OF memory requirement
我自己的算例: 1.44M的Cell 峰值 RSS 3.8 GB, 还有一些小的 case。
圆柱绕流 pisofoam;
DDES;
OF4.1,;
cpu: AMD Opteron™ Processor 617
OS: CentOS Linux release 7.5.1804 (Core)=======info begin
I am in:
/home/newuser/scratch/lengthEffect/workingFolder/case_z_100Layer
JobID Elapsed NCPUS AveRSS MaxRSS AveVMSize ReqMem
13699.batch 21:35:11 24 3743510K 3800206K 21826016K 31Gn
Case mesh contains
cells: 1440000I am in:
/home/newuser/scratch/lengthEffect/workingFolder/case_z_20Layer
13700.batch 03:35:13 24 1913933K 1953179K 19062444K 31Gn
Case mesh contains
cells: 288000I am in:
/home/newuser/scratch/lengthEffect/workingFolder/case_z_40Layer
13701.batch 09:46:27 24 2329258K 2405771K 19580912K 31Gn
Case mesh contains
cells: 576000I am in:
/home/newuser/scratch/lengthEffect/workingFolder/case_z_60Layer
13702.batch 16:42:47 24 2777944K 2875499K 20423644K 31Gn
Case mesh contains
cells: 864000I am in:
/home/newuser/scratch/lengthEffect/workingFolder/case_z_80Layer
13703.batch 18:27:01 24 2225055K 3324466K 15583600K 31Gn
Case mesh contains
cells: 1152000=======info end
又做了个测试,转换网格和checkMesh都没有问题,createPatch出现了如下错误:
// * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Create polyMesh for time = 0 Reading createPatchDict Adding new patch FRONT_CYC as patch 5 from { type cyclic; neighbourPatch BACK_CYC; matchTolerance 0.01; } Adding new patch BACK_CYC as patch 6 from { type cyclic; neighbourPatch FRONT_CYC; matchTolerance 0.01; } Moving faces from patch FRONT to patch 5 terminate called after throwing an instance of 'std::bad_array_new_length' what(): std::bad_array_new_length我的c++不好,但还是想尝试去找这个error的源头。
cppreference 上说三种可能的原因,我觉得我的case是“too large”。
#include <iostream> #include <new> #include <climits> int main() { int negative = -1; int small = 1; int large = INT_MAX; try { new int[negative]; // negative size new int[small]{1,2,3}; // too many initializers new int[large][1000000]; // too large } catch(const std::bad_array_new_length &e) { std::cout << e.what() << '\n'; } }我顺着 Moving faces from patch FRONT to patch 5 找到 createPatch.C 源代码:
====> createPatch.C: Line 705~714 forAll(pp, i) { changePatchID ( mesh, pp.start() + i, destPatchi, meshMod ); }似乎是死在了这个循环里,
changePatchID 的arguments: ( const polyMesh& mesh, const label faceID, const label patchID, polyTopoChange& meshMod )changePatchID里嵌套的这个函数很可疑meshMod.setAction, 特别是polyModifyFace这个函数定义在
polyModifyFace.H奇怪polyModifyPoint.C居然不存在。 似乎是一个虚函数。看到这里,感觉无能为力了,想要找到类似这种
的声明看来是行不通了。所以想请教大家的想法。
====> checkMesh /*---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 4.1 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ Build : 4.1 Exec : checkMesh Date : Jul 06 2018 Time : 15:54:53 Host : "cp0401" PID : 12872 Case : /scratch/crazyuser/biggerMesh nProcs : 1 sigFpe : Enabling floating point exception trapping (FOAM_SIGFPE). fileModificationChecking : Monitoring run-time modified files using timeStampMaster allowSystemOperations : Allowing user-supplied system call operations // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Create polyMesh for time = 0 Time = 0 Mesh stats points: 257514000 faces: 769512000 internal faces: 766488000 cells: 256000000 faces per cell: 6 boundary patches: 5 point zones: 0 face zones: 1 cell zones: 1 Overall number of cells of each type: hexahedra: 256000000 prisms: 0 wedges: 0 pyramids: 0 tet wedges: 0 tetrahedra: 0 polyhedra: 0 Checking topology... Boundary definition OK. Cell to face addressing OK. Point usage OK. Upper triangular ordering OK. Face vertices OK. Number of regions: 1 (OK). Checking patch topology for multiply connected surfaces... Patch Faces Points Surface topology FRONT 1000000 1002000 ok (non-closed singly connected) INLET 256000 257257 ok (non-closed singly connected) OUTLET 256000 257257 ok (non-closed singly connected) CYLINDER 512000 514000 ok (non-closed singly connected) BACK 1000000 1002000 ok (non-closed singly connected) Checking geometry... Overall domain bounding box (-32 -32 0) (32 32 3.33332) Mesh has 3 geometric (non-empty/wedge) directions (1 1 1) Mesh has 3 solution (non-empty) directions (1 1 1) Boundary openness (-4.65606e-16 4.16736e-21 -4.97036e-16) OK. Max cell openness = 3.18122e-16 OK. Max aspect ratio = 29.4282 OK. Minimum face area = 1.3175e-06. Maximum face area = 0.0385213. Face area magnitudes OK. Min volume = 1.71549e-08. Max volume = 0.000501578. Total volume = 10720.6. Cell volumes OK. Mesh non-orthogonality Max: 1.72876e-05 average: 0 Non-orthogonality check OK. Face pyramids OK. Max skewness = 0.00266764 OK. Coupled point location match (average 0) OK. Mesh OK. End -
又查了一下峰值内存,似乎感觉到了问题的所在。
JobID Elapsed NCPUS AveRSS MaxRSS AveVMSize ReqMem ------------ ---------- ---------- ---------- ---------- ---------- ---------- 13898.batch 05:56:36 48 191885982K 194887914K 192155004K 200Gn -
重新运行了算例, 提高了内存请求(200GB->251GB)。同样的结果。请求内存似乎不是问题所在,峰值 RSS 和 200G内存一样。
JobID Elapsed NCPUS AveRSS MaxRSS AveVMSize ReqMem ------------ ---------- ---------- ---------- ---------- ---------- ---------- 14389 06:00:15 192 251Gn 14389.batch 06:00:15 48 302K 194452190K 113468K 251Gn 14389.extern 06:00:15 192 115K 144K 107948K 251Gn
