  3. OpenFOAM边界条件问题
OpenFOAM边界条件问题
1 帖子 1 发布者 2.1k 浏览
  • 莫 离线
    莫 离线
    莫晓柒
    我用OpenFOAM计算外流问题,当来流速度设置为0时可以正常计算,但当来流速度大于零时最多计算一步流道就堵塞了,我怀疑是边界条件有问题。我的边界条件设置如下,请教大家这样搭配可以吗?如果不行应该是怎样呢?
    U
    FoamFile
        version     2.0;
        format      ascii;
        class       volVectorField;
        location    "0";
        object      U;
    boundaryField
        //- Set patchGroups for constraint patches
        #includeEtc "caseDicts/setConstraintTypes"
        inlet
            type            fixedValue;
            value           uniform (0 0 50);
        outlet
            type            zeroGradient;
        symm
            type            slip;
        propellerW-f
           type            movingWallVelocity;
        propellerW-s
        propellerW-h
           type            fixedValue;
        propellerW-t
           type            fixedValue;
    p
    internalField   uniform 101325;
    boundaryField
        inlet
            type            zeroGradient;
        outlet
            type            fixedValue;
            value           uniform 101325;
        symm
            type            slip;
        wall
            type            zeroGradient;
    T
    internalField   uniform 293;
    boundaryField
        inlet
            type            fixedValue;
            value           uniform 293;
        outlet
            type            inletOutlet;
            inletValue      uniform 293;
            value           uniform 293;
        symm
            type            slip;
        "inter.*"
            type            fixedValue;
        wall
            type            zeroGradient;
    nuTilda
    internalField   uniform 1e-5;
    boundaryField
        inlet
            type            fixedValue;
            value           uniform 1e-5;
        outlet
            type            inletOutlet;
            inletValue      uniform 1e-5;
            value           uniform 1e-5;
        symm
            type            slip;
        wall
            type            fixedValue;
            value           uniform 0;
    nut
    internalField   uniform 8.58e-6;
    boundaryField
        inlet
            type            fixedValue;
            value           uniform 8.58e-6;
        outlet
            type            inletOutlet;
            inletValue           uniform 8.58e-06;
            value           uniform 8.58e-06;
        symm
            type            slip;
        wall
            type            nutUSpaldingWallFunction;
            value           uniform 0;
    alphat
    dimensions      [1 -1 -1 0 0 0 0];
    internalField   uniform 0;
    boundaryField
        inlet
            type    calculated;
            value   uniform 0;
        outlet
            type    calculated;
            value   uniform 0;
        symm
            type            slip;
        "inter.*"
            type            fixedValue;
        wall
            type            compressible::alphatWallFunction;
            Prt             0.85;
            value           uniform 0;
    其中inlet,outlet,分别是进口和出口,几何边界条件为patch;symm为四周的自由边界,为柱状,几何边界条件为patch,propeller是计算的螺旋桨,几何边界条件为Wall;计算所用湍流模型为SA模型,所用求解器为rhoSimpleFoam,设置了两块MRF区域,MRF设置如下:
    FoamFile
        version     2.0;
        format      ascii;
        class       dictionary;
        location    "constant";
        object      MRFProperties;
    MRF1
        cellZone    sector_part1;
        active      yes;
        Fixed patches (propellerW-f);
        nonRotatingPatches ();
        origin    (0 0 0);
        axis      (0 0 1);
        omega     112.5737; // rad/s
    MRF2
        cellZone    sector_part2;
        active      yes;
        Fixed patches (propellerW-s);
        origin    (0 0 0);
        axis      (0 0 1);
        omega     -112.5737; // rad/s
