  4. 如何在src文件中创建标量物理filed并且调用
27 帖子 3 发布者 34.6k 浏览
  • chengan.wangC 离线
    chengan.wangC 离线
    chengan.wang
    @李东岳 李老师,又出现了之前的问题:
    lnInclude/ParticleCollector.C: In member function ‘virtual void Foam::ParticleCollector<CloudType>::postMove(Foam::ParticleCollector<CloudType>::parcelType&, Foam::label, Foam::scalar, const point&, bool&)’:
    lnInclude/ParticleCollector.C:750:31: error: ‘const volScalarField {aka const class Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>}’ has no member named ‘internalFieldRef’
             scalar& PPC = summass.internalFieldRef() [cellIp];
    我用grep查了一下,有些函数中用的是internalField()而查不到internalFieldRef(),但如果采用
    scalar& PPC = summass.internalField() [cellIp]
    错误如下
    lnInclude/ParticleCollector.C:750:53: error: binding ‘const double’ to reference of type ‘Foam::scalar& {aka double&}’ discards qualifiers
             scalar& PPC = summass.internalField()[cellIp];
    2.4版本太老了,我也忘了怎么用了,
    scalar PPC = summass.internalField() [cellIp]
    这个呢
    chengan.wangC 1 条回复 最后回复
  • chengan.wangC 离线
    chengan.wangC 离线
    chengan.wang
    @李东岳 编译倒是能通过了,但是运行算例log文件显示错误
    [12]
    [12]
    [12] --> FOAM FATAL ERROR:
    [12]
        request for volScalarField summass from objectRegistry region0 failed
        available objects of type volScalarField are
    19
    thermo:mu
    thermo:psi
    K
    h
    kappa
    air
    rho
    k
    Cp
    dpdt
    thermo:psi_0
    alphat
    dQ
    p
    T
    mut
    H2O
    epsilon
    thermo:alpha
    [12]
    [12]
    [12]     From function objectRegistry::lookupObject<Type>(const word&) const
    [12]     in file /home/chengan/OpenFOAM/OpenFOAM-2.4.0/src/OpenFOAM/lnInclude/objectRegistryTemplates.C at line 198.
    [12]
    应该是你summass这个代码还没创立的时候就寻找了。把这个代码提前几行
  • chengan.wangC 离线
    chengan.wangC 离线
    chengan.wang
    @李东岳 我把
    const volScalarField& summass = p.mesh().objectRegistry::lookupObject<volScalarField>("summass");
    挪到程序前面了,还是同样的错误:135:
    @chengan-wang 在 如何在src文件中创建标量物理filed并且调用 中说:
    "summass",
    runTime.timeName(),
    mesh,
    IOobject::NO_READ,
    IOobject::AUTO_WRITE
    mesh,
    把这个提前
  • chengan.wangC 离线
    chengan.wangC 离线
    chengan.wang
    @李东岳 李老师,按照下列代码
            const label cellIp = p.cell();
            scalar PPC = summass.internalField() [cellIp];
    编译通过了,也能算了,但是好像没有赋值进去,结果是0
        format      binary;
        class       volScalarField;
        location    "0.0002";
        object      summass;
    dimensions      [1 0 0 0 0 0 0];
    internalField   uniform 0;
        walls
            type            calculated;
            value           uniform 0;
    T 1 条回复 最后回复
  • T 离线
    T 离线
    Tens 神
    在 中回复了 chengan.wang 最后由 编辑
    这样只有PPC这个量在变,summass不跟着变。
    我感觉如果是在src库中进行调用和操作,还是应该在库中创建这个量
  • chengan.wangC 离线
    chengan.wangC 离线
    chengan.wang
    在 中回复了 Tens 最后由 编辑
    @tens 应该是这样的,感觉应该带个指针啥的
    scalar& PPC = summass.internalField().ref() [cellIp]
  • chengan.wangC 离线
    chengan.wangC 离线
    chengan.wang
    @李东岳 还是不行
    lnInclude/ParticleCollector.C:746:43: error: ‘const InternalField {aka const class Foam::Field<double>}’ has no member named ‘ref’
         scalar& PPC = summass.internalField().ref() [cellIp];
    你不声明PPC,直接用summass呢?
  • chengan.wangC 离线
    chengan.wangC 离线
    chengan.wang
    @李东岳 李老师,还是不行
        summass.internalField() [cellIp] += p.nParticle()*p.mass();
    编译出错
    lnInclude/ParticleCollector.C:749:38: error: assignment of read-only location ‘(&(& summass)->Foam::GeometricField<Type, PatchField, GeoMesh>::internalField<double, Foam::fvPatchField, Foam::volMesh>())->Foam::Field<double>::<anonymous>.Foam::List<double>::<anonymous>.Foam::UList<T>::operator[]<double>(((Foam::label)cellIp))’
    lnInclude/ParticleCollector.C: In instantiation of ‘void Foam::ParticleCollector<CloudType>::postMove(Foam::ParticleCollector<CloudType>::parcelType&, Foam::label, Foam::scalar, const point&, bool&) [with CloudType = Foam::KinematicCloud<Foam::Cloud<Foam::CollidingParcel<Foam::KinematicParcel<Foam::particle> > > >; Foam::ParticleCollector<CloudType>::parcelType = Foam::CollidingParcel<Foam::KinematicParcel<Foam::particle> >; Foam::label = int; Foam::scalar = double; Foam::point = Foam::Vector<double>]’:
    parcels/derived/basicKinematicCollidingParcel/makeBasicKinematicCollidingParcelSubmodels.C:53:1:   required from here
    volScalarField& summass = p.mesh().objectRegistry::lookupObjectRef<volScalarField>("summass");
  • chengan.wangC 离线
    chengan.wangC 离线
    chengan.wang
    @李东岳 李老师,这句命令
    又报错了
    lnInclude/ParticleCollector.C:745:71: error: ‘class Foam::objectRegistry’ has no member named ‘lookupObjectRef’
    2.4版本太老了,你试下这个
    volScalarField& summass = const_cast<voScalarField&>(p.mesh().objectRegistry::lookupObject<volScalarField>("summass"));
  • chengan.wangC 离线
    chengan.wangC 离线
    chengan.wang
    @李东岳 非常感谢李老师,终于搞定,能输出数据了,但还需要进一步验证是否正确。差点放弃想升级新版本of。
        volScalarField& summass = const_cast<volScalarField&>(p.mesh().objectRegistry::lookupObject<volScalarField>("summass"));
        scalar& PPC = summass.internalField() [cellIp];
    希望对以后需要的朋友有点借鉴作用。特别感谢 @星星星星晴 不厌其烦的解答:146:
