  4. paraview安装好了但无法使用
paraview安装好了但无法使用
14 帖子 6 发布者 14.0k 浏览
    RolandLent
    你在什么环境下编译的,我看报错像是你的qt有问题,paraview用的qt的框架,如果没有qt肯定没办法呼出对应的gui的
    楼上说的是对的。如果是ubuntu系统应该没问题。如果是cent,需要装qt
    yyyy
    谢谢两位老师的回答,我的是ubuntu20.04.6LTS,qt应该是有的,我又根据网上的教程查了查,发现还是无法打开,具体如下:qmake --version后显示
    QMake version 3.1
    Using Qt version 5.12.8 in /usr/lib/x86_64-linux-gnu
    export QT_DEBUG_PLUGINS=1后还是报错
    Got keys from plugin meta data ("xcb")
    QFactoryLoader::QFactoryLoader() checking directory path "/home/yl/OpenFOAM/v2206/ThirdParty-v2206/platforms/linux64Gcc/ParaView-5.10.1/bin/platforms" ...
    loaded library "/usr/lib/x86_64-linux-gnu/qt5/plugins/platforms/libqxcb.so"
    qt.qpa.xcb: could not connect to display
    qt.qpa.plugin: Could not load the Qt platform plugin "xcb" in "" even though it was found.
    This application failed to start because no Qt platform plugin could be initialized. Reinstalling the application may fix this problem.
    Available platform plugins are: eglfs, linuxfb, minimal, minimalegl, offscreen, vnc, xcb.
    Aborted
    然后又查了依赖
     ldd /usr/lib/x86_64-linux-gnu/qt5/plugins/platforms/libqxcb.so
    显示
      linux-vdso.so.1 (0x00007ffdc1e72000)
            libQt5XcbQpa.so.5 => /lib/x86_64-linux-gnu/libQt5XcbQpa.so.5 (0x00007f8ff53f7000)
            libQt5Gui.so.5 => /lib/x86_64-linux-gnu/libQt5Gui.so.5 (0x00007f8ff4e0c000)
            libQt5Core.so.5 => /lib/x86_64-linux-gnu/libQt5Core.so.5 (0x00007f8ff48c3000)
            libstdc++.so.6 => /lib/x86_64-linux-gnu/libstdc++.so.6 (0x00007f8ff46e1000)
            libc.so.6 => /lib/x86_64-linux-gnu/libc.so.6 (0x00007f8ff44ed000)
            libfontconfig.so.1 => /lib/x86_64-linux-gnu/libfontconfig.so.1 (0x00007f8ff44a6000)
            libfreetype.so.6 => /lib/x86_64-linux-gnu/libfreetype.so.6 (0x00007f8ff43e7000)
            libQt5DBus.so.5 => /lib/x86_64-linux-gnu/libQt5DBus.so.5 (0x00007f8ff434b000)
            libpthread.so.0 => /lib/x86_64-linux-gnu/libpthread.so.0 (0x00007f8ff4328000)
            libX11-xcb.so.1 => /lib/x86_64-linux-gnu/libX11-xcb.so.1 (0x00007f8ff4323000)
            libxcb-xinput.so.0 => /lib/x86_64-linux-gnu/libxcb-xinput.so.0 (0x00007f8ff42fd000)
            libxcb-icccm.so.4 => /lib/x86_64-linux-gnu/libxcb-icccm.so.4 (0x00007f8ff42f6000)
            libxcb-image.so.0 => /lib/x86_64-linux-gnu/libxcb-image.so.0 (0x00007f8ff40f1000)
            libxcb-shm.so.0 => /lib/x86_64-linux-gnu/libxcb-shm.so.0 (0x00007f8ff40ec000)
            libxcb-keysyms.so.1 => /lib/x86_64-linux-gnu/libxcb-keysyms.so.1 (0x00007f8ff40e7000)
