  4. 尝试添加一段代码来求颗粒浓度,wmake出错,大神帮忙看看哪里出问题?
5 帖子 2 发布者 8.3k 浏览
  • chpjz0391C 离线
    chpjz0391C 离线
    chpjz0391
    写于 最后由 CFD中文网 编辑
    基于simpleReactingParcelFoam改的主程序:
    #include "fvCFD.H"
    #include "turbulentFluidThermoModel.H"
    #include "basicReactingMultiphaseCloud.H"
    #include "rhoCombustionModel.H"
    #include "radiationModel.H"
    #include "IOporosityModelList.H"
    #include "fvIOoptionList.H"
    #include "SLGThermo.H"
    #include "simpleControl.H"
    #include "basicKinematicCloud.H"
        #include "setRootCase.H"
        #include "createTime.H"
        #include "createMesh.H"
        #include "readGravitationalAcceleration.H"
        simpleControl simple(mesh);
        #include "createFields.H"
        #include "createRadiationModel.H"
        #include "createClouds.H"
        #include "createMRF.H"
        #include "createFvOptions.H"
        #include "initContinuityErrs.H"
    /*#############################use parcelType#####################*/
    //typedef typename basicKinematicTypeCloud::particleType parcelType;
    /*#############################end################################*/
        Info<< "\nStarting time loop\n" << endl;
        while (simple.loop())
            Info<< "Time = " << runTime.timeName() << nl << endl;
            parcels.evolve();
            // --- Pressure-velocity SIMPLE corrector loop
             /*   #include "UEqn.H"
                #include "YEqn.H"
                #include "EEqn.H"
                #include "pEqn.H" */
        /*#################calculate the particle concentration, begin.(下面是自己添加的code)################*/
        forAllConstIter(typename basicKinematicTypeCloud, kinematicCloud, iter)
            const parcelType& p = iter();
            const label cellI = p.cell();
            pmc[cellI]+=p.nParticles()*p.mass0();
            pmc /=mesh().V();
         /*#################calculate the particle concentration, end.################*/
            turbulence->correct();
            runTime.write();
            Info<< "ExecutionTime = " << runTime.elapsedCpuTime() << " s"
                << "  ClockTime = " << runTime.elapsedClockTime() << " s"
                << nl << endl;
        Info<< "End\n" << endl;
        return 0;
    下面是creatFields.H的文件
    Info<< "Creating combustion model\n" << endl;
    autoPtr<combustionModels::rhoCombustionModel> combustion
        combustionModels::rhoCombustionModel::New(mesh)
    rhoReactionThermo& thermo = combustion->thermo();
    thermo.validate(args.executable(), "h", "e");
    SLGThermo slgThermo(mesh, thermo);
    basicSpecieMixture& composition = thermo.composition();
    PtrList<volScalarField>& Y = composition.Y();
    const word inertSpecie(thermo.lookup("inertSpecie"));
    if (!composition.contains(inertSpecie))
        FatalErrorIn(args.executable())
            << "Specified inert specie '" << inertSpecie << "' not found in "
            << "species list. Available species:" << composition.species()
            << exit(FatalError);
    volScalarField& p = thermo.p();
    const volScalarField& T = thermo.T();
    const volScalarField& psi = thermo.psi();
    volScalarField rho
        IOobject
            "rho",
            runTime.timeName(),
            mesh,
            IOobject::NO_READ,
            IOobject::AUTO_WRITE
        thermo.rho()
    Info<< "\nReading field U\n" << endl;
    volVectorField U
        IOobject
            "U",
            runTime.timeName(),
            mesh,
            IOobject::MUST_READ,
        mesh
        Info<< "Reading field pmc\n" << endl;
        volScalarField pmc
            IOobject
                "pmc",
                runTime.timeName(),
                mesh,
                IOobject::READ_IF_PRESENT,
            mesh
    	/*##########################construct solid concentration field.mass  of the lagrangian particle [kg/(m^3)]##############*/
    #include "compressibleCreatePhi.H"
    mesh.setFluxRequired(p.name());
    dimensionedScalar rhoMax
        dimensionedScalar::lookupOrDefault
            "rhoMax",
            simple.dict(),
            dimDensity,
            GREAT
    dimensionedScalar rhoMin
            "rhoMin",
            simple.dict(),
            dimDensity,
    Info<< "Creating turbulence model\n" << endl;
    autoPtr<compressible::turbulenceModel> turbulence
        compressible::turbulenceModel::New
            rho,
            U,
            phi,
            thermo
    // Set the turbulence into the combustion model
    combustion->setTurbulence(turbulence());
    Info<< "Creating multi-variate interpolation scheme\n" << endl;
    multivariateSurfaceInterpolationScheme<scalar>::fieldTable fields;
    forAll(Y, i)
        fields.add(Y[i]);
    fields.add(thermo.he());
    volScalarField dQ
        IOobject
            "dQ",
            runTime.timeName(),
            mesh,
            IOobject::NO_READ,
        mesh,
        dimensionedScalar("dQ", dimEnergy/dimTime, 0.0)
    请问程序哪里有问题,大神可以指出来么?
