  4. 用rhoPimpleFoam计算T型管冷热流混合,计算几步就停掉
21 帖子 5 发布者 28.0k 浏览
  • 希 离线
    希 离线
    希望先生
    各位老师,大家好,我在使用rhoPimpleFoam求解器计算一个T型管冷热空气掺混算例的时候,总是计算几步就停止掉了。之前从来没有计算过这种和热有关的算例,我感觉有可能是边界条件设置的问题,烦请有经验的老师给指导一下。
    这是T型管算例的大概示意图
    这是0/p文件:
    internalField   uniform 101325;
        INLET_HOT
            type            fixedValue;
            value           uniform 101550;
        INLET_COLD
            type            zeroGradient;
        OUTLET
            type            fixedValue;
            value           uniform 101350;
        WALL_HOT
            type            zeroGradient;
        WALL_MID
            type            zeroGradient;
    这是0/T文件:
    internalField   uniform 300;
        INLET_HOT
            type            fixedValue;
            value           uniform 1673.15;
        INLET_COLD
            type            fixedValue;
            value           uniform 438.15;
        OUTLET
            type            inletOutlet;
            inletValue      $internalField;
        WALL_HOT
            type            zeroGradient;
        WALL_MID
            type            zeroGradient;
    这是0/U文件:
        INLET_HOT
            type            pressureInletVelocity;
        INLET_COLD
        OUTLET
        WALL_HOT
            type            noSlip;
        WALL_MID
            type            noSlip;
    这是0/alphat文件:
    dimensions      [1 -1 -1 0 0 0 0];
    internalField   uniform 1e-3;
        INLET_HOT
            type            calculated;
        INLET_COLD
            type            calculated;
        OUTLET
            type            calculated;
        WALL_HOT
            type            compressible::alphatWallFunction;
        WALL_MID
    这是0/epsilon文件:
    dimensions      [0 2 -3 0 0 0 0];
    internalField   uniform 2.2667;
        INLET_HOT
            type            turbulentMixingLengthDissipationRateInlet;
            mixingLength    0.005;
            value           uniform 2.2667;
        INLET_COLD
            mixingLength    0.005;
        OUTLET
            type            inletOutlet;
            inletValue      uniform 2.2667;
        WALL_HOT
            type            epsilonWallFunction;
        WALL_MID
    这是0/k文件:
    internalField   uniform 0.054;
        INLET_HOT
            type            turbulentIntensityKineticEnergyInlet;
            intensity       0.05;
            value           uniform 0.054;
        INLET_COLD
            intensity       0.05;
        OUTLET
            type            inletOutlet;
            inletValue      uniform 0.054;
        WALL_HOT
        WALL_MID
    这是0/nut文件:
    internalField   uniform 0;
        INLET_HOT
            type            calculated;
            value           uniform 0;
        INLET_COLD
            type            calculated;
            value           uniform 0;
        OUTLET
            type            calculated;
            value           uniform 0;
        WALL_HOT
            value           uniform 0;
        WALL_MID
            value           uniform 0;
    这是constant/thermophysicalProperties文件:
    thermoType
        type            hePsiThermo;
        mixture         pureMixture;
        transport       sutherland;
        thermo          hConst;
        equationOfState perfectGas;
        specie          specie;
    mixture
        specie
            molWeight   28.9;
        thermodynamics
            Cp          1007;
            Hf          0;
        transport
            As          1.4792e-06;
            Ts          116;
    这是system/fvScheme文件:
    ddtSchemes
        default         Euler;
    gradSchemes
        default         Gauss linear;
    divSchemes
        default         none;
        div(phi,U)      Gauss upwind;
        div(phid,p)     Gauss upwind;
        div(phiv,p)     Gauss linear;
        div(phi,K)      Gauss linear;
        div(phi,e)      Gauss upwind;
        div(phi,k)      Gauss upwind;
        div(phi,epsilon) Gauss upwind;
        div(phi,R)      Gauss upwind;
        div(phi,omega)  Gauss upwind;
        div((rho*R))    Gauss linear;
        div(R)          Gauss linear;
        div(U)          Gauss linear;
    laplacianSchemes
    interpolationSchemes
        default         linear;
    snGradSchemes
        default         corrected;
    这是system/fvSolution文件:
    solvers
        p
            solver          PCG;
    	preconditioner
    		preconditioner  	GAMG;
    		tolerance       	1e-05;
    		relTol          	0;
    		smoother        	GaussSeidel;
    		cacheAgglomeration	true;
    	tolerance       1e-05;
            relTol          0.1;
        pFinal
    	solver          PCG;
    	preconditioner
    		tolerance               1e-06;
    		relTol                  0;