            libxcb-randr.so.0 => /lib/x86_64-linux-gnu/libxcb-randr.so.0 (0x00007f8ff40d4000)
            libxcb-render-util.so.0 => /lib/x86_64-linux-gnu/libxcb-render-util.so.0 (0x00007f8ff40cb000)
            libxcb-render.so.0 => /lib/x86_64-linux-gnu/libxcb-render.so.0 (0x00007f8ff40bc000)
            libxcb-shape.so.0 => /lib/x86_64-linux-gnu/libxcb-shape.so.0 (0x00007f8ff40b7000)
            libxcb-sync.so.1 => /lib/x86_64-linux-gnu/libxcb-sync.so.1 (0x00007f8ff40ad000)
            libxcb-xfixes.so.0 => /lib/x86_64-linux-gnu/libxcb-xfixes.so.0 (0x00007f8ff40a3000)
            libxcb-xinerama.so.0 => /lib/x86_64-linux-gnu/libxcb-xinerama.so.0 (0x00007f8ff409e000)
            libxcb-xkb.so.1 => /lib/x86_64-linux-gnu/libxcb-xkb.so.1 (0x00007f8ff407e000)
            libxcb.so.1 => /lib/x86_64-linux-gnu/libxcb.so.1 (0x00007f8ff4054000)
            libXrender.so.1 => /lib/x86_64-linux-gnu/libXrender.so.1 (0x00007f8ff3e4a000)
            libX11.so.6 => /lib/x86_64-linux-gnu/libX11.so.6 (0x00007f8ff3d0d000)
            libm.so.6 => /lib/x86_64-linux-gnu/libm.so.6 (0x00007f8ff3bbe000)
            libSM.so.6 => /lib/x86_64-linux-gnu/libSM.so.6 (0x00007f8ff3bb3000)
            libICE.so.6 => /lib/x86_64-linux-gnu/libICE.so.6 (0x00007f8ff3b93000)
            libxkbcommon-x11.so.0 => /lib/x86_64-linux-gnu/libxkbcommon-x11.so.0 (0x00007f8ff3b88000)
            libxkbcommon.so.0 => /lib/x86_64-linux-gnu/libxkbcommon.so.0 (0x00007f8ff3b46000)
            libglib-2.0.so.0 => /lib/x86_64-linux-gnu/libglib-2.0.so.0 (0x00007f8ff3a1c000)
            libgcc_s.so.1 => /lib/x86_64-linux-gnu/libgcc_s.so.1 (0x00007f8ff3a01000)
            libGL.so.1 => /lib/x86_64-linux-gnu/libGL.so.1 (0x00007f8ff3977000)
            libpng16.so.16 => /lib/x86_64-linux-gnu/libpng16.so.16 (0x00007f8ff393f000)
            libz.so.1 => /lib/x86_64-linux-gnu/libz.so.1 (0x00007f8ff3923000)
            libharfbuzz.so.0 => /lib/x86_64-linux-gnu/libharfbuzz.so.0 (0x00007f8ff381f000)
            libicui18n.so.66 => /lib/x86_64-linux-gnu/libicui18n.so.66 (0x00007f8ff3520000)
            libicuuc.so.66 => /lib/x86_64-linux-gnu/libicuuc.so.66 (0x00007f8ff333a000)
            libdl.so.2 => /lib/x86_64-linux-gnu/libdl.so.2 (0x00007f8ff3332000)
            libpcre2-16.so.0 => /lib/x86_64-linux-gnu/libpcre2-16.so.0 (0x00007f8ff32ae000)
            libdouble-conversion.so.3 => /lib/x86_64-linux-gnu/libdouble-conversion.so.3 (0x00007f8ff3298000)
            /lib64/ld-linux-x86-64.so.2 (0x00007f8ff55a9000)
            libexpat.so.1 => /lib/x86_64-linux-gnu/libexpat.so.1 (0x00007f8ff326a000)
            libuuid.so.1 => /lib/x86_64-linux-gnu/libuuid.so.1 (0x00007f8ff3261000)