  • chpjz0391C 离线
    chpjz0391C 离线
    chpjz0391
    写于 最后由 CFD中文网 编辑
    simpleParticlesFoam.C: In function ‘int main(int, char**)’:
    /opt/openfoam30/src/OpenFOAM/lnInclude/UList.H:465:18: error: invalid type in declaration before ‘::’ token
             Container::const_iterator iter = (container).begin();                  \
    simpleParticlesFoam.C:89:5: note: in expansion of macro ‘forAllConstIter’
    /opt/openfoam30/src/OpenFOAM/lnInclude/UList.H:465:18: error: expected ‘;’ before ‘::’ token
    /opt/openfoam30/src/OpenFOAM/lnInclude/UList.H:465:18: error: ‘::const_iterator’ has not been declared
    simpleParticlesFoam.C:89:71: error: expected ‘;’ before ‘iter’
    /opt/openfoam30/src/OpenFOAM/lnInclude/UList.H:465:35: note: in definition of macro ‘forAllConstIter’
    simpleParticlesFoam.C:89:71: error: ‘iter’ was not declared in this scope
    /opt/openfoam30/src/OpenFOAM/lnInclude/UList.H:465:52: error: expected primary-expression before ‘)’ token
    /opt/openfoam30/src/OpenFOAM/lnInclude/UList.H:465:61: error: expected ‘)’ before ‘;’ token
    simpleParticlesFoam.C:89:30: warning: unused variable ‘basicKinematicTypeCloud’ [-Wunused-variable]
    /opt/openfoam30/src/OpenFOAM/lnInclude/UList.H:465:9: note: in definition of macro ‘forAllConstIter’
    /opt/openfoam30/src/OpenFOAM/lnInclude/UList.H:466:9: note: in definition of macro ‘forAllConstIter’
             iter != (container).end();                                             \
    /opt/openfoam30/src/OpenFOAM/lnInclude/UList.H:466:27: error: expected primary-expression before ‘)’ token
    /opt/openfoam30/src/OpenFOAM/lnInclude/UList.H:468:5: error: expected ‘;’ before ‘)’ token
    simpleParticlesFoam.C:97:20: error: no match for call to ‘(Foam::fvMesh) ()’
             pmc /=mesh().V();
    In file included from /opt/openfoam30/src/finiteVolume/lnInclude/fvCFD.H:7:0,
                     from simpleParticlesFoam.C:34:
    /opt/openfoam30/src/finiteVolume/lnInclude/fvMesh.H:79:7: note: candidate is:
     class fvMesh
    In file included from /opt/openfoam30/src/OpenFOAM/lnInclude/HashTable.H:549:0,
                     from /opt/openfoam30/src/OpenFOAM/lnInclude/runTimeSelectionTables.H:41,
                     from /opt/openfoam30/src/OpenFOAM/lnInclude/token.H:49,
                     from /opt/openfoam30/src/OpenFOAM/lnInclude/UListIO.C:28,
                     from /opt/openfoam30/src/OpenFOAM/lnInclude/UList.C:225,
                     from /opt/openfoam30/src/OpenFOAM/lnInclude/UList.H:474,
                     from /opt/openfoam30/src/OpenFOAM/lnInclude/List.H:43,
                     from /opt/openfoam30/src/OpenFOAM/lnInclude/labelList.H:48,
                     from /opt/openfoam30/src/OpenFOAM/lnInclude/UPstream.H:42,
                     from /opt/openfoam30/src/OpenFOAM/lnInclude/Pstream.H:42,
                     from /opt/openfoam30/src/OpenFOAM/lnInclude/parRun.H:35,
                     from /opt/openfoam30/src/finiteVolume/lnInclude/fvCFD.H:4,
    /opt/openfoam30/src/OpenFOAM/lnInclude/HashTableI.H:145:11: note: T& Foam::HashTable<T, Key, Hash>::operator()(const Key&) [with T = Foam::regIOobject*; Key = Foam::word; Hash = Foam::string::hash]
     inline T& Foam::HashTable<T, Key, Hash>::operator()(const Key& key)
    /opt/openfoam30/src/OpenFOAM/lnInclude/HashTableI.H:145:11: note:   candidate expects 1 argument, 0 provided
    In file included from simpleParticlesFoam.C:57:0:
    createFields.H:27:23: warning: unused variable ‘T’ [-Wunused-variable]
    createFields.H:28:23: warning: unused variable ‘psi’ [-Wunused-variable]
    In file included from simpleParticlesFoam.C:62:0:
    /opt/openfoam30/src/finiteVolume/lnInclude/initContinuityErrs.H:37:8: warning: unused variable ‘cumulativeContErr’ [-Wunused-variable]
     scalar cumulativeContErr = 0;
    make: *** [Make/linux64GccDPInt32Opt/simpleParticlesFoam.o] Error 1
    Check this:
              define forAllConstIter(Container,container,iter)
      473     for
      474     (
      475         Container::const_iterator iter = (container).begin();
      476         iter != (container).end();
      477         ++iter
      478     )
    in UList_H.
    并没有看到相关的basicKinematicTypeCloud声明:
    kinematicCloud是basicKinematicTypeCloud的具体类么?
    CFD中国标准用户测试帐号
    目前由徐笑笑登录
    chpjz0391C 1 条回复 最后回复
  • chpjz0391C 离线
    chpjz0391C 离线
    chpjz0391
    这是之前别人给我的一段code,我根据自己需求改了下放到了我的求解器里。 对C++不太了解。 应该怎么改的?@cfd-china
  • chpjz0391C 离线
    chpjz0391C 离线
    chpjz0391
    在 中回复了 CFD中文网 最后由 编辑
    @cfd-china 这个东西之前是写给DPMFoam的。。然后我搬到我这边了。。就出现这样了。
