  3. 并行计算更新边界的问题?
并行计算更新边界的问题?
7 帖子 3 发布者 5.2k 浏览
    Samuel-Tu
    在网上找到一段讲解并行计算的代码
     while (runTime.loop())
        Info<< "Time = " << runTime.timeName() << nl << endl;
        // assign values to the field;
        // sin function expects a dimensionless argument, hence need to convert
        // current time using .value().
        // r has dimensions of length, hence the small value being added to it
        // needs to match that.
        // Finally, the result has to match dimensions of pressure, which are
        // m^2 / s^-2/
        p = Foam::sin(2.*constant::mathematical::pi*f*runTime.time().value())
                / (r/rFarCell + dimensionedScalar("small", dimLength, 1e-12))
                * dimensionedScalar("tmp", dimensionSet(0, 3, -2, 0, 0), 1.);
      // NOTE: this is needed to update the values on the processor boundaries.
      // If this is not done, the gradient operator will get confused around the
      // processor patches.
       p.correctBoundaryConditions();
           // calculate velocity from gradient of pressure
    	U = fvc::grad(p)*dimensionedScalar("tmp", dimTime, 1.);
    	runTime.write();
    疑惑的是在p.correctBoundaryConditions();上一行有NOTE提醒需要执行p.correctBoundaryConditions();,否则计算p的梯度时会有问题。但是我在icoFoam中没有找到
    p.correctBoundaryConditions();,只有U.correctBoundaryConditions();,而实际上在预测步里有用到fvc::grad(p).这是什么原因呢??
        #include "addCheckCaseOptions.H"
        #include "setRootCase.H"
        #include "createTime.H"
        #include "createMesh.H"
        pisoControl piso(mesh);
        #include "createFields.H"
        #include "initContinuityErrs.H"
        Info<< "\nStarting time loop\n" << endl;
            #include "CourantNo.H"
            // Momentum predictor
            fvVectorMatrix UEqn
                fvm::ddt(U)
              + fvm::div(phi, U)
              - fvm::laplacian(nu, U)
            if (piso.momentumPredictor())
                solve(UEqn == -fvc::grad(p));
            // --- PISO loop
            while (piso.correct())
                volScalarField rAU(1.0/UEqn.A());
                volVectorField HbyA(constrainHbyA(rAU*UEqn.H(), U, p));
                surfaceScalarField phiHbyA
                    "phiHbyA",
                    fvc::flux(HbyA)
                  + fvc::interpolate(rAU)*fvc::ddtCorr(U, phi)
                adjustPhi(phiHbyA, U, p);
                // Update the pressure BCs to ensure flux consistency
                constrainPressure(p, U, phiHbyA, rAU);
                // Non-orthogonal pressure corrector loop
                while (piso.correctNonOrthogonal())
                    // Pressure corrector
                    fvScalarMatrix pEqn
                        fvm::laplacian(rAU, p) == fvc::div(phiHbyA)
                    pEqn.setReference(pRefCell, pRefValue);
                    pEqn.solve(mesh.solver(p.select(piso.finalInnerIter())));
                    if (piso.finalNonOrthogonalIter())
                        phi = phiHbyA - pEqn.flux();
                #include "continuityErrs.H"
                U = HbyA - rAU*fvc::grad(p);
            runTime.write();
            runTime.printExecutionTime(Info);
        Info<< "End\n" << endl;
        return 0;
    MicroM 1 条回复 最后回复
    =等号类似的操作都需要correctBoundaryConditions(),solve()出来的都不需要
    S 2 条回复 最后回复
    Samuel-Tu
    @东岳 谢谢:baobao:
    Samuel-Tu
    @东岳 东岳老师,现在我有点拿不准,我先建立了一个体积力f的体心场,然后利用速度U计算出体积力f,最后需要用体积力f插值成面心场phiF
    f=U*系数;
    surfaceScalarField phiF
        "pihF",
        fvc::flux(rAU*f)
    计算f=U*系数后,是否还需要更新f的边界呢
    如果f就是f=U*系数,就不需要。
    如果f是你需要更新边界的场,就需要,否则U*系数会抹掉你的边界信息
    Samuel-Tu
    @东岳 谢谢老师,我想了下应该要更新边界。因为计算surfaceScalarField的时候,并行计算切割区域的边界面上的surfaceScalarField计算需要f的边界场,不像内部面可以通过fvc::interpolate把体心场插值成面心场
  • MicroM 离线
    MicroM 离线
    Micro
    在 中回复了 Samuel-Tu 最后由 编辑
    @samuel-tu =等号类似的操作都需要correctBoundaryConditions()
    @李东岳 请问岳哥,为啥 = 号等类似的操作都需要显式更新下边条呢?能不能稍微解释下,感谢!
