对某文章关于piso循环的一段话不太明白
The solution for pressure equation utilizes the PISO (pressure implicit with split operator) based PIMPLE method, together with a conjugate gradient methods for coupled mass and momentum conservation equations, which is specifically suited to transient flow. 文章用的是openfoam
 里面提到的conjugate gradient methods这个该怎么解读