            libdbus-1.so.3 => /lib/x86_64-linux-gnu/libdbus-1.so.3 (0x00007f8ff320e000)
            libxcb-util.so.1 => /lib/x86_64-linux-gnu/libxcb-util.so.1 (0x00007f8ff3008000)
            libXau.so.6 => /lib/x86_64-linux-gnu/libXau.so.6 (0x00007f8ff3002000)
            libXdmcp.so.6 => /lib/x86_64-linux-gnu/libXdmcp.so.6 (0x00007f8ff2ffa000)
            libbsd.so.0 => /lib/x86_64-linux-gnu/libbsd.so.0 (0x00007f8ff2fe0000)
            libpcre.so.3 => /lib/x86_64-linux-gnu/libpcre.so.3 (0x00007f8ff2f6b000)
            libGLdispatch.so.0 => /lib/x86_64-linux-gnu/libGLdispatch.so.0 (0x00007f8ff2eb3000)
            libGLX.so.0 => /lib/x86_64-linux-gnu/libGLX.so.0 (0x00007f8ff2e7f000)
            libgraphite2.so.3 => /lib/x86_64-linux-gnu/libgraphite2.so.3 (0x00007f8ff2e52000)
            libicudata.so.66 => /lib/x86_64-linux-gnu/libicudata.so.66 (0x00007f8ff1391000)
            libsystemd.so.0 => /lib/x86_64-linux-gnu/libsystemd.so.0 (0x00007f8ff12e0000)
            librt.so.1 => /lib/x86_64-linux-gnu/librt.so.1 (0x00007f8ff12d6000)
            liblzma.so.5 => /lib/x86_64-linux-gnu/liblzma.so.5 (0x00007f8ff12ad000)
            liblz4.so.1 => /lib/x86_64-linux-gnu/liblz4.so.1 (0x00007f8ff128c000)
            libgcrypt.so.20 => /lib/x86_64-linux-gnu/libgcrypt.so.20 (0x00007f8ff116e000)
            libgpg-error.so.0 => /lib/x86_64-linux-gnu/libgpg-error.so.0 (0x00007f8ff1149000)
     ldd /lib/x86_64-linux-gnu/libQt5XcbQpa.so.5
     linux-vdso.so.1 (0x00007ffe54dce000)
            libfontconfig.so.1 => /lib/x86_64-linux-gnu/libfontconfig.so.1 (0x00007f7452b40000)
            libfreetype.so.6 => /lib/x86_64-linux-gnu/libfreetype.so.6 (0x00007f7452a81000)
            libQt5Gui.so.5 => /lib/x86_64-linux-gnu/libQt5Gui.so.5 (0x00007f7452496000)
            libQt5DBus.so.5 => /lib/x86_64-linux-gnu/libQt5DBus.so.5 (0x00007f74523fa000)
            libQt5Core.so.5 => /lib/x86_64-linux-gnu/libQt5Core.so.5 (0x00007f7451eaf000)
            libpthread.so.0 => /lib/x86_64-linux-gnu/libpthread.so.0 (0x00007f7451e8c000)
            libX11-xcb.so.1 => /lib/x86_64-linux-gnu/libX11-xcb.so.1 (0x00007f7451e87000)
            libxcb-xinput.so.0 => /lib/x86_64-linux-gnu/libxcb-xinput.so.0 (0x00007f7451e63000)
            libxcb-icccm.so.4 => /lib/x86_64-linux-gnu/libxcb-icccm.so.4 (0x00007f7451e5c000)
            libxcb-image.so.0 => /lib/x86_64-linux-gnu/libxcb-image.so.0 (0x00007f7451c57000)
            libxcb-shm.so.0 => /lib/x86_64-linux-gnu/libxcb-shm.so.0 (0x00007f7451c50000)
            libxcb-keysyms.so.1 => /lib/x86_64-linux-gnu/libxcb-keysyms.so.1 (0x00007f7451c4b000)
