  3. solids4foam运行算例,流固耦合交界面报错
3 帖子 3 发布者 1.9k 浏览
  • 洱聿洱 离线
    洱聿洱 离线
    洱聿
    在solids4foam中运行验证算例(孤立波下斜坡上的直墙变形和受力),但是当波浪到固体交界面时,就会出现浮点报错问题,修改了网格和固体交界面的问题,还是没有改善这个问题。请问有大佬们知道怎么解决这个问题吗?
    报错时间步alpha场:(每次到这个地方就出现报错)
    报错部分log文件:
    Time = 8.933, iteration: 9
    Current fsi under-relaxation factor (Aitken) of interface: 3.24861e-06
    Maximal accumulated displacement of interface 0: 2.02709e-06
    GAMG:  Solving for cellMotionUx, Initial residual = 0.27053, Final residual = 4.88471e-05, No Iterations 2
    GAMG:  Solving for cellMotionUz, Initial residual = 0.276424, Final residual = 7.60589e-05, No Iterations 2
    GAMG:  Solving for cellMotionUx, Initial residual = 5.19396e-05, Final residual = 4.62925e-07, No Iterations 4
    GAMG:  Solving for cellMotionUz, Initial residual = 8.68504e-05, Final residual = 8.18649e-07, No Iterations 3
    Evolving fluid model: wave2solids
    PIMPLE: iteration 1
    MULES: Solving for alpha1
    alpha1 BC on patch inlet
    Liquid phase volume fraction = 0.259489  Min(alpha1) = -2191.92  Max(alpha1) = 2360.17
    Liquid phase volume fraction = 0.259489  Min(alpha1) = -158062  Max(alpha1) = 163488
    Velocity BC on patch inlet
    3D_2D Absorption BC on patch outlet
    "Correction Levels" 1( 0 )
    DICPCG:  Solving for pd, Initial residual = 0.10778, Final residual = 0.00369688, No Iterations 8
    DICPCG:  Solving for pd, Initial residual = 6.32049e-06, Final residual = 2.94799e-07, No Iterations 644
    DICPCG:  Solving for pd, Initial residual = 4.65247e-05, Final residual = 2.1618e-06, No Iterations 637
    DICPCG:  Solving for pd, Initial residual = 2.0431e-07, Final residual = 9.74494e-08, No Iterations 110
    DICPCG:  Solving for pd, Initial residual = 4.64318e-05, Final residual = 2.21746e-06, No Iterations 638
    DICPCG:  Solving for pd, Initial residual = 2.16117e-07, Final residual = 8.27667e-08, No Iterations 132
    Setting traction on solid interfaces
    Mapping face values using directMap
    Total force on fluid interface 0: (4.3321e+10 -2.82466e-19 -0.673933)
    Total force on solid interface 0: (-4.3321e+10 2.82466e-19 0.673933)
    Evolving solid solver
    Solving the updated Lagrangian form of the momentum equation for DD
    mpirun noticed that process rank 6 with PID 168600 on node node03 exited on signal 8 (Floating point exception).
    卑以自牧,温润如玉。
    cuimai
    大佬,想请教个问题,就是我下载好了solids4Foam,编译也成功了,但是里面的算例算不了,是这样的
    你那个不是算不了,是发散了
