  3. 菜鸟 求解答
菜鸟 求解答
5 帖子 2 发布者 4.2k 浏览
  • 红豆沙红 离线
    红豆沙红 离线
    红豆沙
    FOAM Warning :
        From function const Foam::HashTable<Foam::List<int>, Foam::word>& Foam::polyBoundaryMesh::groupPatchIDs() const
        in file meshes/polyMesh/polyBoundaryMesh/polyBoundaryMesh.C at line 467
        Removing patchGroup 'wall' which clashes with patch 0 of the same name.
    这是0文件里的p和U没编写好 ,还是constant里的边界条件有问题呢
    网格文件从fluent文件转换而来
    世界那么大,怎能不去看看
  • 红豆沙红 离线
    红豆沙红 离线
    红豆沙
    Create time
    Create mesh for time = 0
    Reading transportProperties
    Reading field p
    Reading field U
    --> FOAM Warning :
    Starting time loop
    Time = 0.01
    Courant Number mean: 0.000100039 max: 0.00663633
    smoothSolver:  Solving for Ux, Initial residual = 1, Final residual = 2.17854e-06, No Iterations 4
    smoothSolver:  Solving for Uy, Initial residual = 0, Final residual = 0, No Iterations 0
    --> FOAM FATAL ERROR:
    Continuity error cannot be removed by adjusting the outflow.
    Please check the velocity boundary conditions and/or run potentialFoam to initialise the outflow.
    Total flux              : 7.4817
    Specified mass inflow   : 51.225
    Specified mass outflow  : 5.35026e-54
    Adjustable mass outflow : 0
        From function bool Foam::adjustPhi(Foam::surfaceScalarField&, const volVectorField&, Foam::volScalarField&)
        in file cfdTools/general/adjustPhi/adjustPhi.C at line 107.
    世界那么大,怎能不去看看
  • F 离线
    F 离线
    Foamer24
    wall是边界条件,建议换个名字,比如换成wall1
    红豆沙红 1 条回复 最后回复
  • 红豆沙红 离线
    红豆沙红 离线
    红豆沙
    在 中回复了 Foamer24 最后由 编辑
    @Foamer24 嗯嗯 我试试
    世界那么大,怎能不去看看
  • 红豆沙红 离线
    红豆沙红 离线
    红豆沙
    已解决 谢谢啦
    世界那么大,怎能不去看看
