  4. 请教一个并行运算的问题
请教一个并行运算的问题
5 帖子 2 发布者 6.7k 浏览
    CFDngu
    以代码为例,在一个函数中有如下代码
    	DynamicList<label> CellLabel;
    	DynamicList<scalar> CellCenterX;
    	DynamicList<scalar> CellCenterZ;
    	//markfield 是一个volScalarField, 一部分为0,另一部分为1
            //我想得到markfield[i] = 1网格的网格编号和中心点x,z坐标
    	forAll(markField_, i)
    		if(markField_[i])
    			CellLabel.append(i);
    			CellCenterX.append(mesh_.C()[i].component(0));
    			CellCenterZ.append(mesh_.C()[i].component(2));
           forAll(CellLabel, i) //输出
    	 Info << "i = " << CellLabel[i] << ", " << CellCenterX[i] << ", " << CellCenterZ[i] <<endl;;
    此代码在单核运行时无问题,输出的结果类似:
    i = 20287, 2.4625, -0.39375
    i = 20288, 2.4625, -0.39125
    i = 20289, 2.4625, -0.39875
    i = 20290, 2.4625, -0.39625
    i = 20589, 2.4625, -0.38625
    i = 20590, 2.4625, -0.38875
    i = 20612, 2.4625, -0.38375
    i = 20613, 2.4625, -0.38125
    i = 20614, 2.4675, -0.39375
    i = 20615, 2.4675, -0.39125
    i = 20616, 2.4675, -0.39875
    i = 20617, 2.4675, -0.39625
    然而在并行时出现问题,直接报错
    [wdx-Precision-7920-Tower:06322] *** Process received signal ***
    [wdx-Precision-7920-Tower:06322] Signal: Segmentation fault (11)
    [wdx-Precision-7920-Tower:06322] Signal code:  (-6)
    [wdx-Precision-7920-Tower:06322] Failing at address: 0x3e8000018b2
    [wdx-Precision-7920-Tower:06322] [ 0] /lib/x86_64-linux-gnu/libc.so.6(+0x3ef20)[0x7fd0451a0f20]
    [wdx-Precision-7920-Tower:06322] [ 1] /lib/x86_64-linux-gnu/libc.so.6(gsignal+0xc7)[0x7fd0451a0e97]
    [wdx-Precision-7920-Tower:06322] [ 2] /lib/x86_64-linux-gnu/libc.so.6(+0x3ef20)[0x7fd0451a0f20]
    [wdx-Precision-7920-Tower:06322] [ 3] /home/wdx/OpenFOAM-6/platforms/linux64GccDPInt32Opt/lib/libMassSource.so(_ZN4Foam19massSourceWaveMaker15CalDynamicListsEv+0x316)[0x7fd04750cb96]
    [wdx-Precision-7920-Tower:06322] [ 4] /home/wdx/OpenFOAM-6/platforms/linux64GccDPInt32Opt/lib/libMassSource.so(_ZN4Foam19massSourceWaveMakerC1ERKNS_12IOdictionaryERNS_14GeometricFieldIdNS_12fvPatchFieldENS_7volMeshEEES8_RNS4_INS_6VectorIdEES5_S6_EE+0x9c3)[0x7fd04750e053]
    [wdx-Precision-7920-Tower:06322] [ 5] DXFlow(+0x4941a)[0x5557003bc41a]
    [wdx-Precision-7920-Tower:06322] [ 6] [wdx-Precision-7920-Tower:06316] *** Process received signal ***
    /lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0xe7)[0x7fd045183b97]
    [wdx-Precision-7920-Tower:06322] [ 7] [wdx-Precision-7920-Tower:06316] Signal: Segmentation fault (11)
    [wdx-Precision-7920-Tower:06316] Signal code:  (-6)
    [wdx-Precision-7920-Tower:06316] Failing at address: 0x3e8000018ac
    DXFlow(+0x57a9a)[0x5557003caa9a]
    错误出现在访问动态数组的时候(即输出的时候),查了查是内存访问的问题。我觉得主要原因应该是缺少并行语句,我对MPI编程了解很有限,只大概了解reduce这个函数,但是了解的也不深。我也查了些资料,发现这个比较有参考价值:这里。
    然而我还是没有解决现在的问题,所以来请教一下大家,或者谁能提供一点OF中MPI函数的资料?
    谢谢大家!
    Samuel-Tu
    并行输出用pout,用Info的话只输出主核里的信息,另外并行的网格编号是在decomposed的子块里面的网格编号,和你最后reconstruct后的网格编号不一样
    CFDngu
    在 中回复了 Samuel-Tu 最后由 编辑
    @Samuel-Tu
    你好,感谢你的回复,你说的内容我之前有过了解,Pout可以输出所有processor的信息,每个网格有自己的编号。
    可能是我描述问题不够精确,我换一个说法。
    程序流程如下:
    1、我创建了一个空容器,根据网格位置信息选定某一区域的网格,向容器里面添加元素(网格编号);
    2、后续对这个容器进行操作,因此这个容器不能为空
    这个程序在单核的时候没有问题,寻找网格编号算法无误。但是并行时出现了问题,由于计算域被分块,并不是所有processor上的网格位置信息都位于目标区域,不包含目标网格的processor不会进行添加元素的操作,这样就导致在不同的processor之间有不同大小的容器,因此并行时会出现发散的情况。
    我现在想尝试将所有的容器进行gather和scatter操作,但是没有成功,不知谁能给我点建议?谢谢
    S 2 条回复 最后回复
    Samuel-Tu
    在 中回复了 CFDngu 最后由 编辑
    @CFDngu 我觉得不是因为不同处理器之间容器大小不同导致的算不了。因为我以前也做过类似的操作,计算没有任何问题。
    不过你想把各个部分的动态列表放在一起也许是可行的,我记得有一个命令是可以把某一个处理器里面的数据全局共享的,我搞忘了好像就是reduce,明天我翻一下我的代码。。
    你是否运算过OF的并行算例。有时候没安装好是不能进行并行的,我以前用Windows子系统就没法并行。。
    Samuel-Tu
    @CFDngu 而且forAll操作可以对空容器进行吧。。实在不行你可以给每个空容器加入第一个数-1,而网格编号不可能小于0,你循环的时候判断下网格编号是不是小于0就行了
