  3. 编译失败求助
编译失败求助
4 帖子 2 发布者 3.4k 浏览
    Samuel-Tu
    想实现更改每个单元的粘度的功能,于是在laminarTransport的类singlePhaseTransportModel.H中加入了
    virtual void crtMyNu(const labelUList& myList,scalar myNu);
    目的是为了在simpleFoam里面可以调用laminarTransport.crtMyNu(),输入单元编号的List,和想改成的数值myNu;
    然后在Newtonian.H 里加入
                           forAll(myList,i)
                               label cellI=myList[i];
                                 this->nu_[cellI]=myNu;
    实现对nu_的具体修改。
    编译libincompressibleTransportModels时没有错误
    但是在simpleFOAM.C中加入
    laminarTransport.crtMyNu(solidCells,scalar(10000));
    后,编译simpleFOAM时报错
    -lm -o /home/samuel/OpenFOAM/samuel-v1806/platforms/linux64GccDPInt64Opt/bin/GCSimpleFoam
    Make/linux64GccDPInt64Opt/GCSimpleFoam.o: In function `main':
    GCSimpleFoam.C:(.text.startup+0x3748): undefined reference to `Foam::singlePhaseTransportModel::crtMyNu(Foam::UList<long> const&, double)'
    /home/samuel/OpenFOAM/OpenFOAM-v1806/wmake/makefiles/general:136: recipe for target '/home/samuel/OpenFOAM/samuel-v1806/platforms/linux64GccDPInt64Opt/bin/GCSimpleFoam' failed
    make: *** [/home/samuel/OpenFOAM/samuel-v1806/platforms/linux64GccDPInt64Opt/bin/GCSimpleFoam] Error 1
    编译错误的原因是什么呢?搞不懂。。
    wwzhao 超神
    在 中回复了 Samuel-Tu 最后由 编辑
    @Samuel-Tu 在 编译失败求助 中说:
    这句改成 void singlePhaseTransportModel::crtMyNu(const labelUList& myList,scalar myNu) 试试?
    Samuel-Tu
    在 中回复了 wwzhao 最后由 编辑
    @wwzhao 在Newtonian.H里加吗,singlePhaseTransportModel类编译不通过了。
    In file included from viscosityModels/Newtonian/Newtonian.C:26:0:
    viscosityModels/Newtonian/Newtonian.H:110:14: error: ‘singlePhaseTransportModel’ has not been declared
    /home/samuel/OpenFOAM/OpenFOAM-v1806/wmake/rules/General/transform:34: recipe for target '/home/samuel/OpenFOAM/OpenFOAM-v1806/build/linux64GccDPInt64Opt/src/transportModels/incompressible/viscosityModels/Newtonian/Newtonian.o' failed
    make: *** [/home/samuel/OpenFOAM/OpenFOAM-v1806/build/linux64GccDPInt64Opt/src/transportModels/incompressible/viscosityModels/Newtonian/Newtonian.o] Error 1
    Samuel-Tu
    好像发现原因了,Newtonian没有从singlePhaseTransportMode继承,因此如果在singlePhaseTransportMode中定义虚函数是不行的