            libxcb-randr.so.0 => /lib/x86_64-linux-gnu/libxcb-randr.so.0 (0x00007f7451c38000)
            libxcb-render-util.so.0 => /lib/x86_64-linux-gnu/libxcb-render-util.so.0 (0x00007f7451c31000)
            libxcb-render.so.0 => /lib/x86_64-linux-gnu/libxcb-render.so.0 (0x00007f7451c22000)
            libxcb-shape.so.0 => /lib/x86_64-linux-gnu/libxcb-shape.so.0 (0x00007f7451c1d000)
            libxcb-sync.so.1 => /lib/x86_64-linux-gnu/libxcb-sync.so.1 (0x00007f7451c11000)
            libxcb-xfixes.so.0 => /lib/x86_64-linux-gnu/libxcb-xfixes.so.0 (0x00007f7451c07000)
            libxcb-xinerama.so.0 => /lib/x86_64-linux-gnu/libxcb-xinerama.so.0 (0x00007f7451c02000)
            libxcb-xkb.so.1 => /lib/x86_64-linux-gnu/libxcb-xkb.so.1 (0x00007f7451be4000)
            libxcb.so.1 => /lib/x86_64-linux-gnu/libxcb.so.1 (0x00007f7451bba000)
            libXrender.so.1 => /lib/x86_64-linux-gnu/libXrender.so.1 (0x00007f74519b0000)
            libX11.so.6 => /lib/x86_64-linux-gnu/libX11.so.6 (0x00007f7451871000)
            libm.so.6 => /lib/x86_64-linux-gnu/libm.so.6 (0x00007f7451722000)
            libSM.so.6 => /lib/x86_64-linux-gnu/libSM.so.6 (0x00007f7451717000)
            libICE.so.6 => /lib/x86_64-linux-gnu/libICE.so.6 (0x00007f74516f9000)
            libxkbcommon-x11.so.0 => /lib/x86_64-linux-gnu/libxkbcommon-x11.so.0 (0x00007f74516ee000)
            libxkbcommon.so.0 => /lib/x86_64-linux-gnu/libxkbcommon.so.0 (0x00007f74516ac000)
            libglib-2.0.so.0 => /lib/x86_64-linux-gnu/libglib-2.0.so.0 (0x00007f7451580000)
            libstdc++.so.6 => /lib/x86_64-linux-gnu/libstdc++.so.6 (0x00007f745139e000)
            libgcc_s.so.1 => /lib/x86_64-linux-gnu/libgcc_s.so.1 (0x00007f7451383000)
            libc.so.6 => /lib/x86_64-linux-gnu/libc.so.6 (0x00007f7451191000)
            libexpat.so.1 => /lib/x86_64-linux-gnu/libexpat.so.1 (0x00007f7451163000)
            libuuid.so.1 => /lib/x86_64-linux-gnu/libuuid.so.1 (0x00007f745115a000)
            libpng16.so.16 => /lib/x86_64-linux-gnu/libpng16.so.16 (0x00007f7451120000)
            libz.so.1 => /lib/x86_64-linux-gnu/libz.so.1 (0x00007f7451104000)
            libGL.so.1 => /lib/x86_64-linux-gnu/libGL.so.1 (0x00007f745107c000)
            libharfbuzz.so.0 => /lib/x86_64-linux-gnu/libharfbuzz.so.0 (0x00007f7450f78000)
            libdbus-1.so.3 => /lib/x86_64-linux-gnu/libdbus-1.so.3 (0x00007f7450f27000)
            libicui18n.so.66 => /lib/x86_64-linux-gnu/libicui18n.so.66 (0x00007f7450c28000)
            libicuuc.so.66 => /lib/x86_64-linux-gnu/libicuuc.so.66 (0x00007f7450a40000)
