  4. KEpsilon.C中k定义时使用的autoCreateK("k", mesh_)函数含义?
3 帖子 2 发布者 4.3k 浏览
  • strive_DUTS 离线
    strive_DUTS 离线
    strive_DUT
    最近在看湍流模型代码,发现一个小问题:比如在kEpsilon.C文件关于湍动能k的的定义:
    OpenFOAM的版本中(3.0以上)
    k_
            IOobject
                IOobject::groupName("k", U.group()),
                this->runTime_.timeName(),
                this->mesh_,
                IOobject::MUST_READ,
                IOobject::AUTO_WRITE
            this->mesh_
    foam-extend版本中(4.1)
    k_
            IOobject
                "k",
                U_.db(),
                IOobject::NO_READ,
    可以发现,OpenFOAM中k为MUST_READ,而foam-extend中k为NO_READ,但存在一个autoCreateK("k", mesh_)函数,其定义在backwardsCompatibilityWallFunctions.C中,代码如下:
    tmp<volScalarField> autoCreateK
        const word& fieldName,
        const fvMesh& mesh
        return
            autoCreateWallFunctionField
                scalar,
                RASModels::kqRWallFunctionFvPatchField<scalar>
                fieldName,
                mesh,
                mesh
    backwardsCompatibilityWallFunctionsTemplates.C中有autoCreateWallFunctionField的定义:
    template<class Type, class PatchType>
    tmp<GeometricField<Type, fvPatchField, volMesh> >
        const fvMesh& mesh,
        const objectRegistry& obj
        IOobject mutHeader
            "mut",
            mesh.time().timeName(),
            obj,
            IOobject::MUST_READ
        typedef GeometricField<Type, fvPatchField, volMesh> fieldType;//起了一个别名: fieldType
        if (mutHeader.headerOk())//如果找到了文件路径,并读取了文件头,则为true
            return tmp<fieldType>
                new fieldType
                    IOobject
                        fieldName,
                        obj,
                        IOobject::NO_WRITE,
                        false
                    mesh
        else //如果没有找到文件路径,或无法读取文件头,返回一个新的场
            Info<< "--> Upgrading " << fieldName
                << " to employ run-time selectable wall functions" << endl;
            // Read existing field
            IOobject ioObj
                fieldName,
                obj,
                IOobject::NO_WRITE,
                false
            tmp<fieldType> fieldOrig
                new fieldType
                    ioObj,
                    mesh
            // rename file
            Info<< "    Backup original " << fieldName << " to "
                << fieldName << ".old" << endl;
            mvBak(ioObj.objectPath(), "old");
            PtrList<fvPatchField<Type> > newPatchFields(mesh.boundary().size());
            forAll(newPatchFields, patchI)
                if (mesh.boundary()[patchI].isWall())
                    newPatchFields.set
                        patchI,
                        new PatchType
                            mesh.boundary()[patchI],
                            fieldOrig().dimensionedInternalField()
                    newPatchFields[patchI] == fieldOrig().boundaryField()[patchI];
                else
                    newPatchFields.set
                        patchI,
                        fieldOrig().boundaryField()[patchI].clone()
            tmp<fieldType> fieldNew
                new fieldType
                    IOobject
                        fieldName,
                        obj,
                        IOobject::NO_READ,
                        IOobject::NO_WRITE,
                        false
                    mesh,
                    fieldOrig().dimensions(),
                    fieldOrig().internalField(),
                    newPatchFields
            Info<< "    Writing updated " << fieldName << endl;
            fieldNew().write();
            return fieldNew;
    问题:对于autoCreatek函数具体实现的功能还是不太明了,另外,函数
    <scalar, RASModels::kqRWallFunctionFvPatchField<scalar> >
    (fieldName, mesh, mesh);
    是什么形式,<>内代表什么意思?
    特向各位同行请教:xinxin:
    这是模板的使用
    和
    是对应的,第一个scalar对应Type,第二个RASModels::kqRWallFunctionFvPatchField<scalar>对应PatchType。
    所以你这么写应该也是可以的:
    <一个类型, 一个类型>
    strive_DUTS 1 条回复 最后回复
  • strive_DUTS 离线
    strive_DUTS 离线
    strive_DUT
    @李东岳 谢谢李老师!这是调用函数模板的一种形式吧。此问题已解决!但关于autoCreatek函数的实现功能还是不太明白:mihu:
