  3. foam-extend-4.0 动网格未按照预期进行强迫运动
12 帖子 2 发布者 4.4k 浏览
  • G 离线
    G 离线
    Gunther
    左侧为入口,右侧为出口;前一个圆柱在y方向做正弦运动,后一个圆柱固定。
    dynamicMeshDict代码如下:
    dynamicFvMesh      dynamicMotionSolverFvMesh;
    motionSolverLibs ("libfvMotionSolver.so");
    solver            displacementLaplacian;
    //solver            velocityLaplacian;
    diffusivity       inverseDistance (cylinder1);
    0/pointDisplacement代码如下:
    dimensions      [0 1 0 0 0 0 0];
        frontAndBack
            type            empty;
        cylinder2
             type            fixedValue;
        cylinder1
            type            oscillatingDisplacement;
            amplitude		(0 -1 0);
            omega			3.14;
        topAndBottom
             type            symmetryPlane;
        outlet
             type            fixedValue;
        inlet
             type            fixedValue;
    0/U代码如下:
    internalField   uniform (1 0 0);
        frontAndBack
            type            empty;
        cylinder2
            type            fixedValue;
        cylinder1
            type            movingWallVelocity;
        topAndBottom
            type            symmetryPlane;
        outlet
            type            zeroGradient;
        inlet
            type            fixedValue;
    现在出现的问题是,圆柱根本不动,以下是终端的输出结果:
    Volume: new = 19.8431 old = 19.8431 change = 0 ratio = 0
    Courant Number mean: 0.00403834 max: 0.0257354 velocity magnitude: 1.3391
    Time = 3.052
    GAMG:  Solving for cellDisplacementx, Initial residual = 0, Final residual = 0, No Iterations 0
    GAMG:  Solving for cellDisplacementy, Initial residual = 9.0384e-06, Final residual = 9.0384e-06, No Iterations 0
    volume continuity errors : volume = 19.8431, max error = 2.21646e-12, sum local = 2.26977e-19, global = -4.50435e-20
    BiCGStab:  Solving for Ux, Initial residual = 3.66548e-05, Final residual = 6.20396e-14, No Iterations 1
    BiCGStab:  Solving for Uy, Initial residual = 0.000136469, Final residual = 3.21293e-13, No Iterations 1
    DICPCG:  Solving for p, Initial residual = 0.000114889, Final residual = 5.46747e-06, No Iterations 10
    time step continuity errors : sum local = 1.36508e-11, global = 4.94412e-13, cumulative = 1.47017e-06
    DICPCG:  Solving for p, Initial residual = 9.3308e-06, Final residual = 9.74749e-07, No Iterations 18
    time step continuity errors : sum local = 2.43382e-12, global = 4.80079e-13, cumulative = 1.47017e-06
    ExecutionTime = 149.77 s  ClockTime = 149 s
    麻烦各位大佬支支招!提前拜谢!
  • G 离线
    G 离线
    Gunther
    在cfd-online找到相关的问题,说是程序安装的事,但是我改用dyfluid的虚拟机运行此算例,圆柱依旧无法运动。但是我确实看不出来哪里设置出现问题。
    Dear Foamers,
    I am trying to run the default wingMotion tutorial using sixDoFRigidBodyDisplacement in foam-extend 4.0.
    However, it seems to me that the body is only moving at the very first time step and then all motion ends.
    There is also no output regarding information about restraints, centre of mass etc. in the log file.
    I ran the tutorial in OpenFOAM 5.0 without a problem but can not get it to run in foam-extend 4.0.
    Any ideas? Thanks in advance.
    After some more tries I found that pimpleDyMFoam only moves the body at the first time step and then all movement is stopped.
    This is the same for sixDoFRigidBodyDisplacement or oscillatingDisplacement.
    edit: I somehow messed the installation up. pimpleFoam worked excellent so I did not consider this first but after reinstallation the problem ist solved.
    ps:我同时运行了教程自带的wingMotion sixDoFRigidBodyDisplacement算例,机翼也未发生运动。
    我的虚拟机的什么版本的自带算例?
    G 1 条回复 最后回复
  • G 离线
    G 离线
    Gunther
    @李东岳 李老师您好!我说的是虚拟机fe40自带的tutorial,我运行后发现还是有问题。网格不动。
    你在别的机器上测试过没有,动么
    G 1 条回复 最后回复
  • G 离线
    G 离线
    Gunther
    @李东岳 目前还没有在别的机器测试过,主要不确定是自己代码的原因还是向cfd-online所说是软件安装的问题。
    麻烦您方便的时候看一下我贴出的代码有问题么,感谢感谢!我去找其他机器看看能不能动。
    G 1 条回复 最后回复
  • G 离线
    G 离线
    Gunther
    在 中回复了 Gunther 最后由 编辑
    @Gunther 在 foam-extend-4.0 动网格未按照预期进行强迫运动 中说:
    我换到其他机器也不能动,终端输出结果与贴出内容相同。
  • G 离线
    G 离线
    Gunther
    如图所示,第一个时间步网格会出现些许运动,之后就停止了。
    我以为我那个虚拟机的有bug。
    看起来这个是foam-extend的bug。源代码的bug了。
    .org版本不能实现这个么?
    G 1 条回复 最后回复
  • G 离线
    G 离线
    Gunther
    @李东岳 我要用到基于fe40的fsiFoam。这么说我的代码没有问题么?
    没问题
    G 1 条回复 最后回复
  • G 离线
    G 离线
    Gunther
    @李东岳 麻了,哭。。。我多么希望是我自己的问题
