fluent如何输出颗粒对壁面的碰撞速度和角度。
我用fluent模拟气固管流冲蚀,得到了壁面的冲蚀速率:
 1、问题:fluent导出壁面数据后,缺乏颗粒对壁面的平均碰撞速度(轴向、径向、切向)和平均角度(入射角、反射角)这五个变量。 一个壁面位置受多次颗粒撞击,速度和角度有多个,需要统计一下平均。
 2、UDF刚接触,按照模板修改了一点点,不知道怎么继续写下去,求高人指路!
 #include "udf.h"DEFINE_DPM_BC(bc_reflect,p,t,f,f_normal,dim) { real alpha; /* angle of particle path with face normal */ real vn=0.; real nor_coeff = 0.; real tan_coeff = 0; real normal[3]; int i, idim = dim; real NV_VEC(x); for (i=0; i<idim; i++) normal[i] = f_normal[i]; if(p->type==DPM_TYPE_INERT) { alpha = M_PI/2. - acos(MAX(-1.,MIN(1.,NV_DOT(normal,P_VEL(p))/ MAX(NV_MAG(P_VEL(p)),DPM_SMALL)))); if ((NNULLP(t)) && (THREAD_TYPE(t) == THREAD_F_WALL)) F_CENTROID(x,f,t); /* 定义壁面反射系数 */ nor_coeff=0.993-0.0307*alpha+4.75e-4*alpha*alpha-2.61e-6*alpha*alpha*alpha tan_coeff=0.998-0.029*alpha+6.43e-4*alpha*alpha-3.56e-6*alpha*alpha*alpha /* calculate the normal component, rescale its magnitude by the coefficient of restitution and subtract the change */ /* Compute normal velocity. */ for(i=0; i<idim; i++) vn += P_VEL(p)[i]*normal[i]; /* Subtract off normal velocity. */ for(i=0; i<idim; i++) P_VEL(p)[i] -= vn*normal[i]; /* Apply tangential coefficient of restitution. */ for(i=0; i<idim; i++) P_VEL(p)[i] *= tan_coeff; /* Add reflected normal velocity. */ for(i=0; i<idim; i++) P_VEL(p)[i] -= nor_coeff*vn*normal[i]; /* Store new velocity in P_VEL0 of particle */ for(i=0; i<idim; i++) P_VEL0(p)[i] = P_VEL(p)[i]; return PATH_ACTIVE; } return PATH_ABORT; }