            libdl.so.2 => /lib/x86_64-linux-gnu/libdl.so.2 (0x00007f7450a3a000)
            libpcre2-16.so.0 => /lib/x86_64-linux-gnu/libpcre2-16.so.0 (0x00007f74509b6000)
            libdouble-conversion.so.3 => /lib/x86_64-linux-gnu/libdouble-conversion.so.3 (0x00007f74509a0000)
            /lib64/ld-linux-x86-64.so.2 (0x00007f7452d33000)
            libxcb-util.so.1 => /lib/x86_64-linux-gnu/libxcb-util.so.1 (0x00007f745079a000)
            libXau.so.6 => /lib/x86_64-linux-gnu/libXau.so.6 (0x00007f7450792000)
            libXdmcp.so.6 => /lib/x86_64-linux-gnu/libXdmcp.so.6 (0x00007f745078a000)
            libbsd.so.0 => /lib/x86_64-linux-gnu/libbsd.so.0 (0x00007f7450770000)
            libpcre.so.3 => /lib/x86_64-linux-gnu/libpcre.so.3 (0x00007f74506fd000)
            libGLdispatch.so.0 => /lib/x86_64-linux-gnu/libGLdispatch.so.0 (0x00007f7450645000)
            libGLX.so.0 => /lib/x86_64-linux-gnu/libGLX.so.0 (0x00007f745060f000)
            libgraphite2.so.3 => /lib/x86_64-linux-gnu/libgraphite2.so.3 (0x00007f74505e2000)
            libsystemd.so.0 => /lib/x86_64-linux-gnu/libsystemd.so.0 (0x00007f7450533000)
            libicudata.so.66 => /lib/x86_64-linux-gnu/libicudata.so.66 (0x00007f744ea72000)
            librt.so.1 => /lib/x86_64-linux-gnu/librt.so.1 (0x00007f744ea68000)
            liblzma.so.5 => /lib/x86_64-linux-gnu/liblzma.so.5 (0x00007f744ea3d000)
            liblz4.so.1 => /lib/x86_64-linux-gnu/liblz4.so.1 (0x00007f744ea1c000)
            libgcrypt.so.20 => /lib/x86_64-linux-gnu/libgcrypt.so.20 (0x00007f744e8fe000)
            libgpg-error.so.0 => /lib/x86_64-linux-gnu/libgpg-error.so.0 (0x00007f744e8db000)
    依赖也没有缺少的,但是依然打不开。
    是原生界面还是ssh过去的
    输入gedit之类的能打开么
    yyyy
    用的wsl安装的Ubuntu,gedit确实打不开
    yl@yl:~$ sudo gedit ~/.bashrc
    sudo: gedit: command not found
    你换windows的paraview吧。不要再wsl下面装paraview
    yyyy
    好的 再次谢谢李老师,其实Windows已经下了paraview就是更改bashrc文件让linux能调用的时候也出错了,只能复制粘贴文件太麻烦了。没事 改天我再重下次!
    是的,所以我感觉wsl的体验也不是特别好。你再研究研究
    chon01
    楼主您好,请问您的问题解决了嘛,我在wsl下的ubutu也出现了同样的问题
    longsheng
    之前遇到了同样的问题,最后选择调用windows下的paraview,这个链接https://www.cnblogs.com/liusuanyatong/p/11259638.html的方法还是比较简单有效的,就是打开paraview可能会稍微有点慢
    chon01
    在 中回复了 longsheng 最后由 编辑
    @longsheng 谢谢您
    R 1 条回复 最后回复
    rhzhang
    在 中回复了 chon01 最后由 编辑
    @chon01
    我也遇到了一样的问题,然后找到了这个视频
    https://www.bilibili.com/video/BV1qq4y1S7DJ/?share_source=copy_web&vd_source=b8e30eb5b15079ed88d8e05423e7edf3
    视频里跟着楼主上面发的帖子里的步骤进行的更改,比较详细(原帖省略了一些说明,我第一次跟着做没有成功T-T),个人感觉很有用!
    chon01
    在 中回复了 rhzhang 最后由 编辑
    @rhzhang 谢谢您
