  3. foam-extend4.1并行分块无法使用scotch
4 帖子 2 发布者 927 浏览
  • 杜 离线
    杜 离线
    杜浚平
    在Ubuntu20.04按照教程安装完foam-extend-4.1后尝试并行计算时出现问题:
    | \\      /  F ield         | foam-extend: Open Source CFD                    |
    |  \\    /   O peration     | Version:     4.1                                |
    |   \\  /    A nd           | Web:         http://www.foam-extend.org         |
    |    \\/     M anipulation  | For copyright notice see file Copyright         |
    Build  : 4.1-70b064d0f326
    Exec   : decomposePar
    Date   : Dec 14 2024
    Time   : 16:52:09
    Host   : "ad"
    PID    : 216409
    CtrlDict : "/home/ad/foam/ad-4.1/run/qianyuan/case1/line2/20241209/try/21.6/system/controlDict"
    Case   : /home/ad/foam/ad-4.1/run/qianyuan/case1/line2/20241209/try/21.6
    nProcs : 1
    allowSystemOperations : Disallowing user-supplied system call operations
    Create time
    --> FOAM Warning :
        From function void* Foam::dlOpen(const Foam::fileName&, bool)
        in file POSIX.C at line 1204
        dlopen error : /home/ad/foam/ad-4.1/lib/linux64GccDPInt32Opt/libvorticityTurbulence.so: undefined symbol: _ZNK4Foam14incompressible9RASModels10kOmegaSSTV10divDevReffEv
    --> FOAM Warning :
        From function bool Foam::dlLibraryTable::open(const Foam::fileName&, bool)
        in file db/dynamicLibrary/dlLibraryTable/dlLibraryTable.C at line 97
        could not load "libvorticityTurbulence.so"
    Time = 63000
    Create mesh for region region0
    Calculating distribution of cells
    --> FOAM Warning :
        dlopen error : libscotchDecomp.so: cannot open shared object file: No such file or directory
    --> FOAM Warning :
        could not load "libscotchDecomp.so"
    --> FOAM Warning :
        From function decompositionMethod::loadExternalLibraries()
        in file decompositionMethod/decompositionMethod.C at line 520
        Loading of decomposition library libscotchDecomp.so unsuccesful. Some decomposition methods may not be  available
    --> FOAM Warning :
        dlopen error : libmetisDecomp.so: cannot open shared object file: No such file or directory
    --> FOAM Warning :
        could not load "libmetisDecomp.so"
    --> FOAM Warning :
        Loading of decomposition library libmetisDecomp.so unsuccesful. Some decomposition methods may not be  available
    --> FOAM Warning :
        dlopen error : libparMetisDecomp.so: cannot open shared object file: No such file or directory
    --> FOAM Warning :
        could not load "libparMetisDecomp.so"
    --> FOAM Warning :
        Loading of decomposition library libparMetisDecomp.so unsuccesful. Some decomposition methods may not be  available
    Selecting decompositionMethod scotch
    --> FOAM FATAL ERROR:
    Unknown decompositionMethod scotch
    Valid decompositionMethods are :
    4
    hierarchical
    manual
    patchConstrained
    simple
        From function decompositionMethod::New(const dictionary& decompositionDict, const polyMesh& mesh)
        in file decompositionMethod/decompositionMethod.C at line 496.
    FOAM exiting
    请问各位大佬有没有遇见过类似问题,我该如何解决?
  • 杜 离线
    杜 离线
    杜浚平
    貌似是因为自定义了湍流模型后,挂库出现了问题?
  • 杜 离线
    杜 离线
    杜浚平
    对fe41自身算力damBreak使用simple进行分块,也会出现同样的warning:
    Exec   : decomposePar
    Date   : Dec 14 2024
    Time   : 20:51:03
    Host   : "ad"
    PID    : 222209
    CtrlDict : "/home/ad/foam/ad-4.1/run/damBreak/system/controlDict"
    Case   : /home/ad/foam/ad-4.1/run/damBreak
    nProcs : 1
    Create time
    Time = 0
    --> FOAM Warning :
    --> FOAM Warning :
    --> FOAM Warning :
    --> FOAM Warning :
    --> FOAM Warning :
    --> FOAM Warning :
    --> FOAM Warning :
    --> FOAM Warning :
    --> FOAM Warning :
    Selecting decompositionMethod simple
    Finished decomposition in 0 s
    Constructing processor meshes
    Processor 0
        Number of cells = 575
        Number of faces shared with processor 1 = 26
        Number of faces shared with processor 2 = 24
        Number of processor patches = 2
        Number of processor faces = 50
        Number of boundary faces = 1198
    Processor 1
        Number of cells = 559
        Number of faces shared with processor 0 = 26
        Number of faces shared with processor 3 = 23
        Number of processor faces = 49
        Number of boundary faces = 1183
    Processor 2
        Number of faces shared with processor 0 = 24
        Number of faces shared with processor 3 = 25
        Number of boundary faces = 1165
    Processor 3
        Number of faces shared with processor 2 = 25
        Number of faces shared with processor 1 = 23
        Number of processor faces = 48
    Number of processor faces = 98
    Max number of processor patches = 2
    Max number of faces between processors = 50
    Processor 0: field transfer
    Processor 1: field transfer
    Processor 2: field transfer
    Processor 3: field transfer
    End.
    :135:
    scotch没装上 重装scotch
    http://dyfluid.com/index.html
