  3. 计算出现负相率和负湍动能
计算出现负相率和负湍动能
13 帖子 4 发布者 11.7k 浏览
    Caijinjin
    如图,是一个搅拌釜内的液固两相流,用的twoPhaseEulerFoam,计算过程中逐渐发散,出现了很多负值,请问这个可能是什么原因导致的?对网格进行了质量检查,网格为非结构网格,这个非正交性的值是偏大还是正常范围?
    fvSolution设置为:(为了不求解温度,我将h/e的迭代数设为0,是否对计算有影响?)
    solvers
        "alpha.*"
            nAlphaCorr      1;
            nAlphaSubCycles 2;
            smoothLimiter   0.1;
            implicitPhasePressure yes;
            solver          smoothSolver;
            tolerance       1e-9;
            relTol          0;
            minIter         1;
        p_rgh
            solver          GAMG;
            smoother        DIC;
            tolerance       1e-8;
            relTol          0;
        p_rghFinal
            $p_rgh;
            relTol          0;
        "U.*"
            tolerance       1e-5;
            relTol          0;
            minIter         1;
        "(h|e).*"
            // tolerance       1e-6;
            relTol          0;
            minIter         0;
            maxIter         0;
        "Theta.*"
            tolerance       1e-6;
            relTol          0;
            minIter         1;
        "(k|epsilon).*"
            tolerance       1e-5;
            relTol          0;
            minIter         1;
    PIMPLE
        nOuterCorrectors 3;
        nCorrectors      1;
        nNonOrthogonalCorrectors 0;
    relaxationFactors
        equations
            ".*"            1;
    希望各位大佬帮忙解答,感谢!
    Caijinjin
    另外附上我的离散格式,出现负值是否因为离散格式设置错误?未包含有界限制?
    ddtSchemes
        default     Euler;
    gradSchemes
        default     Gauss linear;
    divSchemes
        default                         none;
        "div\(phi,alpha.*\)"            Gauss vanLeer;
        "div\(phir,alpha.*\)"           Gauss vanLeer;
        "div\(alphaRhoPhi.*,U.*\)"      Gauss limitedLinearV 1;
        "div\(phi.*,U.*\)"              Gauss limitedLinearV 1;
        "div\(alphaRhoPhi.*,(h|e).*\)"  Gauss limitedLinear 1;
        "div\(alphaRhoPhi.*,K.*\)"      Gauss limitedLinear 1;
        "div\(alphaPhi.*,p\)"           Gauss limitedLinear 1;
        div(alphaRhoPhi.particles,Theta.particles) Gauss limitedLinear 1;
        "div\(alphaRhoPhi.*,(k|epsilon).*\)"  Gauss limitedLinear 1;
        div((((alpha.water*thermo:rho.water)*nuEff.water)*dev2(T(grad(U.water))))) Gauss linear;
        div((((thermo:rho.particles*nut.particles)*dev2(T(grad(U.particles))))+(((thermo:rho.particles*lambda.particles)*div(phi.particles))*I)))  Gauss linear;
    laplacianSchemes
        default     Gauss linear uncorrected;
        bounded     Gauss linear uncorrected;
    interpolationSchemes
        default     linear;
    snGradSchemes
        default     uncorrected;
        bounded     uncorrected;
    openfoam几,用新的openfoam比较好
    这个求解器对网格之类比较敏感,最好先上迎风格式
    Caijinjin
    @李东岳 用的of7,那请问我这个网格的非正交性算大还是正常,如果网格质量不好那使用reactingTwoPhaseEulerFoam来计算是否会网格的敏感性有所改善?还是用最新的of9里面的multiphaseEulerFoam会好一点?
    在 中回复了 Caijinjin 最后由 编辑
    @caijinjin multiphaseEulerFoam > reactingTwoPhaseEulerFoam > twoPhaseEulerFoam
    Caijinjin
    @李东岳 好的,谢谢东岳老师
    cyberk
    @caijinjin 您好,我也遇到了类似的问题 想问一下您解决了吗?
    负相率和负湍动能
    这个很难处理。一般只能调整设置。这是纯算法上带来的问题。
    cyberk
    @李东岳 李老师您好,除了上面提到1.更换结构网格 2.采用新版本的openfoam 之外,您说的调整设置具体是指fvscheme里的离散格式和fvsolution中的残差、矩阵求解器、残差等吗?您能给一个大概的调整方向的建议吗?我看到您之前发的帖子中有提到twoPhaseEulerFoam等pimple类算法的的亚松弛因子就算给1也会有保证矩阵对角占优,我观察pimple系列的求解器的tut中亚松弛因子也基本都是给的1,我如果降低亚松弛因子会有助于提高twoPhaseEulerFoam计算的稳定性吗?
  • 田畔的风田 离线
    田畔的风田 离线
    田畔的风 神
    写于 最后由 田畔的风 编辑
    离散格式用vanLeer01和linear01之类的格式可以把标量强制限制在0和1之间。
    Caijinjin
    在 中回复了 cyberk 最后由 编辑
    @cyberk 我这边是因为缺少了createBaffles字典,如果案例的几何边界中存在零厚度面就需要对其进行设置,我这边的搅拌釜的搅拌桨就是零厚度面
    cyberk
    @caijinjin 你好,请问你是用ICEM画的网格吗?我最近也在尝试用ICEM画搅拌槽的网格,可以看我之前的发帖记录。但是我画的网格在计算的时候搅拌桨面上的epsilon值存在一些问题,初步排查原因似乎是由于周向划分数量导致桨叶处第一层网格的y+过小或者过大?想问一下你遇到过这种情况吗?可以加微信交流一下吗?我的微信是wangyu1895
    Caijinjin
    @cyberk 抱歉,这个问题我没有遇到过,但我看了你之前用ICEM画的网格,这个六叶Ruston桨的搅拌槽的网格不太复杂的呀,这个你可以试试只画1/6个区域,然后对称过去,画完整体之后再去openfoam中用topoSet划分搅拌的区域
