  2. CFD彩虹条
  3. 香港城市大学Takashi Hibiki课题组诚招气液两相流CFD博后
已定时 已固定 已锁定 已移动 CFD彩虹条
11 帖子 2 发布者 3.2k 浏览
  • 大 离线
    大 离线
    大黄大黄
    Hong Kong Jockey Club STEM Laboratory of Innovative Thermo-Fluid Science at the City University of Hong Kong is seeking postdocs and research scientists who conduct innovative two-phase flow research under the supervision of Professor Takashi Hibiki. Applicants shall demonstrate their research experience of gas-liquid two-phase flow or relevant fields and excellent communication skills in English.
    The ongoing research projects at JC STEM Lab require expertise in two-phase flow CFD analysis. The introductory information can be found in the following papers.
     Sharma, S. L., Ishii, M., Hibiki, T., Schlegel, J. P., Liu, Y., Buchanan Jr, J. R., Beyond bubbly two-phase flow investigation using a CFD three-field two-fluid model, International Journal of Multiphase Flow 113 (2014) 1-15.
     Chuang, T., J., Hibiki, T., Interfacial forces used in two-phase flow numerical simulation, International Journal of Heat and Mass Transfer 113 (2017) 741-754.
    Applications will be accepted on a rolling basis, and candidates will be considered until the positions are filled. All applicants shall submit a curriculum vitae and a research statement highlighting past and current research experience. If you are interested in
    performing the research under the direction of Prof. Hibiki, please email to: thibiki@cityu.edu.hk.
    2024-10-02
    Takashi Hibiki教授的主页:
    https://www.cityu.edu.hk/mne/node/1326
    https://scholar.google.com.hk/ci ... AAAAJ&hl=en
    Hibiki教授在中国核能热工水力领域的认可度颇高,和清华、上交、西交、中科院、华南理工、华中科大、重庆大学都有学术交流,下面是关于Hibiki教授一些新闻报道:
    https://www.ares.tsinghua.edu.cn/news.aspx?key=28
    http://epe.xjtu.edu.cn/info/1101/16065.htm
    岗位年薪在35至50万港币之间,取决于教授项目资金的期限。面试的时候,教授会跟你讨论工资的相关情况。
    在香港城大Hibiki课题组对论文发表以及申请国自然基金有很大的加成,非常有利于青椒博后到副教授的过渡。
    目前计划招聘两相流CFD相关的一名博后,从事双流体界面力模型(升力、壁面润滑力和湍流分散力)的研究。课题组已经采购正版Fluent、CFX软件。
    有意向的话可以直接邮件Takashi Hibiki教授(thibiki@cityu.edu.hk),也可添加我的微信进一步咨询(17702145710,大黄)。
    2024年10月02日
  • 大 离线
    大 离线
    大黄大黄
    Postdoctoral and Research Scientist Position Opening.pdf
  • 大 离线
    大 离线
    大黄大黄
    该招聘信息目前依旧有效(2024-10-27)
  • 大 离线
    大 离线
    大黄大黄
    该招聘信息目前依旧有效(2024-11-24)
    之前发布招聘,有人发简历没
    http://dyfluid.com/index.html
    按照道理来说,大佬那面应该很好找啊,
    大 1 条回复 最后回复
  • 大 离线
    大 离线
    大黄大黄
    @李东岳 李老师您好。收到不少简历,申请人的成果也很好,但研究方向都不是很相符。所以,还是决定再等等。
    那倒是,有可能。好
  • 大 离线
    大 离线
    大黄大黄
    该招聘信息目前依旧有效(2024-12-09)
    你需要的话我可以在CFD界重新给你发一下。
    不过研究方向不符合的话可能还会发生。
  • 大 离线
    大 离线
    大黄大黄
    如果能在CFD界重新发一下,那真是再好不过了。万分感谢李老师。
