  3. 并行时函数只能在processor0执行
7 帖子 5 发布者 6.2k 浏览
    huiCfd
    Hello,各位大神,
    我在用我自己写的一个求解器并行计算时出现了一个奇怪的问题。这个问题只有在并行计算的时候才会出来,当不并行时没事。问题的具体描述如下:
    在我的solver中有一个名为 updateVelocity 的成员函数来获取计算域中某观察点(这个观察点的位置可能会随着时间改变)的速度。
    具体如下:
        while (runTime.loop())
            Info << "Time = " << runTime.timeName() << nl << endl;
                #include "CourantNo.H"
            // Pressure-velocity PISO corrector
                #include "UEqn.H"
                // --- PISO loop
                while (piso.correct())
                     #include "pEqn.H"
            laminarTransport.correct();
            turbulence->correct();
            //>>>>>>>>>>>>>Below>>>>>>>
            Nettings.updateVelocity(U,mesh);
            //<<<<<<<<<<<<<Above<<<<<<
            runTime.write();
            Info << "ExecutionTime = " << runTime.elapsedCpuTime() << " s"
                 << "  ClockTime = " << runTime.elapsedClockTime() << " s"
                 << nl << endl;
        Info << "End\n"
             << endl;
        return 0;
    这个函数的源代码如下,具体实现形式就是判断每个cell的中心到观察点的距离,然后取出距离观察点距离最近的cell的速度
    void Foam::netPanel::updateVelocity(
        const volVectorField &U,
        const fvMesh &mesh)
        const vectorField &centres(mesh.C());
        List<vector> fluidVelocities(structuralElements_memb.size(), vector::zero);
        Info << "In updateVelocity, number of mesh is " << centres.size() << endl;
        Info << "In updateVelocity, number of U is " << U.size() << endl;
        scalar maxDistance(1);
        forAll(EPcenter, Elemi)
            maxDistance = 1;
            vector nearestCell(vector::zero);
            scalar loops(0);
            forAll(centres, cellI) // loop through all the cells,
                scalar k1(calcDist(centres[cellI], EPcenter[Elemi]));
                if (k1 < maxDistance)
                    maxDistance = k1;
                    fluidVelocities[Elemi] = U[cellI];
                    nearestCell = centres[cellI];
                    loops += 1;
                    Info << "After " << loops << " times of loop, the nearest cell is " << nearestCell << "to point " << EPcenter << "\n"
                         << endl;
        fluidVelocity_memb = fluidVelocities; // only assige onece
        Info << "the velocity on nodes are  " << fluidVelocity_memb << endl;
    就是这样的一个简单的函数,但是在并行时却出现了问题。
    首先我们来看串行计算的情况:
    Starting time loop
    Time = 0.01
    Courant Number mean: 0.000565 max: 0.0904
    smoothSolver:  Solving for Ux, Initial residual = 1, Final residual = 2.4007e-06, No Iterations 1
    smoothSolver:  Solving for Uy, Initial residual = 0.891308, Final residual = 1.23902e-06, No Iterations 1
    smoothSolver:  Solving for Uz, Initial residual = 0.895257, Final residual = 1.31102e-06, No Iterations 1
    GAMG:  Solving for p, Initial residual = 1, Final residual = 8.40918e-07, No Iterations 35
    time step continuity errors : sum local = 9.50237e-10, global = 1.27782e-10, cumulative = 1.27782e-10
    smoothSolver:  Solving for epsilon, Initial residual = 1, Final residual = 0.00445555, No Iterations 1
    smoothSolver:  Solving for k, Initial residual = 1, Final residual = 0.004493, No Iterations 1
    In updateVelocity, number of mesh is 184320
    In updateVelocity, number of U is 184320
    After 1 times of loop, the nearest cell is (-0.49375 -0.21875 -0.39375)to point (0 0.05 -0.1)
    After 45 times of loop, the nearest cell is (-0.00625 0.05625 -0.20625)to point (0 0.05 -0.2)
