  3. 拉格朗日求解器合并块问题
拉格朗日求解器合并块问题
4 帖子 3 发布者 2.4k 浏览
  • Y 在线
    Y 在线
    youhaoyu
    拉格朗日DPMFoam求解器使用过程中,我并行结束后合并不了块,出现以下代码
    Create time
    Reconstructing fields for mesh region0
    Time = 0.5
    Reconstructing FV fields
        Reconstructing volScalarField::DimensionedInternalFields
            kinematicCloud:UCoeff
        Reconstructing volVectorField::DimensionedInternalFields
            kinematicCloud:UTrans
        Reconstructing volScalarFields
            k.air
            mu.air
            alpha.air
            epsilon.air
            nut.air
            p
            rho.air
        Reconstructing volVectorFields
            U.air
        Reconstructing surfaceScalarFields
            phi.air
    Reconstructing point fields
    No point fields
    Reconstructing lagrangian fields for cloud kinematicCloud
    --> FOAM FATAL ERROR:
        cell, tetFace and tetPt search failure at position (0.855908 3.37988 -0.0348682)
        for requested cell 78838
        If this is a restart or reconstruction/decomposition etc. it is likely that the write precision is not sufficient.
        Either increase 'writePrecision' or set 'writeFormat' to 'binary'
        From function void Foam::particle::initCellFacePt()
        in file /home/zly/OpenFOAM/OpenFOAM-3.0.0/src/lagrangian/basic/lnInclude/particleI.H at line 735.
    FOAM aborting
    #2  Foam::reconstructLagrangianPositions(Foam::polyMesh const&, Foam::word const&, Foam::PtrList<Foam::fvMesh> const&, Foam::PtrList<Foam::IOList<int> > const&, Foam::PtrList<Foam::IOList<int> > const&) at ??:?
    #3  ? at ??:?
    #4  __libc_start_main in "/lib64/libc.so.6"
    #5  ? at ??:?
    Aborted (core dumped
    然后当我想mpirun -np继续运行时候,他就运行不了了,出现以下报错
    Create time
    Create mesh for time = 7
    PIMPLE: Operating solver in PISO mode
    Reading g
    Reading field U
    Reading field p
    Reading/calculating continuous-phase face flux field phic
    Creating turbulence model
    Creating field alphac
    Constructing kinematicCloud kinematicCloud
    Constructing particle forces
        Selecting particle force ErgunWenYuDrag
        Selecting particle force gravity
    Constructing cloud functions
        none
    Constructing particle injection models
    Creating injector: model1
    Selecting injection model patchInjection
        Constructing 3-D injection
        Choosing nParticle to be a fixed value, massTotal variable now does not determine anything.
    [6]
    [6]
    [6] --> FOAM FATAL ERROR:
    [6]     cell, tetFace and tetPt search failure at position (0.856587 3.37816 -0.0300663)
    [6]
    [6]     From function void Foam::particle::initCellFacePt()
    [6]     in file /home/zly/OpenFOAM/OpenFOAM-3.0.0/src/lagrangian/basic/lnInclude/particleI.H at line 735.
    [6]
    FOAM parallel run aborting
    [6]
    [6] #0  Foam::error::printStack(Foam::Ostream&) at ??:?
    [6] #1  Foam::error::abort() at ??:?
    [6] #2  ? at ??:?
    [6] #3  ? at ??:?
    [6] #4  ? at ??:?
    [6] #5  ? at ??:?
    [6] #6  ? at ??:?
    [6] #7  __libc_start_main in "/lib64/libc.so.6"
    [6] #8  ? at ??:?
    MPI_ABORT was invoked on rank 6 in communicator MPI_COMM_WORLD
    with errorcode 1.
    NOTE: invoking MPI_ABORT causes Open MPI to kill all MPI processes.
    You may or may not see output from other processes, depending on
    exactly when Open MPI kills them.
    ^Cmpirun: abort is already in progress...hit ctrl-c again to forcibly terminate
    我认为主要报错原因是这一段话
    但是我不理解他意思,是指的这个时间段颗粒在分块的交界线上,所以产生报错现象吗???我感觉of不会出现这种问题把。那出现这种问题有什么补办法么,难道只有修改decomposePar个数,或者把网格画粗一点重新计算么?有没有什么方法能够让他合并成功?
    主要为我问题一个是我合并不了块,无法看拉格朗日项,第二个问题是我无法继续进行计算(因为我中途暂停了只是想看一下流场是什么样子的。我能合并流场的块,不能合并拉格朗日项的块很难受)。
    recontructPar
    reconstructParMesh
    轮流用用,换换顺序用用。试试
  • T 离线
    T 离线
    Tens 神
    看看controlDict文件
    他不是建议了吗,你试试看这两种方法行不行
  • Y 在线
    Y 在线
    youhaoyu
    在 中回复了 Tens 最后由 编辑
    @Tens 都试了不行,减少并行块数量有点用,但是偶尔也犯病,这玩意我现在看玄学了
