FoamFile
version 2.0;
format ascii;
class dictionary;
location “system”;
object setFieldsDict;
defaultFieldValues ( volScalarFieldValue T 0 );
regions (
sphereToCell
centre (0.0 0.0 0.0);
radius 1;
fieldValues
volScalarFieldvalue T 1
Create time
Create mesh for time = 0
Reading setFieldsDict
Setting field default values
    Setting internal values of volScalarField T
Setting field region values
    Adding cells with centre within sphere, with centre = (0 0 0) and radius = 1
--> FOAM Warning :
    From function Foam::autoPtr<setCellField> setCellField::iNew::operator()(Foam::Istream&) const
    in file setFields.C at line 174
    field type volScalarFieldvalue not currently supported
--> FOAM Warning :
    field type T not currently supported
--> FOAM FATAL IO ERROR:
wrong token type - expected word, found on line 27 the label 1
file: .sphereToCell.fieldValues at line 27.
    From function Foam::Istream& Foam::operator>>(Foam::Istream&, Foam::word&)
    in file primitives/strings/word/wordIO.C at line 74.
FOAM exiting
