84 帖子 18 发布者 202.9k 浏览
    在 中回复了 xiezhuoyu 最后由 编辑
    @xiezhuoyu 你训练的场,比如温度场压力场
    这是一个顶盖驱动流动的PINN代码。写了一天,最开始的版本植入的是守恒的形式,边界条件除了顶盖都给的零梯度,导致导数特别多。
    下面这个版本我还植入的非守恒形式,然后边界条件都变成了固定值0。不过结果还是不太对。做个记录吧。整了一天这个导数
    :136:
    我目前怀疑边界的导数应该也是从mesh计算,而不能单独计算边界的导数。这需要大改。
    #include <torch/torch.h>
    using namespace std;
    class NN
        public torch::nn::Module
        torch::nn::Sequential net_;
    public:
        NN()
            net_ = register_module
                "net",
                    torch::nn::Linear(2,20),
                    torch::nn::Tanh(),
                    torch::nn::Linear(20,20),
                    torch::nn::Tanh(),
                    torch::nn::Tanh(),
                    torch::nn::Tanh(),
                    torch::nn::Linear(20,3)
        auto forward(torch::Tensor x)
            return net_->forward(x);
    int main()
        torch::manual_seed(30);
        int iter = 1;
        int IterationNum = 200;
        auto crit = torch::nn::MSELoss();
        auto model = std::make_shared<NN>();
        auto adam = std::make_shared<torch::optim::Adam>(model->parameters());
        // Computational domain
        double dx = 0.2;
        double dy = 0.2;
        auto x = torch::arange(0, 1 + dx, dx);
        auto y = torch::arange(10, 11 + dy, dy);
        auto mesh =
            torch::stack(torch::meshgrid({x, y})).reshape({2, -1}).transpose(0, 1);
        mesh.requires_grad_(true);
        auto leftWall =
            torch::stack
                torch::meshgrid({x.index({0}), y})
        auto rightWall =
            torch::stack
                torch::meshgrid({x.index({-1}), y})
        auto bottom =
            torch::stack
                torch::meshgrid({x, y.index({0})})
        bottom.requires_grad_(true);
        auto top =
            torch::stack
                torch::meshgrid({x, y.index({-1})})
        top.requires_grad_(true);
        auto fixedWalls = torch::cat({leftWall, rightWall, bottom});
        auto u_top = torch::full({x.size(0)}, 1.0);
        auto v_top = torch::full({x.size(0)}, 0.0);
        //cout<< "mesh = \n" << mesh << endl;
        //cout<< "leftWall = \n" << leftWall << endl;
        //cout<< "rightWall = \n" << rightWall << endl;
        //cout<< "bottom = \n" << bottom << endl;
        //cout<< "top = \n" << top << endl;
        //cout<< "fixedWalls = \n" << fixedWalls << endl;
        // Iteration
        for (int i = 0; i < IterationNum; i++)
            adam->zero_grad();
            // Top boundary
            auto top_pred = model->forward(top);
            auto u_top_pred = top_pred.index({torch::indexing::Slice(), 0});
            auto v_top_pred = top_pred.index({torch::indexing::Slice(), 1});
            auto p_top_pred = top_pred.index({torch::indexing::Slice(), 2});
            auto loss_top =
                crit(v_top_pred, v_top) + crit(u_top_pred, u_top);
            auto dpdTop =
                torch::autograd::grad
                    {p_top_pred},
                    {top},
                    {torch::ones_like(p_top_pred)},
                    true,
                    true
                )[0];
            auto dpdyTop = dpdTop.index({torch::indexing::Slice(), 1});
            loss_top += crit(dpdyTop, torch::zeros({dpdyTop.size(0)}));
            //cout << "loss_top\n" << loss_top << endl;
            // Bottom boundary
            auto bot_pred = model->forward(bottom);
            auto u_bot_pred = bot_pred.index({torch::indexing::Slice(), 0});
            auto v_bot_pred = bot_pred.index({torch::indexing::Slice(), 1});
            auto p_bot_pred = bot_pred.index({torch::indexing::Slice(), 2});
            auto dpdBot =
                    {p_bot_pred},
                    {bottom},
                    {torch::ones_like(p_bot_pred)},
                    true,
                    true
                )[0];
            auto dpdyBot = dpdBot.index({torch::indexing::Slice(), 1});
            auto loss_bot = crit(dpdyBot, torch::zeros({dpdyBot.size(0)}))
              + crit(u_bot_pred, torch::zeros({dpdyBot.size(0)}))
              + crit(v_bot_pred, torch::zeros({dpdyBot.size(0)}));
            // Field
            auto UP = model->forward(mesh);
            auto u_pred = UP.index({torch::indexing::Slice(), 0});
            auto v_pred = UP.index({torch::indexing::Slice(), 1});
            auto p_pred = UP.index({torch::indexing::Slice(), 2});
            auto dpdMesh =
                    {p_pred},
                    {mesh},
                    {torch::ones_like(u_pred)},
                    true,
                    true
                )[0];
            auto dpdx = dpdMesh.index({torch::indexing::Slice(), 0});
            auto dpdy = dpdMesh.index({torch::indexing::Slice(), 1});
            auto dudMesh =
                    {u_pred},
                    {mesh},
                    true,
                    true
                )[0];
            auto dudx = dudMesh.index({torch::indexing::Slice(), 0});
            auto dudy = dudMesh.index({torch::indexing::Slice(), 1});
            auto dudxMesh =
                    {dudx},
                    {mesh},
                    true,
                    true
                )[0];
            auto dudyMesh =
                    {dudy},
                    {mesh},
                    true,
                    true
                )[0];
            auto dudxx = dudxMesh.index({torch::indexing::Slice(), 0});
            auto dudyy = dudyMesh.index({torch::indexing::Slice(), 1});
            //cout << "dudxx\n" << dudxx << endl;
            auto dvdMesh =
                    {v_pred},
                    {mesh},
                    true,
                    true
                )[0];
            auto dvdx = dvdMesh.index({torch::indexing::Slice(), 0});
            auto dvdy = dvdMesh.index({torch::indexing::Slice(), 1});
            auto dvdxMesh =
                    {dvdx},
                    {mesh},
                    true,
                    true
                )[0];
            auto dvdyMesh =
                    {dvdy},
                    {mesh},
                    true,
                    true
                )[0];
            auto dvdxx = dvdxMesh.index({torch::indexing::Slice(), 0});
            auto dvdyy = dvdyMesh.index({torch::indexing::Slice(), 1});
            auto loss_cont = crit(dudx, -dvdy);
            auto loss_mom1 = crit(u_pred*dudx + v_pred*dudy - 0.001*(dudxx + dudyy), -dpdx);
            auto loss_mom2 = crit(u_pred*dvdx + v_pred*dvdy - 0.001*(dvdxx + dvdyy), -dpdy);
            auto loss_pde = loss_cont + loss_mom1 + loss_mom2;
            //cout<< "loss_cont\n" << loss_cont << endl;
            //cout<< "loss_mom1\n" << loss_mom1 << endl;
            //cout<< "loss_mom2\n" << loss_mom2 << endl;
            //cout<< "loss_pde\n" << loss_pde << endl;
            // leftWall and rightWall
            auto dpdxLeft = dpdx.index({torch::indexing::Slice(0, 6)});
            auto u_pred_left = u_pred.index({torch::indexing::Slice(0, 6)});
            auto v_pred_left = v_pred.index({torch::indexing::Slice(0, 6)});
            auto dpdxRight = dpdx.index({torch::indexing::Slice(-6, torch::indexing::None)});
            auto u_pred_right = u_pred.index({torch::indexing::Slice(-6, torch::indexing::None)});
            auto v_pred_right = v_pred.index({torch::indexing::Slice(-6, torch::indexing::None)});
            auto loss_leftRight = crit(u_pred_left, torch::zeros({6}))
              + crit(v_pred_left, torch::zeros({6}))
              + crit(dpdxLeft, torch::zeros({6}))
              + crit(v_pred_right, torch::zeros({6}))
              + crit(u_pred_right, torch::zeros({6}))
              + crit(dpdxRight, torch::zeros({6}));
            //cout<< "loss_leftRight\n" << loss_leftRight << endl;
            auto loss = loss_top + loss_bot + loss_leftRight + loss_pde;
            //cout<< "loss\n" << loss << endl;
            loss.backward();
            adam->step();
            std::cout << iter << " " << loss.item<double>() << std::endl;
            iter++;
        model->eval();//neglect
        auto results = model->forward(mesh);
        cout << "results\n" << results << endl;
        return 0;
    都是在OpeNFOAM环境下,左边是我的PINN算的,下面是OpenFOAM自带的simpleFoam算的。:135: :135:
  • T 离线
    T 离线
    tiankai
    @xiezhuoyu 我是小白,想要请教一下,怎么才能运行呢:135:
    xiezhuoyuX 1 条回复 最后回复
  • xiezhuoyuX 离线
    xiezhuoyuX 离线
    xiezhuoyu
    在 中回复了 tiankai 最后由 编辑
    @tiankai
    1. 查看/修改OpenFOAM执行wmake时采用的Gcc版本,OpenFOAM/wmake/rules/General/Gcc/c++
      CC          = g++$(COMPILER_VERSION) -std=c++14
    2. pytorch官网下载libtorch
      2.3.0版本依赖C++17
      2.0.0版本依赖C++14
      1.10.0版本依赖C++14
    3. 修改/home/***/.bashrc,设置环境变量
      export LD_LIBRARY_PATH=/home/***/OpenFOAM/libtorch/lib:$LD_LIBRARY_PATH
    4. wmake你的库(比如李老师贴的代码)PINNFoam
    5. 最后调用PINNFoam
    T 1 条回复 最后回复
  • T 离线
    T 离线
    tiankai
    @xiezhuoyu 多谢回复,我查看了g++版本,确实是14,而且我已经成功编译了libtorch库,但是在编译一维对流方程时报错了
    提示指针变量有错误
  • xiezhuoyuX 离线
    xiezhuoyuX 离线
    xiezhuoyu
    @tiankai 看不出来什么问题?问问李老师@李东岳 :papa:
    我已经成功编译了libtorch库
    @tiankai 我这个路子不需要编译libtorch。 你看楼上总结那个也不需要编译。我这面没有编译。就跟OpenFOAM安装一样。OpenFOAM可以直接下载装(apt install那种),也可以编译安装。你不要编译,你按照我1楼的方法用现成的,跟openfoam捆绑起来能跑起来。回头再研究编译libtorch
    T 1 条回复 最后回复
  • T 离线
    T 离线
    tiankai
    @李东岳 在 OpenFOAM外挂libtorch 中说:
    我已经成功编译了libtorch库
    不好意思李老师,是我没有表述清楚,我是将libtorch解压了,用wmake了torchFoam,添加了路径。输入torchFoam,输出了上文中一样的信息,这表明libtorch库挂载成功了。
    所以我想要运行PiNNFoam的代码,需要创建一个制作make文件夹,然后将PiNNFoam(一维对流方程),net.h,net.H添加到PiNNFoam的文件夹下,然后使用wmake文件夹PiNNFoam,最后调用PiNNFoam即可吧。现在使用wmake执行PiNNFoam报错了图中内容
    你测试我顶盖驱动流那个。net那个是我用来测试外挂库的。估计你没有挂net的库。net这个还要编译成库挂上去才行。
    或者你直接把net.H net.C全部复制到对流那个.C的main之前也行
    T 1 条回复 最后回复
    顶盖驱动流那个debug出问题了。因为数据点,比如左上角那个,同时被包含在了left边界以及top边界,但是这俩边界的边界条件不一样,导致loss下不去。debug一天。。。
    更新,妥了,搞出来了
  • T 离线
    T 离线
    tiankai
    @李东岳 多谢李老师,已经解决。之前出错是因为错把net.H文件也添加到了main文件中,类Class NN 重复定义了。
    我植入了PINN+TVD格式。把震荡去掉了。下图圆点:原始PINN,实线:PINN+TVD
    耦合的ODE系统。这个不加监督点训练不了。加了监督点效果很好。:136:
  • 迟 离线
    迟 离线
    迟铁
    大家记得在第5步之后source一下,不然会报找不到动态库的问题T T(貌似只有我忘记了)
    OpenFoam/ CFX/ ansys/ hypermesh/ python
    @迟铁 感谢,已更新。
  • leaonL 离线
    leaonL 离线
    leaon
    @李东岳 老师好,
    您这个代码的第二、三行,“argList.H”,“solver.H”涉及的这两个文件,
    • 是需要自己编写?
    • 还是去simpleFoam里面找这两个文件呢?
    CFD是个什么鬼?!
    在 中回复了 leaon 最后由 编辑
    #36
    @leaon openfoam自带的,openfoam-11
    leaonL 1 条回复 最后回复
    @迟铁 我试了一下,不需要加v,我估计你那面你自己搞啥东西搞错了。帖子我一会删除了,怕引起误导。
    class NN:
    public:
        NN()
                "net",
                    torch::nn::Linear(9, 10),
                    torch::nn::ReLU(),
                    torch::nn::Linear(10, 1)
        torch::Tensor forward(torch::Tensor x)
    int main()
        torch::nn::MSELoss crit;
        NN model;
        auto input = torch::empty({6, 1, 9});
        #include "data.H"
        torch::optim::Adam adam(model.parameters(), torch::optim::AdamOptions(0.001));
        for (int epoch = 0; epoch < 5000; epoch++)
            auto outputF = model.forward(input);
            auto target = torch::empty_like(outputF);
            #include "target.H"
            auto loss = crit(outputF, target);
            adam.zero_grad();
            loss.backward();
            adam.step();
            if ((epoch + 1) % 100 == 0)
                cout << "Loss: " << loss.item<float>() << endl;
        auto test = torch::empty({2, 1, 9}); // batch, channel, sequence length
        #include "test.H"
        auto output = model.forward(test);
        std::cout<< output << endl;
        return 0;
    更新非常简单的一个可以用来识别流场是否存在间断的代码框架
  • leaonL 离线
    leaonL 离线
    leaon
    #39
    @李东岳 老师,好!
    还是有很多不明白的地方,多谢您的解答。
    • 为了在编译的时候能找到“argList.H”,“solver.H”这两个文件,我查找了这个文件的位置,并在options文件里面指定了这两个文件的位置。 :
    EXE_INC = \
     -I$(LIB_SRC)/optimisation/adjointOptimisation/adjoint/lnInclude \
     -I$(LIB_SRC)/OpenFOAM/lnInclude \
     -I$(LIB_SRC)/OpenFOAM/include \
    EXE_LIBS = \
        -libadjointOptimisation \
        -libOpenFOAM \
    • 此外,从icoFoam solver 里面粘贴了一个createFields.H文件,但继续编译的时候,又出现了新的错误。这个**“simplifiedMeshes”和"fvc"的错误改如何解决**呀?请李老师指点一下。
    • 最后,我有一个疑问,您这个代码如何与求解器建立关系呢?它对所有的求解器都是通用的么?
    CFD是个什么鬼?!
