  3. 关于稳态欧拉-拉格朗日计算速度的探讨
关于稳态欧拉-拉格朗日计算速度的探讨
4 帖子 2 发布者 3.8k 浏览
  • 液 离线
    液 离线
    液固两相流
    目前我在采用稳态的欧拉拉格朗日求解器,求解水轮机的磨损问题,颗粒数为50000,网格数为1100w左右。颗粒文件的设置如下:```
    code_text
    solution
        active          true;
        calcFrequency   15;
        maxTrackTime    6;
        maxCo           0.6;
        coupled         true;
        cellValueSourceCorrection off; //suggested to be off
        interpolationSchemes
           Urel      	cellPoint;		//U for water
           rho     		cell;	 		//rho of water
           mu      		cell;			 //mu of water
           DUcDt        cell;	 		//DUcDt of water
        integrationSchemes
            U               Euler;
        sourceTerms
         resetOnStartup false;
            schemes
                U semiImplicit 1;
    constantProperties
        rho0 2650;	//the density for the particle
    subModels
        particleForces
            sphereDrag; //drag forces
            gravity;  // gravity force
    		pressureGradient //pressure gradient force
    		  U   Urel;
    		virtualMass    //virtual mass force
    		  Cvm   0.5;
    		MRF
    		 omega (0 0 -104.72);
    		 centreOfRotation (0 0 0);
    		 Ctemp	MRFC;
        injectionModels
            model1
    		 type					patchInjection;
             parcelBasisType   		fixed;
             patchName        		INLET_SV;
             U0                		(0 0 0);
    		 nParticle          	420;
    		 duration            	1;
    		 parcelsPerSecond		50000;
             flowRateProfile 		constant 1;
    		 massFlowRate     		 0;
    		 //positionsFile   		"kinematicCloudPositions";
                sizeDistribution
                    type        fixedValue;
                    fixedValueDistribution
                        value   0.0002;//m
        dispersionModel stochasticDispersionRAS;
        patchInteractionModel UserLocalInteraction;
        //using the tabakoff rebound model
        UserLocalInteractionCoeffs
            patches
                    type rebound;
    				reboundModel 2;
                OUTLET_SC
                    type none;
                INLET_SV
                    type escape;
                OUTLET_SV
                    type none;
                INLET_GV
                    type none;
                OUTLET_GV
                    type none;
                INLET_RUN
                    type none;
                OUTLET_RUN
                    type none;
                INLET_DT
                    type none;
                INLET_SC
                    type none;
                OUTLET_DT
                    type escape;
        heatTransferModel none;
        surfaceFilmModel none;
        collisionModel none;
        stochasticCollisionModel none;
        radiation off;
    流场迭代15步之后,会进行颗粒的迭代,颗粒计算平均耗时5min。
    但每次计算至210步时,颗粒就算不动了(前面的颗粒计算均是正常的)。
    我如果把颗粒数降至10000,计算至750步,颗粒就算不动了。
    请问一下大家又碰到这类问题吗?有什么比较好的解决办法吗?
    发代表性网格截面看一下
    液 1 条回复 最后回复
  • 液 离线
    液 离线
    液固两相流
    @东岳
    我的网格有多个交界面(用的是cyclicAMI),交界面对于拉格朗日的计算会有影响吗?
    很有可能,cyclicAMI有可能把粒子算丢了