    	tolerance       1e-06;
    	relTol          0.1;
        "(rho|U|e|k|epsilon|omega)"
            solver          PBiCGStab;
            preconditioner  DILU;
            tolerance       1e-06;
            relTol          0;
        "(rho|U|e|k|epsilon|omega)Final"
            $U;
            relTol          0;
    PIMPLE
        momentumPredictor   yes;
        transonic           no;
        nOuterCorrectors    50;
        nCorrectors         1;
        nNonOrthogonalCorrectors 0;
        consistent          yes;
        SIMPLErho           yes;
        pMaxFactor          1.5;
        pMinFactor          0.9;
        residualControl
            "(U|k|epsilon)"
                relTol          0;
                tolerance       0.00001;
        turbOnFinalIterOnly no;
    relaxationFactors
        fields
            "p.*"           0.5;
            "rho.*"         1;
        equations
            "U.*"           0.9;
            "e.*"           0.7;
            "(k|epsilon|omega).*" 0.8;
    然后,这是运行rhoPimpleFoam时保存的log文件,看不出非常明显的报错信息:
    PIMPLE: iteration 25
    DILUPBiCGStab:  Solving for Ux, Initial residual = 0.188633, Final residual = 6.22293e-07, No Iterations 4
    DILUPBiCGStab:  Solving for Uy, Initial residual = 0.108362, Final residual = 3.91435e-07, No Iterations 4
    DILUPBiCGStab:  Solving for Uz, Initial residual = 0.36688, Final residual = 5.86313e-07, No Iterations 4
    DILUPBiCGStab:  Solving for e, Initial residual = 0.170771, Final residual = 1.74252e-07, No Iterations 3
    这是在集群上计算停止后保存的errput文件,不知道是否有用,先放上:136: :
    [[18352,1],4]: A high-performance Open MPI point-to-point messaging module
    was unable to find any relevant network interfaces:
    Module: OpenFabrics (openib)
      Host: c01n02
    Another transport will be used instead, although this may result in
    lower performance.
    NOTE: You can disable this warning by setting the MCA parameter
    btl_base_warn_component_unused to 0.
    [c01n02:275299] 31 more processes have sent help message help-mpi-btl-base.txt / btl:no-nics
    [c01n02:275299] Set MCA parameter "orte_base_help_aggregate" to 0 to see all help / error messages
    [16] #0  Foam::error::printStack(Foam::Ostream&)[15] #0  Foam::error::printStack(Foam::Ostream&) at ??:?
     at ??:?
    [15] #1  Foam::sigFpe::sigHandler(int)[16] #1  Foam::sigFpe::sigHandler(int) at ??:?
    [15] #2  ? at ??:?
    [16] #2  ? in /usr/lib64/libpthread.so.0
    [15] #3  Foam::hePsiThermo<Foam::psiThermo, Foam::pureMixture<Foam::sutherlandTransport<Foam::species::thermo<Foam::hConstThermo<Foam::perfectGas<Foam::specie> >, Foam::sensibleInternalEnergy> > > >::calculate(Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>&, bool) in /usr/lib64/libpthread.so.0
    [16] #3  Foam::hePsiThermo<Foam::psiThermo, Foam::pureMixture<Foam::sutherlandTransport<Foam::species::thermo<Foam::hConstThermo<Foam::perfectGas<Foam::specie> >, Foam::sensibleInternalEnergy> > > >::calculate(Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>&, bool) at ??:?
    [15] #4  Foam::hePsiThermo<Foam::psiThermo, Foam::pureMixture<Foam::sutherlandTransport<Foam::species::thermo<Foam::hConstThermo<Foam::perfectGas<Foam::specie> >, Foam::sensibleInternalEnergy> > > >::correct() at ??:?
    [16] #4  Foam::hePsiThermo<Foam::psiThermo, Foam::pureMixture<Foam::sutherlandTransport<Foam::species::thermo<Foam::hConstThermo<Foam::perfectGas<Foam::specie> >, Foam::sensibleInternalEnergy> > > >::correct() at ??:?
    [15] #5   at ??:?
    [16] #5  ?? at ??:?
    [15] #6  __libc_start_main at ??:?
    [16] #6  __libc_start_main in /usr/lib64/libc.so.6
    [15] #7   in /usr/lib64/libc.so.6
    [16] #7  ?? at ??:?
    [c01n02:275348:0:275348] Caught signal 8 (Floating point exception: tkill(2) or tgkill(2))
     at ??:?
    [c01n02:275349:0:275349] Caught signal 8 (Floating point exception: tkill(2) or tgkill(2))
    ==== backtrace ====
     0 0x000000000000f4ab raise()  ???:0
     1 0x000000000000f5e0 _L_unlock_13()  funlockfile.c:0
     2 0x00000000002addcf Foam::hePsiThermo<Foam::psiThermo, Foam::pureMixture<Foam::sutherlandTransport<Foam::species::thermo<Foam::hConstThermo<Foam::perfectGas<Foam::specie> >, Foam::sensibleInternalEnergy> > > >::calculate()  ???:0
     3 0x00000000002aea19 Foam::hePsiThermo<Foam::psiThermo, Foam::pureMixture<Foam::sutherlandTransport<Foam::species::thermo<Foam::hConstThermo<Foam::perfectGas<Foam::specie> >, Foam::sensibleInternalEnergy> > > >::correct()  ???:0
     4 0x00000000004255e6 main()  ???:0
     5 0x0000000000021c05 __libc_start_main()  ???:0
     6 0x000000000042d711 _start()  ???:0
    ==== backtrace ====
    mpirun noticed that process rank 16 with PID 0 on node c01n02 exited on signal 8 (Floating point exception).
