  3. OF memory requirement
5 帖子 2 发布者 5.6k 浏览
  • siboS 离线
    siboS 离线
    sibo
    大家好,
    请问在并行运算的时候,每个core需要多少memory呢?
    应该是和 decompse之后每个core所负责的cells数目 以及 solver复杂程度有关,请问有什么相关的大致规律呢?
    昨天发现一个大概3千万cells的mesh,单核跑checkMesh时 提示run out of memory, 但是solver可以跑!是不是checkMesh对memory要求很大?
    非常感谢!
  • R 离线
    R 离线
    random_ran 大神
    我自己的算例: 1.44M的Cell 峰值 RSS 3.8 GB, 还有一些小的 case。
    圆柱绕流 pisofoam;
    DDES;
    OF4.1,;
    cpu: AMD Opteron™ Processor 617
    OS: CentOS Linux release 7.5.1804 (Core)
    =======info begin
    I am in:
    /home/newuser/scratch/lengthEffect/workingFolder/case_z_100Layer
    JobID Elapsed NCPUS AveRSS MaxRSS AveVMSize ReqMem
    13699.batch 21:35:11 24 3743510K 3800206K 21826016K 31Gn
    Case mesh contains
    cells: 1440000
    I am in:
    /home/newuser/scratch/lengthEffect/workingFolder/case_z_20Layer
    13700.batch 03:35:13 24 1913933K 1953179K 19062444K 31Gn
    Case mesh contains
    cells: 288000
    I am in:
    /home/newuser/scratch/lengthEffect/workingFolder/case_z_40Layer
    13701.batch 09:46:27 24 2329258K 2405771K 19580912K 31Gn
    Case mesh contains
    cells: 576000
    I am in:
    /home/newuser/scratch/lengthEffect/workingFolder/case_z_60Layer
    13702.batch 16:42:47 24 2777944K 2875499K 20423644K 31Gn
    Case mesh contains
    cells: 864000
    I am in:
    /home/newuser/scratch/lengthEffect/workingFolder/case_z_80Layer
    13703.batch 18:27:01 24 2225055K 3324466K 15583600K 31Gn
    Case mesh contains
    cells: 1152000
    =======info end
    Yours in CFD,
    Ran
  • R 离线
    R 离线
    random_ran 大神
    又做了个测试,转换网格和checkMesh都没有问题,createPatch出现了如下错误:
    Create time
    Create polyMesh for time = 0
    Reading createPatchDict
    Adding new patch FRONT_CYC as patch 5 from
        type            cyclic;
        neighbourPatch  BACK_CYC;
        matchTolerance  0.01;
    Adding new patch BACK_CYC as patch 6 from
        type            cyclic;
        neighbourPatch  FRONT_CYC;
    Moving faces from patch FRONT to patch 5
    terminate called after throwing an instance of 'std::bad_array_new_length'
      what():  std::bad_array_new_length
    我的c++不好,但还是想尝试去找这个error的源头。
    cppreference 上说三种可能的原因,我觉得我的case是“too large”。
    #include <iostream>
    #include <new>
    #include <climits>
    int main()
        int negative = -1;
        int small = 1;
        int large = INT_MAX;
        try {
            new int[negative];           // negative size
            new int[small]{1,2,3};       // too many initializers
            new int[large][1000000];     // too large
        } catch(const std::bad_array_new_length &e) {
            std::cout << e.what() << '\n';
    我顺着 Moving faces from patch FRONT to patch 5 找到 createPatch.C 源代码:
    ====> createPatch.C:  Line 705~714
                    forAll(pp, i)
                        changePatchID
                            mesh,
                            pp.start() + i,
                            destPatchi,
                            meshMod
    似乎是死在了这个循环里,
    changePatchID 的arguments:
        const polyMesh& mesh,
        const label faceID,
        const label patchID,
        polyTopoChange& meshMod
    changePatchID 里嵌套的这个函数很可疑 meshMod.setAction, 特别是 polyModifyFace 这个函数
    定义在
    polyModifyFace.H 奇怪 polyModifyPoint.C 居然不存在。 似乎是一个虚函数。
    看到这里,感觉无能为力了,想要找到类似这种 new int[large][1000000]; // too large
    的声明看来是行不通了。
    所以想请教大家的想法。
    ====> checkMesh
    |  \\    /   O peration     | Version:  4.1                                   |
    Build  : 4.1
    Exec   : checkMesh
    Date   : Jul 06 2018
    Time   : 15:54:53
    Host   : "cp0401"
    PID    : 12872
    Case   : /scratch/crazyuser/biggerMesh
    nProcs : 1
    Create time
    Time = 0
    Mesh stats
        faces:            769512000
        internal faces:   766488000
        cells:            256000000
        faces per cell:   6
        boundary patches: 5
        point zones:      0
        face zones:       1
        cell zones:       1
        hexahedra:     256000000
        prisms:        0
        wedges:        0
        pyramids:      0
        tet wedges:    0
        tetrahedra:    0
        polyhedra:     0
    Checking topology...
        Boundary definition OK.
        Cell to face addressing OK.
        Point usage OK.
        Upper triangular ordering OK.
        Face vertices OK.
        Number of regions: 1 (OK).
    Checking patch topology for multiply connected surfaces...
        Patch               Faces    Points   Surface topology
        FRONT               1000000  1002000  ok (non-closed singly connected)
        INLET               256000   257257   ok (non-closed singly connected)
        OUTLET              256000   257257   ok (non-closed singly connected)
        CYLINDER            512000   514000   ok (non-closed singly connected)
        BACK                1000000  1002000  ok (non-closed singly connected)
    Checking geometry...
        Overall domain bounding box (-32 -32 0) (32 32 3.33332)
        Mesh has 3 geometric (non-empty/wedge) directions (1 1 1)
        Mesh has 3 solution (non-empty) directions (1 1 1)
        Boundary openness (-4.65606e-16 4.16736e-21 -4.97036e-16) OK.
        Max cell openness = 3.18122e-16 OK.
        Max aspect ratio = 29.4282 OK.
        Minimum face area = 1.3175e-06. Maximum face area = 0.0385213.  Face area magnitudes OK.
        Min volume = 1.71549e-08. Max volume = 0.000501578.  Total volume = 10720.6.  Cell volumes OK.
        Mesh non-orthogonality Max: 1.72876e-05 average: 0
        Non-orthogonality check OK.
        Face pyramids OK.
        Max skewness = 0.00266764 OK.
    Mesh OK.
    End
    Yours in CFD,
    Ran
  • R 离线
    R 离线
    random_ran 大神
    又查了一下峰值内存,似乎感觉到了问题的所在。
    13898.batch    05:56:36         48 191885982K 194887914K 192155004K      200Gn
    Yours in CFD,
    Ran
  • R 离线
    R 离线
    random_ran 大神
    重新运行了算例, 提高了内存请求(200GB->251GB)。同样的结果。请求内存似乎不是问题所在,峰值 RSS 和 200G内存一样。
    14389          06:00:15        192                                       251Gn
    14389.batch    06:00:15         48       302K 194452190K    113468K      251Gn
    14389.extern   06:00:15        192       115K       144K    107948K      251Gn
    Yours in CFD,
    Ran
