  3. 利用散点插值成连续曲线作为另外一个几何的边界条件?
6 帖子 2 发布者 6.1k 浏览
  • J 离线
    J 离线
    jiangqih
    我现在有个一个压强随x方向变化的散点文件,我现在需要对这个散点进行插值形成曲线作为另外一个几何边界的边界条件,在OF中该怎么实现呢?
    请参考下面的边界条件:
    inlet
            type            fixedProfile;
            profile         csvFile;
            profileCoeffs
                nHeaderLine         1;          // Number of header lines
                refColumn           0;          // Reference column index
                componentColumns    (1);    // Component column indices
                separator           ",";        // Optional (defaults to ",")
                mergeSeparators     no;         // Merge multiple separators
                fileName            "inletProfiles/alpha.csv";
                outOfBounds         clamp;      // Optional out-of-bounds handling
                interpolationScheme linear;     // Optional interpolation scheme
            direction        (1 0 0);
            origin           0;
  • J 离线
    J 离线
    jiangqih
    boundaryField
    front
    type empty;
    cyc_left
    type cyclic;
    top
    type uniformTotalPressure;
    profile csvFile;
    profileCoeffs
    nHeaderLine 0; // Number of header lines
    componentColumns (1 2); // Component column indices
    fileName "dataFile.csv"; // name of csv data file
    direction (1 0 0);
    origin 0;
    bottom
    type zeroGradient;
    back
    type empty;
    cyc_right
    type cyclic;
    data file 格式
    0,0
    0.005,0.043
    0.01,0.158
    0.015,0.311
    0.02,0.482
    0.025,0.663
    0.03,0.845
    0.035,1.022
    0.04,1.187
    0.045,1.334
    0.05,1.46
    0.055,1.561
    0.06,1.637
    0.065,1.69
    0.07,1.723
    0.075,1.737
    0.08,1.735
    0.085,1.717
    0.09,1.688
    0.095,1.648
    0.1,1.599
    0.105,1.543
    0.11,1.48
    0.115,1.412
    0.12,1.34
    0.125,1.263
    0.13,1.183
    0.135,1.099
    0.14,1.012
    0.145,0.922
    0.15,0.829
    0.155,0.733
    0.16,0.633
    0.165,0.531
    0.17,0.425
    0.175,0.315
    0.18,0.201
    0.185,0.083
    0.19,-0.041
    0.195,-0.172
    0.2,-0.31
    0.205,-0.457
    0.21,-0.615
    0.215,-0.789
    0.22,-0.982
    0.225,-1.21
    0.23,-1.469
    0.235,-1.853
    0.24,-2.185
    0.245,-2.948
    0.25,-2.923
    0.255,-2.011
    0.26,-1.717
    0.265,-1.562
    0.27,-1.437
    0.275,-1.32
    0.28,-1.209
    0.285,-1.101
    0.29,-0.996
    0.295,-0.894
    0.3,-0.797
    0.305,-0.702
    0.31,-0.61
    0.315,-0.521
    0.32,-0.437
    0.325,-0.358
    0.33,-0.285
    0.335,-0.22
    0.34,-0.152
    0.345,-0.065
    0.35,-0.017
    但是一直报错,找了好久也没找出原因来
    --> FOAM FATAL IO ERROR:
    keyword file is undefined in dictionary "/home/qihao/OpenFOAM/qihao-5.0/run/hyporheic/Hyporheic/Groundwater/Stratified/0/p.boundaryField.top.profileCoeffs"
    file: /home/qihao/OpenFOAM/qihao-5.0/run/hyporheic/Hyporheic/Groundwater/Stratified/0/p.boundaryField.top.profileCoeffs from line 38 to line 45.
    From function const Foam::entry& Foam::dictionary::lookupEntry(const Foam::word&, bool, bool) const
    in file db/dictionary/dictionary.C at line 566.
  • J 离线
    J 离线
    jiangqih
    p文件用的是这个,上面回复错了
    boundaryField
    front
    type empty;
    cyc_left
    type cyclic;
    top
    type fixedProfile;;
    profile csvFile;
    profileCoeffs
    direction (1 0 0);
    origin 0;
    bottom
    type zeroGradient;
    back
    type empty;
    cyc_right
    type cyclic;
    把这个
    fileName “dataFile.csv”; // name of csv data file
    改为
    file  “dataFile.csv”; // name of csv data file
    估计你用的OpenFOAM-5.x
    J 1 条回复 最后回复
  • J 离线
    J 离线
    jiangqih
    @李东岳 谢谢东岳老师,明天再试一下
