  3. calculated 边界条件怎么用?有谁知道啊?
7 帖子 2 发布者 12.4k 浏览
  • M 离线
    M 离线
    mark
    This boundary condition
    你不需要指定其他信息,这样即可:
    type calculated;
    CFD中国标准用户测试帐号
    目前由徐笑笑登录
  • M 离线
    M 离线
    mark
    FoamFile
    version 2.0;
    format ascii;
    class volScalarField;
    object p;
    dimensions [1 -1 -2 0 0 0 0];
    internalField uniform 3e+06;
    boundaryField
    INLET
    type calculated;
    WALL
        type            zeroGradient;
    OUTLET
        type            calculated;
  • M 离线
    M 离线
    mark
    FoamFile
    version 2.0;
    format ascii;
    object p_rgh;
    boundaryField
    INLET
    type fixedValue;
    value uniform 10e+06;
    WALL
        type            zeroGradient;
    OUTLET
        type            waveTransmissive;
        value           uniform 3e+06;
        field           p;
        gamma           1.17;
        phi             phi;
        rho             rho;
        psi             psi;
        lInf            0.05;
        fieldInf        3e+06;
  • M 离线
    M 离线
    mark
    PIMPLE: iteration 1
    #0 Foam::error::printStack(Foam::Ostream&) at ??:?
    #1 Foam::sigFpe::sigHandler(int) at ??:?
    #2 ? in "/lib/x86_64-linux-gnu/libc.so.6"
    #3 Foam::divide(Foam::Field<double>&, double const&, Foam::UList<double> const&) at ??:?
    #4 void Foam::divide<Foam::fvPatchField, Foam::volMesh>(Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>&, Foam::dimensioned<double> const&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&) at ??:?
    #5 Foam::tmp<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> > Foam::operator/<Foam::fvPatchField, Foam::volMesh>(Foam::dimensioned<double> const&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&) at ??:?
    #6 Foam::tmp<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> > Foam::operator/<Foam::fvPatchField, Foam::volMesh>(double const&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&) at ??:?
    #7 Foam::phaseChangeTwoPhaseMixture::vDotAlphal() const at ??:?
    #8 ? at ??:?
    #9 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6"
    #10 ? at ??:?
  • M 离线
    M 离线
    mark
    写于 最后由 mark 编辑
    这样设置好像不行啊@cfd-china
    在 中回复了 mark 最后由 编辑
    @mark
    这不是因为边界条件导致的哦。估计是除以0了:sunglasses:
    CFD中国标准用户测试帐号
    目前由徐笑笑登录