    烦请有时间、有经验的老师给提一下建议:135:
    在 中回复了 希望先生 最后由 编辑
    @希望先生 网格数量多少?有对比的sci数据么?
    希 1 条回复 最后回复
  • 希 离线
    希 离线
    希望先生
    在 中回复了 李东岳 最后由 希望先生 编辑
    @李东岳 李老师,你好。我上面画的T型管的网格数量大概为360万。现在没有sci数据,原本是需要计算一个类似于T型管的掺合阀,那个掺合阀的模型比这个T型管要复杂的多。:135: 因为一直计算不下去,开始以为是掺合阀用的是非结构网格的原因,于是就先计算一个这样比较简单的T型管,划分了结构网格,试了一下还是计算不下去。现在感觉可能是边界条件的原因,或者是什么其他的原因。:136:
    在 中回复了 希望先生 最后由 编辑
    @希望先生 不太好判断哪里出问题。能把网格数量调节到几十万的话,我可以给你调试一下。
    希 1 条回复 最后回复
  • 希 离线
    希 离线
    希望先生
    @李东岳 李老师,你好。我已经将网格数量调到了77万,但是上传不到这上面来,我发送到您的邮箱里面去了,不知道符合不符合您的要求。:135:
    在 中回复了 希望先生 最后由 李东岳 编辑
    @希望先生 收到,我给你看一下。弄好了之后在论坛里给你连接。现在服务器在跑算例。估计得下周能给你
    希 1 条回复 最后回复
  • 希 离线
    希 离线
    希望先生
    @李东岳 :142: 感谢李老师,我不着急的
  • hurricane007H 离线
    hurricane007H 离线
    hurricane007
    我记得我有段时间算流化床,卡住的原因是连接处的网格问题,就像你这个小管子和大管子连接处,有没有做过渡啊。。。如果太尖锐了就可能卡住的。。。
    希 1 条回复 最后回复
    wangfei9088 大神
    写于 最后由 wangfei9088 编辑
    @希望先生 0/p中INLET_COLD为啥设置成zeroGradient?OUTLET的压力值也和图中不一样。
    这俩边界条件写反了?
    :134:
    INLET_HOT
        type            fixedValue;
    INLET_COLD
        type            zeroGradient;
    OUTLET
        type            fixedValue;
    希 1 条回复 最后回复
  • 希 离线
    希 离线
    希望先生
    在 中回复了 hurricane007 最后由 编辑
    @hurricane007 多谢老师提醒,我这里并没有特别地去做一些明显的过渡,我去试一下看能不能解决问题。:xiexie:
  • 希 离线
    希 离线
    希望先生
    在 中回复了 wangfei9088 最后由 编辑
    @wangfei9088 多谢老师提醒,这个地方确实是把INLET_COLD和OUTLET的边界条件写反了,我尝试改了过来,但是仍旧没有解决问题。:xinlei:
    zhouxu
    在 中回复了 希望先生 最后由 编辑
    试一下把压力入口边界换成速度入口边界
    这个算例是openfoam几的,我用openfoam78都运行不了
    希 2 条回复 最后回复
  • 希 离线
    希 离线
    希望先生
    @李东岳 李老师,不好意思,没有及时关注回复。我这个算例使用OpenFOAM-5.x,因为需要使用CFDEM,所以一直没有编译安装新版本的OpenFOAM。
  • 希 离线
    希 离线
    希望先生
    @李东岳 李老师,会不会还是网格的原因?有可能是我网格划分的有问题:xinlei:
    在 中回复了 希望先生 最后由 编辑
    @希望先生 你这个有对照实验值么,目前有一些结果出来,等下周我把算例更新在这里 http://dyfluid.com/rhoPimpleFoam.html
    希 1 条回复 最后回复
  • 希 离线
    希 离线
    希望先生
    @李东岳 感谢李老师:xiexie: ,但是没有T型管的试验数据。原本是要计算一个掺合阀的,原理类似于T型管,但是那个掺合阀模型比这个T型管要复杂很多,尤其在小口径管和大口径管结合的地方,那个模型一直计算不下去就画了个简单的T型管。这个T型管的边界条件,是我按照厂子里面测试掺合阀的实验条件放上的,如果按照他们的试验的话,热流进口是应该大概是在930-1600摄氏度范围内,冷流大概是160-170摄氏度,掺合阀调控的混合流出口温度大概在220-260摄氏度。李老师,厂子里面实验条件非常简陋,仅作小小参考:136: 只要结果不太一样,那就勇敢地相信是他们试验做得不对:tishizi:
    在 中回复了 希望先生 最后由 编辑
    @希望先生 你这个其实不需要这个小圆管,直接画一个大圆管,然后在侧面用topoSet做一个进口就行。这样网格数10万以下足够了。
    希 1 条回复 最后回复
  • 希 离线
    希 离线
    希望先生
    @李东岳 谢谢李老师提醒,我去尝试一下
    :haqi:
    希 1 条回复 最后回复