    the velocity on nodes are  4((0.226059 -2.8946e-08 -3.59708e-08) (0.226059 3.97379e-08 -4.07855e-08) (0.226059 2.65165e-08 -2.22689e-08) (0.226059 -4.12251e-08 -1.8172e-08))
    ExecutionTime = 2.31 s  ClockTime = 2 s
    计算的结果没有任何问题,上面的updateVelocity函数也能够顺利的找到4个特定观察点的速度。
    但是问题来啦,如果并行计算的话,updateVelocity就没法找到这4个特定观察点的速度了。
    Starting time loop
    Time = 0.01
    Current Number means: 0.000565 max: 0.0904
    smoothSolver:  Solving for Uy, Initial residual = 0.892185, Final residual = 1.24606e-06, No Iterations 1
    smoothSolver:  Solving for Uz, Initial residual = 0.895991, Final residual = 1.31577e-06, No Iterations 1
    GAMG:  Solving for p, Initial residual = 1, Final residual = 9.93486e-07, No Iterations 34
    time step continuity errors : sum local = 1.12264e-09, global = -1.18173e-10, cumulative = -1.18173e-10
    smoothSolver:  Solving for epsilon, Initial residual = 1, Final residual = 0.0107252, No Iterations 1
    smoothSolver:  Solving for k, Initial residual = 1, Final residual = 0.0106817, No Iterations 1
    In updateVelocity, number of mesh is 23177
    In updateVelocity, number of U is 23177
    the velocity on nodes are  4{(0 0 0)}
    ExecutionTime = 0.57 s  ClockTime = 1 s
    并行和串行用的是同统一套网格,并行是用 scotch方法分成了八个subdomains
    值得注意的是:
    在串行计算中:In updateVelocity, number of mesh is 184320
    在并行计算中:In updateVelocity, number of mesh is 23177
    其中23177就是在processor0中的cell数,下面的是在processor0内的U文件
    FoamFile
        version     2.0;
        format      ascii;
        class       volVectorField;
        location    "0.1";
        object      U;
    internalField   nonuniform List<vector>
    23177
    (0.225112 5.13224e-05 2.5452e-05)
    也就是说,在并行时这个函数只读入梁processor0里面的速度和网格,其他processor1、2、3... 均没有放进来。
    请问各位大神有没有人遇到过类似的情况?
    新 1 条回复 最后回复
    huiCfd
    processor零,不是o。因为字体原因,0和o看起来很像。:zoule:
    是的,当你用多个processor的时候,每个processor处理的网格数量不一样,我看你用了cellI这种循环,如果单核,一共100个网格,有100个标志,但是4核只有25个
    H 1 条回复 最后回复
    huiCfd
    @东岳 感谢东岳老师回复,请问应该用何种循环 才能在并行时 对所有的cell进行计算呢?
    因为并行计算时,函数只在第一个processor里面的domain进行了循环,而所求观测点不在第一个processor的domain里,所以该函数无法返回符合要求的速度。如果要让该函数在其他proessor下也进行循环的话我应该如何修改?或者我应该看哪方面的资料来解决这个问题。
    谢谢
  • 金 离线
    金 离线
    金哲飞
    你好老师~我也遇到了类似问题,用forall循环遍历每个网格,并进行累加操作。单核没有问题,多核就卡住,不报错也不继续。请问老师问题解决了吗~
  • 新 离线
    新 离线
    新喻庸
    在 中回复了 huiCfd 最后由 编辑
    @huicfd 并行时每个进程完成该进程的任务,这是只输出了0号进程(openfoam好像默认该进程为master prosessor),而其他进程的结果没有输出。要获取其他进程计算得到的数据,需要同时使用open foam中的Pstrean::gatherList函数和Pstream::scatterList函数进行数据同步。
    贴一段我的测试代码,希望对你有帮助。
    if ( Pstream::parRun() )
        List<scalarField> test(Pstream::nProcs());
        test[Pstream::myProcNo()].setSize(3, Pstream::myProcNo());
        Pstream::gatherList<scalarField>(test);
        Pstream::scatterList(test);
        // Pout << test << endl;
        List<scalar> numcell(Pstream::nProcs());
        numcell[Pstream::myProcNo()] = mesh.nCells();
        Pstream::gatherList<scalar>(numcell);
        Pstream::scatterList<scalar>(numcell);
        // reduce( numcell, sumOp<List<scalar> >() );
        reduce( nCells, sumOp<scalar>() );
        // Pout << "CPU = " << Pstream::myProcNo() << ", masterProcNo = "
        // << Pstream::masterNo() << endl;
        if ( Pstream::master() )
            scalar size = 0.0;
            for ( label procI=0; procI<Pstream::nProcs(); procI++ )
                size += numcell[procI];
            // Pout << "grid size = " << size << endl;
            // Pout << "Cell size in each Process is " << numcell
            // << ", Total cell size = " << nCells << endl;
    cresendo
    在 中回复了 新喻庸 最后由 编辑
    接楼上的发言,Info在并行时只会输出master processor的信息,所以把Info改成Pout应该就可以了
