源项类中的addSup函数是如何被调用的?
在各种源项类的声明和实现中经常能看到addSup函数,功能为将源项加入到控制方程中,如在actuationDiskSource.H中: //- Source term to momentum equation virtual void addSup ( fvMatrix<vector>& eqn, const label fieldi );那么请问这个addSup函数是在什么时候被调用的?找了很久没有找到。在网上查了一些资料,基本可以确定这个函数是在求解器形成U方程的时候被调用了,如在simpleFoam的UEqn.H中: tmp<fvVectorMatrix> tUEqn ( fvm::div(phi, U) + MRF.DDt(U) + turbulence->divDevSigma(U) == fvOptions(U) );大家都说fvOptions(U)就用到了addSup函数,可是这里addSup函数是如何被调用的?希望有大神能帮忙解答!
这是在application里抓的,在src里抓能抓到更多,但是多是定义而不是使用。 ./solvers/multiphase/compressibleInterFoam/compressibleInterFilmFoam/VoFSolidificationMeltingSource/VoFSolidificationMeltingSource.C:void Foam::fv::VoFSolidificationMeltingSource::addSup ./solvers/multiphase/compressibleInterFoam/compressibleInterFilmFoam/VoFSolidificationMeltingSource/VoFSolidificationMeltingSource.C:void Foam::fv::VoFSolidificationMeltingSource::addSup ./solvers/multiphase/compressibleInterFoam/compressibleInterFilmFoam/VoFSolidificationMeltingSource/VoFSolidificationMeltingSource.C:void Foam::fv::VoFSolidificationMeltingSource::addSup ./solvers/multiphase/compressibleInterFoam/compressibleInterFilmFoam/VoFSolidificationMeltingSource/VoFSolidificationMeltingSource.C:void Foam::fv::VoFSolidificationMeltingSource::addSup ./solvers/multiphase/compressibleInterFoam/compressibleInterFilmFoam/VoFSolidificationMeltingSource/VoFSolidificationMeltingSource.C: addSup(eqn, fieldi); ./solvers/multiphase/compressibleInterFoam/compressibleInterFilmFoam/VoFSolidificationMeltingSource/VoFSolidificationMeltingSource.H: virtual void addSup(fvMatrix<scalar>& eqn, const label fieldi); ./solvers/multiphase/compressibleInterFoam/compressibleInterFilmFoam/VoFSolidificationMeltingSource/VoFSolidificationMeltingSource.H: virtual void addSup(fvMatrix<vector>& eqn, const label fieldi); ./solvers/multiphase/compressibleInterFoam/compressibleInterFilmFoam/VoFSolidificationMeltingSource/VoFSolidificationMeltingSource.H: virtual void addSup ./solvers/multiphase/compressibleInterFoam/compressibleInterFilmFoam/VoFSolidificationMeltingSource/VoFSolidificationMeltingSource.H: virtual void addSup
fvOptions是一个fv::options类型的一个对象,fv::options类继承自optionList类。
 optionList类中含有一个包含所有源项的指针列表PtrList<option> 。optionList类中对operator()进行了运算符重载,函数体中遍历调用PtrList<option>中的每一个addSup函数。
 相关函数体的定义在fvOptionListTemplates.C中。template<class Type> Foam::tmp<Foam::fvMatrix<Type>> Foam::fv::optionList::operator() ( GeometricField<Type, fvPatchField, volMesh>& field, const word& fieldName ) { return source(field, fieldName, field.dimensions()/dimTime*dimVolume); }template<class Type> Foam::tmp<Foam::fvMatrix<Type>> Foam::fv::optionList::source ( GeometricField<Type, fvPatchField, volMesh>& field, const word& fieldName, const dimensionSet& ds ) { checkApplied(); tmp<fvMatrix<Type>> tmtx(new fvMatrix<Type>(field, ds)); fvMatrix<Type>& mtx = tmtx.ref(); forAll(*this, i) { option& source = this->operator[](i); label fieldi = source.applyToField(fieldName); if (fieldi != -1) { source.setApplied(fieldi); if (source.isActive()) { if (debug) { Info<< "Applying source " << source.name() << " to field " << fieldName << endl; } source.addSup(mtx, fieldi); } } } return tmtx; }
