- Performing Test COMPILER_SUPPORT_Wformatsecurity - Success
    -- Performing Test COMPILER_SUPPORT_Wshorten64to32
    -- Performing Test COMPILER_SUPPORT_Wshorten64to32 - Failed
    -- Performing Test COMPILER_SUPPORT_Wlogicalop
    -- Performing Test COMPILER_SUPPORT_Wlogicalop - Success
    -- Performing Test COMPILER_SUPPORT_Wenumconversion
    -- Performing Test COMPILER_SUPPORT_Wenumconversion - Failed
    -- Performing Test COMPILER_SUPPORT_Wcpp11extensions
    -- Performing Test COMPILER_SUPPORT_Wcpp11extensions - Failed
    -- Performing Test COMPILER_SUPPORT_Wdoublepromotion
    -- Performing Test COMPILER_SUPPORT_Wdoublepromotion - Success
    -- Performing Test COMPILER_SUPPORT_Wnopsabi
    -- Performing Test COMPILER_SUPPORT_Wnopsabi - Success
    -- Performing Test COMPILER_SUPPORT_Wnovariadicmacros
    -- Performing Test COMPILER_SUPPORT_Wnovariadicmacros - Success
    -- Performing Test COMPILER_SUPPORT_Wnolonglong
    -- Performing Test COMPILER_SUPPORT_Wnolonglong - Success
    -- Performing Test COMPILER_SUPPORT_fnochecknew
    -- Performing Test COMPILER_SUPPORT_fnochecknew - Success
    -- Performing Test COMPILER_SUPPORT_fnocommon
    -- Performing Test COMPILER_SUPPORT_fnocommon - Success
    -- Performing Test COMPILER_SUPPORT_fstrictaliasing
    -- Performing Test COMPILER_SUPPORT_fstrictaliasing - Success
    -- Performing Test COMPILER_SUPPORT_wd981
    -- Performing Test COMPILER_SUPPORT_wd981 - Failed
    -- Performing Test COMPILER_SUPPORT_wd2304
    -- Performing Test COMPILER_SUPPORT_wd2304 - Failed
    -- Performing Test COMPILER_SUPPORT_STRICTANSI
    -- Performing Test COMPILER_SUPPORT_STRICTANSI - Failed
    -- Performing Test COMPILER_SUPPORT_Qunusedarguments
    -- Performing Test COMPILER_SUPPORT_Qunusedarguments - Failed
    -- Performing Test COMPILER_SUPPORT_ansi
    -- Performing Test COMPILER_SUPPORT_ansi - Success
    -- Performing Test COMPILER_SUPPORT_OPENMP
    -- Performing Test COMPILER_SUPPORT_OPENMP - Success
    -- Found OpenGL: /usr/lib/x86_64-linux-gnu/libGL.so
    -- Looking for XOpenDisplay in /usr/lib/x86_64-linux-gnu/libX11.so;/usr/lib/x86_64-linux-gnu/libXext.so
    -- Looking for XOpenDisplay in /usr/lib/x86_64-linux-gnu/libX11.so;/usr/lib/x86_64-linux-gnu/libXext.so - found
    -- Looking for gethostbyname
    -- Looking for gethostbyname - found
    -- Looking for connect
    -- Looking for connect - found
    -- Looking for remove
    -- Looking for remove - found
    -- Looking for shmat
    -- Looking for shmat - found
    -- Looking for IceConnectionNumber in ICE
    -- Looking for IceConnectionNumber in ICE - found
    -- Found X11: /usr/lib/x86_64-linux-gnu/libX11.so
    -- Looking for strings.h
    -- Looking for strings.h - found
    -- Looking for byteswap.h
    -- Looking for byteswap.h - found
    -- Looking for sys/endian.h
    -- Looking for sys/endian.h - not found
    -- Looking for HAVE_BSWAP_16
    -- Looking for HAVE_BSWAP_16 - not found
    -- Looking for HAVE_BSWAP_32
    -- Looking for HAVE_BSWAP_32 - not found
    -- Looking for HAVE_BSWAP_64
    -- Looking for HAVE_BSWAP_64 - not found
    -- Looking for inttypes.h
    -- Looking for inttypes.h - found
    -- Looking for limits.h
    -- Looking for limits.h - found
    -- Looking for stdbool.h
