  4. LPT-VOF coupling in OF 7
3 帖子 2 发布者 5.0k 浏览
  • Q 离线
    Q 离线
    qingdong_wang
    大家好, 现在在做LPT和VOF耦合, 既把solidParticle植入到interFoam中。 我现在有的参考还是chamlers根据openFoam 3.0 做的, 但是他在OF7 中并不匹配
    void Foam::solidParticleCloud::inject(solidParticle::trackingData &td)
    label cellI=1;
    label tetFaceI=1;
    label tetPtI=1;
    mesh_.findCellFacePt(td.cloud().posP1_, cellI, tetFaceI, tetPtI);
    solidParticle* ptr1 = new solidParticle(mesh_, td.cloud().posP1_, cellI,
    tetFaceI, tetPtI,td.cloud().dP1_, td.cloud().UP1_);
    Cloud<solidParticle>::addParticle(ptr1);
    mesh_.findCellFacePt(td.cloud().posP2_, cellI, tetFaceI, tetPtI);
    solidParticle* ptr2 = new solidParticle(mesh_, td.cloud().posP2_, cellI,
    tetFaceI, tetPtI, td.cloud().dP2_, td.cloud().UP2_);
    Cloud<solidParticle>::addParticle(ptr2);
    这个是加入到solidParticleCloud.H 的代码, 然后显示member function cloud 不存在,然后我去看了particle.H 中的代码,
    class particle
        public IDLList<particle>::link
        // Private member data
            //- Size in bytes of the position data
            static const std::size_t sizeofPosition_;
            //- Size in bytes of the fields
            static const std::size_t sizeofFields_;
            //- The factor by which the displacement is increased when passing
            //  through negative space. This should be slightly bigger than one.
            //  This is needed as a straight trajectory can form a closed loop
            //  through regions of overlapping positive and negative space, leading
            //  to a track which never ends. By increasing the rate of displacement
            //  through negative regions, the change in track fraction over this
            //  part of the loop no longer exactly cancels the change over the
            //  positive part, and the track therefore terminates.
            static const scalar negativeSpaceDisplacementFactor;
    public:
        class trackingData
        public:
            // Public data
                //- Flag to switch processor
                bool switchProcessor;
                //- Flag to indicate whether to keep particle (false = delete)
                bool keepParticle;
            // Constructor
            template <class TrackCloudType>
            trackingData(const TrackCloudType& cloud)
    发现trackingData已经没有private成员和member function了,OF5中还是有的, 如下
    class particle
    public:
        template<class CloudType>
        class TrackingData
            // Private data
                //- Reference to the cloud containing (this) particle
                CloudType& cloud_;
        public:
            // Public data
                typedef CloudType cloudType;
                bool keepParticle;
            // Constructor
            TrackingData(CloudType& cloud)
                cloud_(cloud)
            // Member functions
                //- Return a reference to the cloud
                CloudType& cloud()
                    return cloud_;
    我看官方貌似对particle和injection做了挺多改变的。请问一下有大神对这个有所涉及或者可以给个hint吗?
    你可以直接用MPPICInterFoam试试
    Q 1 条回复 最后回复
  • Q 离线
    Q 离线
    qingdong_wang
    @东岳 但是那个貌似是在v1906这种版本,我现在用的是OpenFoam 7, 貌似没有MPPICInterFoam
