  3. Meshy
  4. ANSYS ICEM热键
ANSYS ICEM热键
2 帖子 2 发布者 5.6k 浏览
    Geometry:
    a: Merge Curves
    b: Build Topology
    d: Delete Entity
    g: Group Curves
    h: Home Position
    j: Solid/Wire Frame Shading
    p: Project Point to Curve
    s: Segment Curve
    x: Cancel any Selection
    z: Zoom In
    Shift-c: Create Surface
    Shift-i: Isometric View
    Shift-p: Project Point to Surface
    Shift-r: View Reverse
    Shift-x: YZ Plane View
    Shift-y: XZ Plane View
    Shift-z: XY Plane View
    Ctrl + c: Create Curve from Points
    Ctrl + d: Delete Entity Permanently
    Ctrl + g: Segment Curve by Points
    Ctrl + m: Copy/Move Entities
    Ctrl + p: Project Curve on Surface
    Ctrl+ s: Segment Surface by Curve
    Ctrl+y: Redo (For any operation)
    Ctrl+z: Undo (For any operation)
    F11: Emergency Reset
    F4: Emergency Reset
    F5: Set Wireframe Offset Display
    F6: Set Wireframe Offset Display to 0
    F7: Increase Wireframe Offset Display
    F8: Reduce Wireframe Offset Display
    Edit Mesh:
    a: Merge Nodes
    b: Repair Mesh
    d: Delete Elements
    e: Create Mesh from Edge
    m: Move Nodes
    p: Project Node to Curve
    q: Quality Matrices
    r: Remesh Elements
    s: Split Edge
    t: Convert Mesh Type
    v: Snap Project Nodes
    w: Swap Edge
    z: Zoom In
    shift-c: Create Element
    shift-d: Diagnostics
    shift-p: Project Nodes to Point
    Ctrl+a: Merge Node (interactive)
    Ctrl+m: Move Multiple Nodes
    Ctrl+p: Project Nodes to Surface
    Ctrl+q: Quality Histogram
    Ctrl+r: Remesh Bad Elements
    Ctrl+t: Convert Quad to Tri
    F4: Emergency Reset
    F6: Set Wireframe Offset to 0
    F7: Increase Wieframe Offset
    Enter: Apply
    Blocking:
    a: Merge Vertices
    e: Edit Edge
    f: Associate Face to Surface
    g: Group and Ungroup curves
    i: Index Control
    l: Align Vertices
    m: Move Vertices
    n: Pre-mesh Parameters
    o: Split O-grid
    p: Associate Edge to Curve
    q: Premesh Quality
    s: Split Block
    u: Update Size (Mesh Parameter)
    v: Snap Project Vertices
    shift-c: Create Block
    shift-i: Isometric View
    shift-l: Set Edge Length
    shift-n: Scale Size
    shift-p: Associate Vertex to Point
    Ctrl+s: Split Selected Edge
    F4: Emergency Reset
    Enter: Apply
    Selection Mode:
    0: Select All Node Elements
    1: Select All Line Elements
    2: Select All Shell Elements
    3. Select All Volume Elements
    a: Select All
    b: Select All Blanked
    Shift + c: Select by Circular Region
    d: Select by Diagonal Corners
    g: Set Feature Angle
    h: Toggle Highlighted
    i: Segment in Between
    k: Flood Fill One (Select Attached Layer)
    l: Flood Fill
    m: Toggle Region
    n: Go to Next by Name
    o: Toggle Boundary
    p: Polygon Parts
    r: Flood Fill to Curve (Select Attached until Curve)
    t: Select Attached to Geometry
    v: Select All Visible
    x: Cancel Selection Mode
    [: Undo Selection
    ]: Accept Selection
    Enter: Apply
    CFD中国标准用户测试帐号
    目前由徐笑笑登录
    random_ran 大神
    z 和 x 用得最顺。
    其他的还在熟悉中。
    Yours in CFD,
    Ran
