  2. CFD彩虹条
  3. 为什么打开论坛后会自动下载一个叫composer.tpl的文件?
已定时 已固定 已锁定 已移动 CFD彩虹条
1 帖子 1 发布者 1.5k 浏览
  • 星 离线
    星 离线
    星星星星晴
    HTML文件,内容如下
    <div component="composer" class="composer<!-- IF resizable --> resizable<!-- ENDIF resizable --><!-- IF !isTopicOrMain --> reply<!-- ENDIF !isTopicOrMain -->">
    	<div class="composer-container">
    		<nav class="navbar navbar-fixed-top mobile-navbar hidden-md hidden-lg">
    			<div class="btn-group">
    				<button class="btn btn-sm btn-primary composer-discard" data-action="discard" tabindex="-1"><i class="fa fa-times"></i></button>
    				<button class="btn btn-sm btn-primary composer-minimize" data-action="minimize" tabindex="-1"><i class="fa fa-minus"></i></button>
    			</div>
    			<!-- IF isTopic -->
    			<div class="category-name-container">
    				<span class="category-name"></span> <i class="fa fa-sort"></i>
    			</div>
    			<!-- ENDIF isTopic -->
    			<h4 class="title">[[topic:composer.replying_to, "{title}"]]</h4>
    				<button class="btn btn-sm btn-primary composer-submit" data-action="post" tabindex="-1"><i class="fa fa-chevron-right"></i></button>
    			</div>
    		</nav>
    		<div class="row title-container">
    			<!-- IF showHandleInput -->
    			<div data-component="composer/handle">
    				<input class="handle form-control" type="text" tabindex="1" placeholder="[[topic:composer.handle_placeholder]]" value="{handle}" />
    			</div>
    			<!-- ENDIF showHandleInput -->
    			<div data-component="composer/title">
    				<!-- IF isTopicOrMain -->
    				<input class="title form-control" type="text" tabindex="1" placeholder="[[topic:composer.title_placeholder]]" value="{title}"/>
    				<!-- ELSE -->
    				<span class="title form-control">[[topic:composer.replying_to, "{title}"]]</span>
    				<!-- ENDIF isTopicOrMain -->
    				<ul class="dropdown-menu quick-search-results hidden">
    					{{{each posts}}}
    <li>
    	<a href="{config.relative_path}/post/{posts.pid}">
    		{buildAvatar(posts.user, "sm", true)}
    		<span class="quick-search-title">{posts.topic.title}</span>
    		<br/>
    		<p class="snippet">
    		{posts.snippet}
    		</p>
    		<small class="post-info pull-right">
    			<span class="fa-stack" style="{function.generateCategoryBackground, posts.category}"><i style="color:{posts.category.color};" class="fa {posts.category.icon} fa-stack-1x"></i></span> {posts.category.name} &bull;
    			<span class="timeago" title="{posts.timestampISO}"></span>
    		</small>
    	 </a>
    </li>
    <!-- IF !@last -->
    <li role="separator" class="divider"></li>
    <!-- ENDIF -->
    {{{end}}}
    <!-- IF multiplePages -->
    <li class="text-center">
    	<a href="{url}">
    		[[search:see-more-results, {matchCount}]]
    	</a>
    </li>
    <!-- ENDIF multiplePages -->
    				</ul>
    			</div>
    			<!-- IF isTopic -->
    			<div class="category-list-container hidden-sm hidden-xs"></div>
    			<div class="pull-right draft-icon hidden-xs hidden-sm"></div>
    			<div class="btn-group pull-right action-bar hidden-sm hidden-xs">
    				<button class="btn btn-default composer-discard" data-action="discard" tabindex="-1"><i class="fa fa-times"></i> [[topic:composer.discard]]</button>
    				<button class="btn btn-primary composer-submit" data-action="post" tabindex="6"><i class="fa fa-check"></i> [[topic:composer.submit]]</button>
    			</div>
    		</div>
    		<div class="category-tag-row">
    			<div class="btn-toolbar formatting-bar">
    				<ul class="formatting-group">
    					<!-- BEGIN formatting -->
    						<!-- IF formatting.spacer -->
    						<li class="spacer"></li>
    						<!-- ELSE -->
    						<!-- IF !formatting.mobile -->
    						<li tabindex="-1" data-format="{formatting.name}" title="{formatting.title}"><i class="{formatting.className}"></i></li>
    						<!-- ENDIF !formatting.mobile -->
    						<!-- ENDIF formatting.spacer -->
    					<!-- END formatting -->
    					<!--[if gte IE 9]><!-->
    						<!-- IF privileges.upload:post:image -->
    						<li class="img-upload-btn hide" data-format="picture" tabindex="-1" title="[[modules:composer.upload-picture]]">
    							<i class="fa fa-file-image-o"></i>
    						</li>
    						<!-- ENDIF privileges.upload:post:image -->
    						<!-- IF privileges.upload:post:file -->
    						<li class="file-upload-btn hide" data-format="upload" tabindex="-1" title="[[modules:composer.upload-file]]">
    							<span class="fa-stack">
    								<i class="fa fa-file-o fa-stack-1x"></i>
    								<i class="fa fa-arrow-up fa-stack-1x"></i>
    							</span>
    						</li>
    						<!-- ENDIF privileges.upload:post:file -->
    					<!--<![endif]-->
    					<!-- IF allowTopicsThumbnail -->
    					<li tabindex="-1">
    						<i class="fa fa-th-large topic-thumb-btn topic-thumb-toggle-btn hide" title="[[topic:composer.thumb_title]]"></i>
    					</li>
    					<div class="topic-thumb-container center-block hide">
    						<form id="thumbForm" method="post" class="topic-thumb-form form-inline" enctype="multipart/form-data">
    							<img class="topic-thumb-preview"></img>
    							<div class="form-group">
    								<label for="topic-thumb-url">[[topic:composer.thumb_url_label]]</label>
    								<input type="text" id="topic-thumb-url" class="form-control" placeholder="[[topic:composer.thumb_url_placeholder]]" />
    							</div>
    								<label for="topic-thumb-file">[[topic:composer.thumb_file_label]]</label>
    								<input type="file" id="topic-thumb-file" class="form-control" />
    							</div>
    							<div class="form-group topic-thumb-ctrl">
    								<i class="fa fa-spinner fa-spin hide topic-thumb-spinner" title="[[topic:composer.uploading]]"></i>
    								<i class="fa fa-times topic-thumb-btn hide topic-thumb-clear-btn" title="[[topic:composer.thumb_remove]]"></i>
    							</div>
    						</form>
    					</div>
    					<!-- ENDIF allowTopicsThumbnail -->
    					<form id="fileForm" method="post" enctype="multipart/form-data">
    							<input type="file" id="files" name="files[]" multiple class="gte-ie9 hide"/>
    						<!--<![endif]-->
    						<!--[if lt IE 9]>
    							<input type="file" id="files" name="files[]" class="lt-ie9 hide" value="Upload"/>
    						<![endif]-->
    					</form>
    				</ul>
    			</div>
    		</div>
    		<div class="row write-preview-container">
    			<div class="write-container">
    				<div class="help-text">
    					<span class="help hidden">[[modules:composer.compose]] <i class="fa fa-question-circle"></i></span>
    					<span class="toggle-preview hide">[[modules:composer.show_preview]]</span>
    				</div>
    				<div class="pull-right draft-icon hidden-md hidden-lg"></div>
    				<textarea class="write" tabindex="4"></textarea>
    			</div>
    			<div class="hidden-sm hidden-xs preview-container">
    					<span class="toggle-preview">[[modules:composer.hide_preview]]</span>
    				</div>
    				<div class="preview well"></div>
    			</div>
    		</div>
    		<div class="tag-row">
    			<div class="tags-container">
    				<div class="btn-group dropup <!-- IF !tagWhitelist.length -->hidden<!-- ENDIF !tagWhitelist.length -->" component="composer/tag/dropdown">
    					<button class="btn btn-default dropdown-toggle" data-toggle="dropdown" type="button">
    						<span class="visible-sm-inline visible-md-inline visible-lg-inline"><i class="fa fa-tags"></i></span>
    						<span class="caret"></span>
    					</button>
    					<ul class="dropdown-menu">
    						<!-- BEGIN tagWhitelist -->
    						<li data-tag="@value"><a href="#">@value</a></li>
    						<!-- END tagWhitelist -->
    					</ul>
    				</div>
    				<input class="tags" type="text" class="form-control" placeholder="[[tags:enter_tags_here, {minimumTagLength}, {maximumTagLength}]]" tabindex="5"/>
    			</div>
    		</div>
    		<!-- IF isTopic -->
    		<ul class="category-selector visible-xs visible-sm">
    		</ul>
    		<div class="imagedrop"><div>[[topic:composer.drag_and_drop_images]]</div></div>
    		<div class="resizer"><div class="trigger text-center"><i class="fa"></i></div></div>
    	</div>
    </div>
    回来了,都回来了~
