  3. blockMesh划分网格,在v2112和v6均测试可以,v8报错
6 帖子 3 发布者 4.5k 浏览
  • 尚 在线
    尚 在线
    尚善若水
    请教一下大家,我用 of 的 blockMesh 划分一个带圆形喷孔几何体的六面体网格。blockMesh 在 v2112 和 v6 均测试可以运行,但是 v8 报错。我刚学习 of,自己没排查出错误,请教下大家。
    错误提示如下:
    Create time
    Creating block mesh from
        "system/blockMeshDict"
    Using #calcEntry at line 46 in file "/home/users/nus/e0944146/OpenFOAM/e0944146-8/run/JISCF/system/blockMeshDict"
    Using #codeStream with "/home/users/nus/e0944146/OpenFOAM/e0944146-8/run/JISCF/dynamicCode/platforms/linux64GccDPInt32Opt/lib/libcodeStream_b7af15ef665f94aa93a235a5e34750b6bd3e16a1.so"
    Invoking "wmake -s libso /home/users/nus/e0944146/OpenFOAM/e0944146-8/run/JISCF/dynamicCode/_b7af15ef665f94aa93a235a5e34750b6bd3e16a1"
    wmake libso /home/users/nus/e0944146/OpenFOAM/e0944146-8/run/JISCF/dynamicCode/_b7af15ef665f94aa93a235a5e34750b6bd3e16a1
        Ctoo: codeStreamTemplate.C
    /home/users/nus/e0944146/OpenFOAM/e0944146-8/run/JISCF/system/blockMeshDict: In function 'void Foam::codeStream_b7af15ef665f94aa93a235a5e34750b6bd3e16a1(Foam::Ostream&, const Foam::dictionary&)':
    /home/users/nus/e0944146/OpenFOAM/e0944146-8/run/JISCF/system/blockMeshDict:1:8: error: '$D' was not declared in this scope
    make: *** [Make/linux64GccDPInt32Opt/codeStreamTemplate.o] Error 1
    --> FOAM FATAL IO ERROR:
    Failed wmake "dynamicCode/_b7af15ef665f94aa93a235a5e34750b6bd3e16a1/platforms/linux64GccDPInt32Opt/lib/libcodeStream_b7af15ef665f94aa93a235a5e34750b6bd3e16a1.so"
    file: /home/users/nus/e0944146/OpenFOAM/e0944146-8/run/JISCF/system/blockMeshDict from line 17 to line 45.
        From function static void (* Foam::functionEntries::codeStream::getFunction(const Foam::dictionary&, const Foam::dictionary&))(Foam::Ostream&, const Foam::dictionary&)
        in file db/dictionary/functionEntries/codeStream/codeStream.C at line 214.
    FOAM exiting
    网格如下:
    测试文件 blockMesh.zip
    C 2 条回复 最后回复
    @尚善若水
    我用OpenFOAM-8试了下,提示‘$D’ was not declared,尝试找到$D,在后面加个空格,如下所示。
    alpha 45.0;                   // o-block degree
    // s     #calc "$D/4.0";         // Inner square side half
    // sc    #calc "$D/4.0 + 0.1";   // Inner square side curvature
    // R     #calc "$D/2.0";         // Radius of the jet nozzle
    s     #calc "$D /4.0";         // Inner square side half
    sc    #calc "$D /4.0 + 0.1";   // Inner square side curvature
    R     #calc "$D /2.0";         // Radius of the jet nozzle
    接着能运行一会,又出现error: ‘$lx’ was not declared,也是类似在后面加个空格,就可继续运行。
    // round 函数表示四舍五入取整数
    // xCells #calc "round($lx/$deltax)"; // 310
    // yCells #calc "round($ly/$deltay)"; // 110
    // zCells #calc "round($lz/$deltaz)"; // 200
    xCells #calc "round($lx /$deltax)"; // 310
    yCells #calc "round($ly /$deltay)"; // 110
    zCells #calc "round($lz /$deltaz)"; // 200
    以此方式后续还有好几个类似的参数都这个问题,当基本改完后,运行还是有如下错误。这块也不清楚什么问题了
        ln: ./lnInclude
        wmkdep: codeStreamTemplate.C
        ld: /home/user1/OpenFOAM/user1-8/run/blockmesh/dynamicCode/_d585a44b91ff1f499e2e3d99401445beaf8aa06c/../platforms/linux64GccDPInt32Opt/lib/libcodeStream_d585a44b91ff1f499e2e3d99401445beaf8aa06c.so
    Creating block edges
    No non-planar block faces defined
    Creating topology blocks
    wrong token type - expected int32_t, found on line 184 the doubleScalar 10
    file: /home/user1/OpenFOAM/user1-8/run/blockmesh/system/blockMeshDict/blocks at line 184.
        From function Foam::Istream& Foam::operator>>(Foam::Istream&, int32_t&)
        in file primitives/ints/int32/int32IO.C at line 62.
    FOAM exiting
    在 中回复了 尚善若水 最后由 编辑
    @尚善若水 刚再试了OpenFOAM-2012,可以运行没有任何报错。如果你需要用OpenFOAM-8计算,看是否可以用其他版本的先生成网格,然后再用OpenFOAM-8计算?
    在 中回复了 尚善若水 最后由 编辑
    @尚善若水 除了加空格,再把rsCells改为10,就可以在OpenFOAM-8 运行了。上面提示的错误是指划分网格数量应该是int类型数值
    //rsCells 10.0; // Number of cells between inner square and circle
    rsCells 10; // Number of cells between inner square and circle
    尚 1 条回复 最后回复
  • 尚 在线
    尚 在线
    尚善若水
    @coolhhh 厉害厉害,我就觉着是变量定义格式问题,但是自己不太懂。感谢~
