  4. 使用CodeFixedValue对非均匀速度场的编写
9 帖子 3 发布者 10.4k 浏览
    SHUKK
    大家好!我最近参考杨易老师2017年关于中性风场自保持的文献中的设置和KOmegaSST模型来用CodeFixedValue对inlet的U,k,OMEGA进行了编写,大概类似于中性大气环境湍流动能的自保持。 (https://cfd-china.com/topic/6231/中性大气环境湍流动能的自保持-附有算例下载)但是我在decomposePar进行并行运算时候出现问题,看看有没有大佬能帮忙解决。下面附带我u,k,omega的代码,看看是不是代码问题还是其他的地方有问题。谢谢!:135:
    decomposePar中出现的问题time=0时候
    -> FOAM Warning :
        From const Foam::HashTable<Foam::List<int> >& Foam::polyBoundaryMesh::groupPatchIDs() const
        in file meshes/polyMesh/polyBoundaryMesh/polyBoundaryMesh.C at line 510
        Removed patchGroup 'symmetry' which clashes with patch 2 of the same name.
    --> FOAM FATAL IO ERROR: (openfoam-2012)
    Cannot find patchField entry for symmetry
    file: /home/user3/SHUKK/monixuexi/313_RANS_lianxi/0/k.boundaryField at line 25 to 64.
        From void Foam::GeometricField<Type, PatchField, GeoMesh>::Boundary::readField(const Foam::DimensionedField<TypeR, GeoMesh>&, const Foam::dictionary&) [with Type = double; PatchField = Foam::fvPatchField; GeoMesh = Foam::volMesh]
        in file /home/user3/OpenFOAM/OpenFOAM-v2012/src/OpenFOAM/lnInclude/GeometricBoundaryField.C at line 172.
    FOAM exiting
    k
        format      ascii;
        class       volScalarField;
        object      k;
    internalField   uniform 1;
        inlet
            value           uniform 0.1; //default value
            name            kinlet; //name of new BC type
            code
                const fvPatch& boundaryPatch = this->patch();
                scalarField& vf = *this;
                forAll(vf, i)
                    scalar z = boundaryPatch.Cf()[i].y();
                    scalar D1 = -1.515;
                    scalar D2 = 7.463;
                    scalar alpha = 0.25;
                    vf[i] = sqrt(D1*pow(z, alpha) + D2);
        upperwall
            type            symmetry;
        lowerwall
            value           uniform 0.375;
        outlet
            type            zeroGradient;
        building
    U
        inlet
            value           uniform (0 0 0); //default value
            name            uinlet; //name of new BC type
            code
                vectorField& vf = *this;
                forAll(vf, i)
                    //scalar uStar = 0.511;
                    //scalar z0 = 2.25e-4;
                    //scalar kappa = 0.42;
                    //vf[i].x() = uStar/kappa*log((z + z0)/z0);
                    //vf[i].y() = 0.0;
                    //vf[i].z() = 0.0;
                    scalar ur = 11.0;
                    scalar zr = 0.40;
                    vf[i].x() = ur*pow(z/zr, alpha);
                    vf[i].y() = 0.0;
                    vf[i].z() = 0.0;
                operator==(vf)
        outlet
            type            zeroGradient;
        upperWall
            type            symmetry;
        lowerWall
            type            noSlip;
        symmetry
            type            symmetry;
        building
            type          fixedValue;
    omega
       inlet
            name            omegainlet; //name of new BC type
            code
                forAll(vf, i)
                    //scalar kappa = 0.4;
                    //scalar C1 = -0.17;
                    //scalar C2 = 1.62;
                    //scalar Cmu = 0.42;
                    //vf[i] = uStar/(z +z0)/kappa/sqrt(Cmu);
                    scalar ur = 11.0;
                    scalar Cmu = 0.08;
                    scalar zr = 0.4;
                    scalar u = ur*pow(z/zr, alpha);
                    vf[i] = (alpha/sqrt(Cmu))*u/z;
        outlet
            type            zeroGradient;
        upperWall
            type            symmetry;
        lowerWall
        symmetry
            type            symmetry;
        building
    我那个算例好像没有添加symmetry类型。这个是你自己加的么。
    SHUKK
    @李东岳 对的,我是看杨易老师依照2017年的文献来设置的实操文献里面,计算域的左右和顶部都是symmetry,还有按照杨易老师设置无法保证自保持。 :135: f3f1ae1c-0d9c-407a-b6dc-1bab494475f3-_72()ML{XXP2SHNW}2SQ$Q4.png
    在 中回复了 SHUKK 最后由 编辑
    @SHUKK 这个里面有算例,你直接下载,allrun就可以
    https://www.cfd-china.com/topic/6231/中性大气环境湍流动能的自保持-附有算例下载/24
    S 2 条回复 最后回复
    SHUKK
    @李东岳 好的,谢谢李老师!我去试试,看看有没有问题。:chouchou:
    SHUKK
    @李东岳 李老师,我刚刚试了最新的算例。发现还是有这个问题,我也检查了我边界是不是没有一一对应的问题。:136:
    wangfei9088 大神
    在 中回复了 SHUKK 最后由 编辑
    @SHUKK 在 使用CodeFixedValue对非均匀速度场的编写 中说:
    看这意思是patch名和type名重名了呀,看下面这个。。。
    symmetry
        type            symmetry;
    SHUKK
    在 中回复了 wangfei9088 最后由 编辑
    @wangfei9088 这个以前用LES我没留意到,我现在就发现是我k里面忘记加左右壁面的,我重新做一个网格看看:146:
    SHUKK
    按照李东岳老师的case修改即可完成本项工作。:huahua:
