  3. Algorithm
  4. 动量方程中viscous term的离散,书里写的有点问题?
7 帖子 2 发布者 10.4k 浏览
  • V 离线
    V 离线
    Voynich
    《The finite volume in computational fluid dynamics》中,$\nabla\mathbf v$写成
    \begin{equation}
    \nabla \mathbf{v} = \left[
    \begin{matrix}
    \frac{\partial u}{\partial x} & \frac{\partial v}{\partial x} & \frac{\partial w}{\partial x}\\
    \frac{\partial u}{\partial y} & \frac{\partial v}{\partial y} & \frac{\partial w}{\partial y} \\
    \frac{\partial u}{\partial z} & \frac{\partial v}{\partial z} & \frac{\partial w}{\partial z}\\
    \end{matrix}
    \right]
    在书中15.5.1节对SIMPLE的推导中,把$\nabla\cdot\{\mu\nabla\mathbf v\}$作为扩散项离散,把$\nabla\cdot\{\mu(\nabla\mathbf v)^\top\}$作为源项处理,是不是弄反了?
    $\bfU$和$\bfU^T$是存在这个问题。CFD里面一般就是你写的方程1的形式。参考《笔记》2.5节
    V 1 条回复 最后回复
  • V 离线
    V 离线
    Voynich
    在 中回复了 李东岳 最后由 Voynich 编辑
    问题可能在这儿,Moukalled书p589这两个式子有问题,应该像下面这样写:
    \begin{equation}
    \int_\limits{V_C}\nabla\cdot\{\mu(\nabla\mathbf{v})^\top\}dV=\sum_\limits{f\sim nb(C)}\mathbf{S}_f\cdot\{\mu(\nabla\mathbf{v})_f^\top\}
    \begin{equation}
    \mathbf{S}_f\cdot\{\mu(\nabla\mathbf{v})^\top_f\} = \left[
    \begin{matrix}
    \frac{\partial u}{\partial x}S_f^x + \frac{\partial v}{\partial x}S_f^y + \frac{\partial w}{\partial x}S_f^z\\
    \frac{\partial u}{\partial y}S_f^x + \frac{\partial v}{\partial y}S_f^y + \frac{\partial w}{\partial y}S_f^z \\
    \frac{\partial u}{\partial z}S_f^x + \frac{\partial v}{\partial z}S_f^y + \frac{\partial w}{\partial z}S_f^z\\
    \end{matrix}
    \right]
    就是说,把$\nabla\cdot\{\mu\nabla\mathbf v\}$作为diffusion,把$\nabla\cdot\{\mu(\nabla\mathbf v)^\top\}$作为source处理是对的。diffusion term用高斯定理积分后应该是
    \begin{equation}
    \int_\limits{V_C}\nabla\cdot\{\mu(\nabla\mathbf{v})\}dV=\sum_\limits{f\sim nb(C)}\mathbf{S}_f\cdot\{\mu(\nabla\mathbf{v})\}
    \begin{equation}
    \mathbf{S}_f\cdot\{\mu(\nabla\mathbf{v})\} = \left[
    \begin{matrix}
    \frac{\partial u}{\partial x}S_f^x + \frac{\partial u}{\partial y}S_f^y + \frac{\partial u}{\partial z}S_f^z\\
    \frac{\partial v}{\partial x}S_f^x + \frac{\partial v}{\partial y}S_f^y + \frac{\partial v}{\partial z}S_f^z \\
    \frac{\partial w}{\partial x}S_f^x + \frac{\partial w}{\partial y}S_f^y + \frac{\partial w}{\partial z}S_f^z\\
    \end{matrix}
    \right]
    $\nabla\cdot\{\mu\nabla\mathbf v\}$和(5)的第$i$分量分别和Ferziger的Computational Method for Fluid Dynamics p185式(7.8)的微分形式和积分形式一致。
    其中
    \begin{equation}
    \nabla u_i\cdot\mathbf ndS=\frac{\partial u_i}{\partial x}S_f^x + \frac{\partial u_i}{\partial y}S_f^y + \frac{\partial u_i}{\partial z}S_f^z
    总结,$\nabla\cdot\{\mu\nabla\mathbf v\}$是扩散项没问题,可以应用中心差分等数值格式计算。Moukalled书p589的式(15.65)张量形式的高斯定理写错了,$\mathbf{a}\cdot\{\tau\}$写成了$\{\tau\}\cdot\mathbf{a}$,式(15.66)展开成分量也就跟着错了。麻烦大佬看看我理解的对不对?
    这排版太流弊了。
    不过为什么写成方程2,3? 你的方程3如果继续做散度,无法消去,正常可以用连续性方程消去等于0。
    我觉得你的高斯定律应该写反了。我觉得你可能$\nabla\bfU$这一块就反了。最开始用一个反的,到后面只能每一步都需要用反的才能对上。
    你那个方程6是$\nabla\bfU\cdot\bfS$么?第一行应该是$u_xS_x + v_xS_y + w_xS_z$. 方程2 3 4 5应该也是反了。
    V 1 条回复 最后回复
  • V 离线
    V 离线
    Voynich
    @李东岳 感谢大佬回复,我说的可能有点乱,核心问题就是,$\nabla\cdot\{\tau\}$拆成两部分:
    \begin{equation}
    \begin{aligned}
    &\int_\limits{V_C}\nabla\cdot\{\tau\}dV\\
    =&\int_\limits{V_C}\nabla\cdot\{\mu\nabla\mathbf v\}dV+\int_\limits{V_C}\nabla\cdot\{\mu(\nabla\mathbf v)^\top\}dV\\
    =&\sum\limits_f\Box\cdot\mathbf{S}_f+\sum\limits_f\Box\cdot\mathbf{S}_f
    \end{aligned}
    不管$\Box$里面是分子布局还是分母布局,反正可以得到下面两项:
    \begin{equation}
    \sum\limits_f\Box\cdot\mathbf{S}_f=\sum\limits_f\left[
    \begin{matrix}
    \end{matrix}
    \right]
    \begin{equation}
    \begin{matrix}
    \end{matrix}
    \right]
    应该是前面一个,式(8)作为diffusion处理,对每个分量都有$\nabla\phi\cdot\mathbf S_f=\frac{\phi_F-\phi_C}{d_{CF}}S_f$(正交网格)。是这样吗?
    你的方程8写的对。是。你最后一个帖子是对的。
    你这排版太流弊了。我都没你写得好..
    V 1 条回复 最后回复
  • V 离线
    V 离线
    Voynich
    @李东岳 明白了,谢谢李老师。排版排了好久,清楚一点方便讨论:papa:
