  3. openfoam导入icem二维网格生成的cellzones文件里面为什么显示0个?
3 帖子 2 发布者 3.2k 浏览
  • 削 离线
    削 离线
    削铅笔
    使用fluntMeshtoFoam命令时,显示生成成功,但是polymesh文件夹里面的cellzones显示为0,还包括下图中的文件:
    icem中的part和cell的划分如下图:
    转换网格时终端显示的信息为:
    Create time
    Dimension of grid: 2
    Number of points: 182065
    Reading points
    Number of cells: 302646
    Other readCellGroupData: d 1 366c7 1 0
    Reading mixed cells
    Other readCellGroupData: e 366c8 455c8 1 0
    Reading mixed cells
    Other readCellGroupData: f 455c9 49e36 1 1
    Reading uniform cells
    number of faces: 484771
    Reading uniform faces
    Read zone1:13 name:YL patchTypeID:fluid
    Reading zone data
    Read zone1:14 name:WK patchTypeID:fluid
    Reading zone data
    Read zone1:15 name:JK patchTypeID:fluid
    Reading zone data
    Read zone1:16 name:int_YL patchTypeID:interior
    Reading zone data
    Read zone1:17 name:int_WK patchTypeID:interior
    Reading zone data
    Read zone1:18 name:int_JK patchTypeID:interior
    Reading zone data
    Read zone1:19 name:WALL_ITFC2 patchTypeID:wall
    Reading zone data
    Read zone1:20 name:WALL_ITFC1 patchTypeID:wall
    Reading zone data
    Read zone1:21 name:BLADE patchTypeID:wall
    Reading zone data
    Read zone1:22 name:WALL_ITFC22 patchTypeID:wall
    Reading zone data
    Read zone1:23 name:WALL_ITFC11 patchTypeID:wall
    Reading zone data
    Read zone1:24 name:INLET patchTypeID:velocity-inlet
    Reading zone data
    Read zone1:25 name:WALL_WK patchTypeID:wall
    Reading zone data
    Read zone1:26 name:OUTLET patchTypeID:outlet-vent
    Reading zone data
    FINISHED LEXING
    dimension of grid: 2
    Grid is 2-D. Extruding in z-direction by: 15.1284
    Creating shapes for 2-D cells
    Building patch-less mesh...--> FOAM Warning :
        From function Foam::polyMesh::polyMesh(const Foam::IOobject&, Foam::pointField&&, const cellShapeList&, const faceListList&, const wordList&, const wordList&, const Foam::word&, const Foam::word&, const wordList&, bool)
        in file meshes/polyMesh/polyMeshFromShapeMesh.C at line 595
        Found 618200 undefined faces in mesh; adding to default patch.
    done.
    Building boundary and internal patches.
    Creating patch 0 for zone: 16 start: 1 end: 350445 type: interior name: int_YL
    Creating patch 1 for zone: 17 start: 350446 end: 444302 type: interior name: int_WK
    Creating patch 2 for zone: 18 start: 444303 end: 471863 type: interior name: int_JK
    Creating patch 3 for zone: 19 start: 471864 end: 473971 type: wall name: WALL_ITFC2
    Creating patch 4 for zone: 20 start: 473972 end: 475730 type: wall name: WALL_ITFC1
    Creating patch 5 for zone: 21 start: 475731 end: 482930 type: wall name: BLADE
    Creating patch 6 for zone: 22 start: 482931 end: 483351 type: wall name: WALL_ITFC22
    Creating patch 7 for zone: 23 start: 483352 end: 483703 type: wall name: WALL_ITFC11
    Creating patch 8 for zone: 24 start: 483704 end: 483855 type: velocity-inlet name: INLET
    Creating patch 9 for zone: 25 start: 483856 end: 484704 type: wall name: WALL_WK
    Creating patch 10 for zone: 26 start: 484705 end: 484771 type: outlet-vent name: OUTLET
    Creating patch for front and back planes
    Patch int_YL is internal to the mesh  and is not being added to the boundary.
    Patch int_WK is internal to the mesh  and is not being added to the boundary.
    Patch int_JK is internal to the mesh  and is not being added to the boundary.
    Adding new patch WALL_ITFC2 of type wall as patch 0
    Adding new patch WALL_ITFC1 of type wall as patch 1
    Adding new patch BLADE of type wall as patch 2
    Adding new patch WALL_ITFC22 of type wall as patch 3
    Adding new patch WALL_ITFC11 of type wall as patch 4
    Adding new patch INLET of type patch as patch 5
    Adding new patch WALL_WK of type wall as patch 6
    Adding new patch OUTLET of type patch as patch 7
    Adding new patch frontAndBackPlanes of type empty as patch 8
    Writing mesh... to "constant/polyMesh"  done.
    End
    如果你要cellZone,你需要带参数-writeZones
    削 1 条回复 最后回复
  • 削 离线
    削 离线
    削铅笔
    @李东岳 谢谢李哥
