  3. 可压流计算发散,出现Negative Initial Temperature 问题如何处理?
rhosimplefoamrhopimplefoam
25 帖子 7 发布者 26.3k 浏览
    RebelYoung
    在 中回复了 sibo 最后由 编辑
    @sibo log是rhoC 的,算例thermo 中mu 1.82E -5,肯定是viscous 哇。
    一开始我算的超过0.3Ma ,很快发散。我怀疑是雷诺数太高的层流问题。。。就把速度改小了,雷诺数在10的3次方量级。
    RebelYoung
    在 中回复了 sibo 最后由 编辑
    @sibo 上面传了个rcf_sphere_laminar 的压缩文件,里面有polyMesh 以外的文件。BCs 的话真的很简单,上面描述过了。
    RebelYoung
    以上基本描述的都是rhoCentralFoam问题,报错是Negative Initial Temperature,但是全场最小温度并没有负值。。
    这个rcf_sphere_laminar是根据,$FOAM_TUTORIALS/compressible/rhoCentralFoam/obliqueShock改的。是层流计算,/0下设置了p,T,U三个量。
    以下贴出rhoC 0下文件:
    ./0/p
        format      ascii;
        class       volScalarField;
        object      p;
    internalField   uniform 100000;
        ball
            type            zeroGradient;
        inlet
            type            zeroGradient;
        outlet
            type            fixedValue;
            value           uniform 100000;
        far
            type            zeroGradient;
    ./0/T
        format      ascii;
        object      T;
    internalField   uniform 270;
        ball
            type            zeroGradient;
        inlet
            type            fixedValue;
            value           uniform 270;
        outlet
            type            zeroGradient;
        far
            type            fixedValue;
            value           uniform 270;
    ./0/U
    其中U从1到250,都算过。都出现能量方程发散或negative initial temperature问题。
        format      ascii;
        class       volVectorField;
        object      U;
    internalField   uniform (1 0 0);
        ball
            type            noSlip;
        inlet
            type            fixedValue;
        outlet
            type            zeroGradient;
        far
            type            fixedValue;
    checkMesh结果:
    Create time
    Create polyMesh for time = 0
    Time = 0
    Mesh stats
        faces:            309924
        internal faces:   293684
        cells:            150902
        faces per cell:   4
        boundary patches: 4
        point zones:      0
        face zones:       0
        cell zones:       0
        hexahedra:     0
        prisms:        0
        wedges:        0
        pyramids:      0
        tet wedges:    0
        tetrahedra:    150902
        polyhedra:     0
    Checking topology...
        Boundary definition OK.
        Cell to face addressing OK.
        Point usage OK.
        Upper triangular ordering OK.
        Face vertices OK.
        Number of regions: 1 (OK).
        ball                9780     4892     ok (closed singly connected)
        far                 4404     2278     ok (non-closed singly connected)
        inlet               1028     553      ok (non-closed singly connected)
        outlet              1028     553      ok (non-closed singly connected)
    Checking geometry...
        Overall domain bounding box (-0.1 -0.1 -0.1) (0.1 0.1 0.1)
        Boundary openness (1.54762e-16 -1.49987e-17 -1.09064e-16) OK.
        Max cell openness = 3.03063e-16 OK.
        Max aspect ratio = 5.29154 OK.
        Minimum face area = 3.38388e-08. Maximum face area = 0.000137468.  Face area magnitudes OK.
        Min volume = 4.46514e-12. Max volume = 4.98913e-07.  Total volume = 0.00799582.  Cell volumes OK.
        Mesh non-orthogonality Max: 58.0988 average: 22.4508
        Non-orthogonality check OK.
        Face pyramids OK.
        Max skewness = 0.67456 OK.
    Mesh OK.
    End
    @sibo
    ./constant/thermophysicalProperties: 此文件根据rhoS中计算翼型的文件修改,因为原算例是想控制mach数等原因,改的不符合物理性质,且mu=0。我将其改成了正常参数。
        format      ascii;
        class       dictionary;
        location    "constant";
        object      thermophysicalProperties;
    thermoType
        type            hePsiThermo;
        mixture         pureMixture;
        transport       const;
        thermo          hConst;
        equationOfState perfectGas;
        specie          specie;
    mixture
        // normalised gas
        specie
            molWeight       28.9;
        thermodynamics
            Cp              1005;
            Hf              0;
        transport
            mu              1.8e-5;
            Pr              0.71;
        format      ascii;
        class       dictionary;
    simulationType  laminar;
    RebelYoung
    @bestucan 可是上面minMax监视的全场温度,并没有出现负温度啊?初始值220K,最低也就210.。。
    RebelYoung
    最新看到的说法是,T估算值或者插值中出现了问题。比如方程解的是h,那么从h=cp(T)T中解出T的估算值,结果是负的。。
    rhoC解的是e,那么e=Cv
    T,cv基本不变,那应该是e出现负值导致T出现负值。。。
    bestucanB 1 条回复 最后回复
    在 中回复了 RebelYoung 最后由 编辑
    @RebelYoung 出现负值不代表计算结果是负的。数值溢出也会成负值。就是大到极限了。
    温度的 min max 最后一步最大值不但跳增,而且离上一个坐标点很远,这很明显有问题啊。一个时间步至少增长了4000K,你的时间步还那么的小。这种增长率很可能是数值溢出了。
    如果问题描述搭的附件太多,会看起来很难成一体,即使尽力地暗逻辑描述。一般这种状况的信息是像引用文献那样表述的。下面是个例子,自由软件基金会的公开邮件。不过因为是纯文本格式的,所以网址是直接贴的,你可以用超链接。
    这样主体信息和逻辑就不会被附件打断了。现在看你的帖子有种听微信语音的感觉:xinlei:
    This spring, as the time for planning our [biannual appeal][1] came
    around, we discussed the difficult time all of us are
    experiencing: charities like us, the free software community, and
    every individual. And it led us to consider why people from all
    walks of life cherish user freedom.
    [1]: https://www.fsf.org/appeal?pk_campaign=frspring2020&pk_source=collab1
    The socially distant, digital way in which we are carrying on our
    work and private lives is affecting our software
    freedom. Globally, decisions to transition to an online and
    remote life were made with less consideration than we normally
    put into them, giving proprietary corporations access to parts of
    our lives we normally protect. Lately, we have been pointing to
    grim examples of [bulk surveillance][2] and [privacy
    violations][3] in the realms of education and [communication][4]
    to help everyone understand why this fight is so important.
    [2]: https://www.fsf.org/blogs/community/remote-education-does-not-require-giving-up-rights-to-freedom-and-privacy
    [3]: https://www.fsf.org/bulletin/2019/spring/its-not-just-about-privacy
    [4]: https://www.fsf.org/blogs/community/better-than-zoom-try-these-free-software-tools-for-staying-in-touch
  • 爱 离线
    爱 离线
    爱吃鱼的兔子
    你好,想问一下你问的这个问题解决了吗,我也遇到了一样的问题。如果你已经解决了,能麻烦你提点指教一下吗
    DXSS
    您好,想问一下您问的这个问题解决了吗,我目前也在通过naca翼型接触openfoam,用rhopimple算的非定常总是收敛,从rhopimple改成rhoC算就会提示各种错误
    wangpc
    在 中回复了 DXSS 最后由 编辑
    @DXSS 在 可压流计算发散,出现Negative Initial Temperature 问题如何处理? 中说:
    你好,请问解决了吗
    可压缩流动瞬态算法要比稳态更容易收敛
