  3. request for volScalarField from objectRegistry failed
3 帖子 3 发布者 4.5k 浏览
    在寻找对象的时候,初始化成员这样写的话:
    rhoc_(mesh.time().lookupObject<volScalarField>("rhoc")),
    或者
    rhoc_(mesh.time().db().lookupObject<volScalarField>("rhoc")),
    等等等,报错如下
    --> FOAM FATAL ERROR:
        request for volScalarField rhod from objectRegistry QMOM failed
        available objects of type volScalarField are
    0()
    更改为
    rhoc_(mesh.lookupObject<volScalarField>("rhoc")),
    即可,这样寻找的对象注册体为region不是是类型。
        request for volScalarField rhod from objectRegistry region0 failed
    8
    k
    rhoc
    muc
    alpha
    rhod
    d32
    mud
    epsilon
    L 范准范 2 条回复 最后回复
    lyc
    @李东岳 李老师,在使用openFOAM-V2006版本的buoyantBoussinesqFoam求解器,出现如下报错:
    request for basicThermo thermophysicalProperties from objectRegistry region0 failed
    available objects of type basicThermo are
    0()
    From const Type& Foam::objectRegistry::lookupObject(const Foam::word&, bool) const [with Type = Foam::basicThermo]
    in file /home/lyc/OpenFOAM/OpenFOAM-v2006/src/OpenFOAM/lnInclude/objectRegistryTemplates.C at line 463.
    FOAM aborting
    #0 Foam::error::printStack(Foam::Ostream&) at ??:?
    #1 Foam::error::exitOrAbort(int, bool) at ??:?
    #2 Foam::basicThermo const& Foam::objectRegistry::lookupObjectFoam::basicThermo(Foam::word const&, bool) const at ??:?
    #3 Foam::fv::fixedTemperatureConstraint::fixedTemperatureConstraint(Foam::word const&, Foam::word const&, Foam::dictionary const&, Foam::fvMesh const&) at ??:?
    #4 Foam::fv::option::adddictionaryConstructorToTableFoam::fv::fixedTemperatureConstraint::New(Foam::word const&, Foam::word const&, Foam::dictionary const&, Foam::fvMesh const&) at ??:?
    #5 Foam::fv::option::New(Foam::word const&, Foam::dictionary const&, Foam::fvMesh const&) at ??:?
    #6 Foam::fv::optionList::reset(Foam::dictionary const&) at ??:?
    #7 Foam::fv::optionList::optionList(Foam::fvMesh const&, Foam::dictionary const&) at ??:?
    #8 Foam::fv::options::options(Foam::fvMesh const&) at ??:?
    #9 Foam::fv::options::New(Foam::fvMesh const&) at ??:?
    #10 ? in ~/OpenFOAM/OpenFOAM-v2006/platforms/linux64GccDPInt32Opt/bin/buoyantBoussinesqPimpleFoam
    #11 __libc_start_main in /lib/x86_64-linux-gnu/libc.so.6
    #12 ? in ~/OpenFOAM/OpenFOAM-v2006/platforms/linux64GccDPInt32Opt/bin/buoyantBoussinesqPimpleFoam
    请问是什么原因呢,我的constant 和0文件与tutorials一致,还是报错。
  • 范准范 离线
    范准范 离线
    范准
    @李东岳 最近在将低版本OF的自定义边界条件移植到高版本OF的时候也发生了这个问题。串行求解没问题,并行求解报错。在不修改自定义边界条件源码的情况下,解决方案如下:1.在decomposePar前,将controlDict中引用的自定义库注释掉,例如
    libs (
          "libOpenFOAM.so"
          //"libUserBC.so"
    2.执行decomposePar,3.取消注释,4.运行求解器,5.重新注释,6.执行reconstructPar。
    以上,便可解决该报错。
