twoPhaseMixture类中添加muf()函数报错求助
求助大佬,为了在compressibleInterFoam求解器中添加有效粘度muEff
surfaceScalarField muEff ( "muEff", mixture.muf() + fvc::interpolate(rho*turbulence->nut()) );需要定义muf()函数,mixture是twoPhaseMixtureThermo类型,在对应的H文件和C文件进行更改
virtual tmp<surfaceScalarField> muf() const; //muf()声明 Foam::tmp<Foam::surfaceScalarField> Foam::twoPhaseMixtureThermo::muf() const //muf()定义 { const surfaceScalarField alpha1f ( min(max(fvc::interpolate(alpha1_), scalar(0)), scalar(1)) ); return tmp<surfaceScalarField> ( new surfaceScalarField ( "muf", alpha1f*(thermo1_->rho())*fvc::interpolate(nuModel1_->nu()) + (scalar(1) - alpha1f)*(thermo2_->rho())*fvc::interpolate(nuModel2_->nu()) ) ); }编译时主要报这些错误
该如何解决?为什么类似的代码在incompressibleTwoPhaseMixture中可以编译?/home/dell/OpenFOAM/OpenFOAM-4.x/src/OpenFOAM/lnInclude/GeometricField.H:99:40: error: invalid use of incomplete type ‘class Foam::surfaceMesh’ typedef typename GeoMesh::Mesh Mesh; /home/dell/OpenFOAM/OpenFOAM-4.x/src/OpenFOAM/lnInclude/GeometricField.H:103:48: error: invalid use of incomplete type ‘class Foam::surfaceMesh’ typedef typename GeoMesh::BoundaryMesh BoundaryMesh; twoPhaseMixtureThermo.C:83:17: error: ‘fvc’ has not been declared min(max(fvc::interpolate(alpha1_), scalar(0)), scalar(1)) -
感谢回答,尝试添加了fvc.H, 只报错以下内容
/home/dell/OpenFOAM/OpenFOAM-4.x/src/finiteVolume/lnInclude/cyclicAMIFvPatch.H:39:10: fatal error: cyclicAMILduInterface.H: 没有那个文件或目录 #include "cyclicAMILduInterface.H" ^~~~~~~~~~~~~~~~~~~~~~~~~不懂在哪里用到了cyclicAMILduInterface.H,先不管,它在src/meshTools路径下,在options里面添加路径,但是编译后又回到了一开始的报错
twoPhaseMixtureThermo.C:94:9: error: no matching function for call to ‘Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh>::GeometricField(const char [4], Foam::tmp<Foam::Field<double> >)’ ) -
@Miss-Zhou_DUT 您好,请问您解决这个问题了嘛