    -- Looking for stdbool.h - found
    -- Looking for string.h
    -- Looking for string.h - found
    -- Looking for memory.h
    -- Looking for memory.h - found
    -- Check size of int16_t
    -- Check size of int16_t - done
    -- Check size of int32_t
    -- Check size of int32_t - done
    -- Check size of int64_t
    -- Check size of int64_t - done
    -- Check size of intmax_t
    -- Check size of intmax_t - done
    -- Check size of uint8_t
    -- Check size of uint8_t - done
    -- Check size of uint16_t
    -- Check size of uint16_t - done
    -- Check size of uint32_t
    -- Check size of uint32_t - done
    -- Check size of uint64_t
    -- Check size of uint64_t - done
    -- Check size of uintmax_t
    -- Check size of uintmax_t - done
    -- Check size of short
    -- Check size of short - done
    -- Check size of int - done
    -- Check size of long
    -- Check size of long - done
    -- Check size of long long
    -- Check size of long long - done
    -- Check size of unsigned - done
    -- Check size of unsigned long
    -- Check size of unsigned long - done
    -- Check size of unsigned long long
    -- Check size of unsigned long long - done
    -- Check size of size_t
    -- Check size of size_t - done
    -- Check size of __int64
    -- Check size of __int64 - failed
    -- Check size of unsigned __int64
    -- Check size of unsigned __int64 - failed
    -- Check size of uintptr_t
    -- Check size of uintptr_t - done
    -- Check size of off64_t
    -- Check size of off64_t - done
    -- Looking for unistd.h
    -- Looking for unistd.h - found
    -- Looking for dlfcn.h
    -- Looking for dlfcn.h - found
    -- Looking for fcntl.h
    -- Looking for fcntl.h - found
    -- Looking for stdlib.h
    -- Looking for stdlib.h - found
    -- Looking for sys/stat.h
    -- Looking for sys/stat.h - found
    -- Looking for getpagesize
    -- Looking for getpagesize - found
    -- Looking for getrandom
    -- Looking for getrandom - not found
    -- Looking for bcopy
    -- Looking for bcopy - found
    -- Looking for memmove
    -- Looking for memmove - found
    -- Looking for mmap
    -- Looking for mmap - found
    -- Looking for arc4random_buf
    -- Looking for arc4random_buf - not found
    -- Looking for arc4random - not found
    -- Looking for 4 include files stdlib.h, ..., float.h
    -- Looking for 4 include files stdlib.h, ..., float.h - found
    -- Looking for off_t
    -- Looking for off_t - not found
    -- Looking for size_t
    -- Looking for size_t - not found
    -- Performing Test HAVE_SYSCALL_GETRANDOM
    -- Performing Test HAVE_SYSCALL_GETRANDOM - Success
    -- Performing Test FLAG_NO_STRICT_ALIASING
    -- Performing Test FLAG_NO_STRICT_ALIASING - Success
    -- Looking for memset
    -- Looking for memset - found
    -- Looking for memcpy
    -- Looking for memcpy - found
    -- Performing Test C_FLAG_Wall
    -- Performing Test C_FLAG_Wall - Success
    -- Performing Test C_FLAG_Winline
    -- Performing Test C_FLAG_Winline - Success
    -- Performing Test C_FLAG_W - Success
    -- Performing Test C_FLAG_Wformat_security
    -- Performing Test C_FLAG_Wformat_security - Success
    -- Performing Test C_FLAG_Wpointer_arith
    -- Performing Test C_FLAG_Wpointer_arith - Success
    -- Performing Test C_FLAG_Wdisabled_optimization
    -- Performing Test C_FLAG_Wdisabled_optimization - Success
    -- Performing Test C_FLAG_Wno_unknown_pragmas
    -- Performing Test C_FLAG_Wno_unknown_pragmas - Success
    -- Performing Test C_FLAG_Wdeclaration_after_statement
    -- Performing Test C_FLAG_Wdeclaration_after_statement - Success
    -- Performing Test C_FLAG_fstrict_aliasing
    -- Performing Test C_FLAG_fstrict_aliasing - Success
    -- Performing Test HAVE_LD_VERSION_SCRIPT
    -- Performing Test HAVE_LD_VERSION_SCRIPT - Success
    -- Looking for assert.h
    -- Looking for assert.h - found
    -- Looking for io.h
    -- Looking for io.h - not found
    -- Looking for search.h
    -- Looking for search.h - found
    -- Performing Test C_HAS_inline
    -- Performing Test C_HAS_inline - Success
    -- Performing Test TIME_WITH_SYS_TIME
    -- Performing Test TIME_WITH_SYS_TIME - Success
    -- Performing Test TM_IN_SYS_TIME
    -- Performing Test TM_IN_SYS_TIME - Success
    -- Check size of signed int
    -- Check size of signed int - done
    -- Check size of unsigned int
    -- Check size of unsigned int - done
    -- Check size of signed long
    -- Check size of signed long - done
    -- Check size of signed long long
    -- Check size of signed long long - done
    -- Check size of unsigned char *
    -- Check size of unsigned char * - done
    -- Check size of ptrdiff_t
    -- Check size of ptrdiff_t - done
    -- Looking for snprintf
    -- Looking for snprintf - found
    -- Looking for strcasecmp
    -- Looking for strcasecmp - found
    -- Found MPI_C: /usr/lib/openmpi/lib/libmpi.so
    -- Found MPI_CXX: /usr/lib/openmpi/lib/libmpi_cxx.so;/usr/lib/openmpi/lib/libmpi.so
    -- Protobuf: doing try-compiles for hash map/set headers
    -- Protobuf: doing try-compiles for pthread test
    CMake Error at CMake/ParaViewQt.cmake:71 (find_package):
      Could not find a configuration file for package "Qt5" that is compatible
      with requested version "5.6".
      The following configuration files were considered but not accepted:
        /usr/lib/x86_64-linux-gnu/cmake/Qt5/Qt5Config.cmake, version: 5.5.1
    Call Stack (most recent call first):
      Qt/Widgets/CMakeLists.txt:203 (pv_find_package_qt)
    -- Configuring incomplete, errors occurred!
    See also "/root/OpenFOAM/ThirdParty-v1806/build/linux64Gcc/ParaView-5.5.2/CMakeFiles/CMakeOutput.log".
    See also "/root/OpenFOAM/ThirdParty-v1806/build/linux64Gcc/ParaView-5.5.2/CMakeFiles/CMakeError.log".
    Samuel-Tu
    好像找到原因了,因为买的时候默认是linux 16.04的。我换了下系统,换到18.04好像可以了。。
    Samuel-Tu
    发现了新问题。我对初始边界使用了codeFixedValue,但是运行不了。提示我为了安全,不能以管理员身份运行某个共享的库。但是用阿里云ECS必须要登录自己的root啊。。现在卡在这里了。。。
    Samuel-Tu
    @Samuel-Tu 找到这个问题的解决办法了。实际上当申请一个实例后,阿里云给用户的是最高权限的账号,可以adduser建一个普通账户,见教程,然后通过普通账户安装OpenFOAM。这样我就成功用普通用户模式运行了root模式不能运行的OpenFOAM代码。
    @samuel-tu 还好看了老铁的帖子,准备买ECS的时候问了下销售,他已经去找技术那边确认核数了。这个vCPU确实有点误导人了,而且按照vCPU估算了下ECS的单价大概一毛多到两毛多一核时,还是很贵的,两毛的话超算上都可以用商业软件了。
    李东岳李 S 2 条回复 最后回复
    在 中回复了 cccrrryyy 最后由 李东岳 编辑
    买了一个月,9.6元 1核2G内存,40G云盘,装个OpenFOAM看看。这点钱也不贵,长期算点小模型
    1核2G内存忒少了。虽然跟不要钱一样。但是折腾的时间也是成本哟。
    Samuel-Tu
    @cccrrryyy 现在没用ECS了。。回课题组有电脑咯。。。感觉还是得找天河这类专业的超算来算东西。。
    @samuel-tu 是的,超算还是划算些。昨天跟阿里云销售确认了下,他们的vCPU除以2是物理核心数,按他的说法是ECS所有服务器都是这样的。
