  4. 在foam-extend-4.0下安装waves2Foam失败,请求帮助
14 帖子 4 发布者 14.9k 浏览
  • J 离线
    J 离线
    jlx
    @李东岳 东岳老师好,我用您说的g++-4.8试了下,按照下面的步骤安装g++-4.8:
    bd4ac027-45fd-4fa7-8d1a-88dbadb04b38-图片.png 。
    之后重新编译了下,还是会出现一样的问题。下面是报错的文件:
     COMPILE OCEANWAVE3D
    Pull changes from the OceanWave3D git repository ...
    Saved working directory and index state WIP on master: bb7d99e bug fix for calling OceanWave3D
    Already up to date.
    On branch master
    Your branch is up to date with 'origin/master'.
    Changes not staged for commit:
      (use "git add <file>..." to update what will be committed)
      (use "git checkout -- <file>..." to discard changes in working directory)
    	modified:   common.mk
    	modified:   makefile
    no changes added to commit (use "git add" and/or "git commit -a")
    Dropped refs/stash@{0} (6284db29337d2e0832e9517c0febf14d2e55dfd4)
    OceanWave3D has already been compiled
    /home/abao/foam/abao-4.0/applications/utilities/waves2Foam/ThirdParty
        COMPILE FENTON4FOAM
    fenton4Foam has already been compiled
        COMPILE LIBRARY
    /home/abao/foam/foam-extend-4.0/wmake/Makefile:186: recipe for target '/home/abao/foam/abao-4.0/lib/linux64GccDPOpt/libwaves2Foam.so' failed
    /home/abao/foam/foam-extend-4.0/wmake/Makefile:186: recipe for target '/home/abao/foam/abao-4.0/lib/linux64GccDPOpt/libwaves2FoamProcessing.so' failed
    /home/abao/foam/foam-extend-4.0/wmake/Makefile:186: recipe for target '/home/abao/foam/abao-4.0/lib/linux64GccDPOpt/libwaves2FoamSampling.so' failed
    '/home/abao/foam/abao-4.0/lib/linux64GccDPOpt/libwaves2FoamPorosity.so' is up to date.
        COMPILE SOLVERS
    g++-5 -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3  -DNoRepository -ftemplate-depth-200 -I/home/abao/foam/foam-extend-4.0/src/transportModels     -I/home/abao/foam/foam-extend-4.0/src/transportModels/incompressible/lnInclude     -I/home/abao/foam/foam-extend-4.0/src/transportModels/interfaceProperties/lnInclude     -I/home/abao/foam/foam-extend-4.0/src/turbulenceModels/incompressible/turbulenceModel     -I/home/abao/foam/foam-extend-4.0/src/finiteVolume/lnInclude     -DOFVERSION=400     -DEXTBRANCH=1     -DOFPLUSBRANCH=0     -I/home/abao/foam/abao-4.0/applications/utilities/waves2Foam/src/waves2Foam/lnInclude     -I/home/abao/foam/abao-4.0/applications/utilities/waves2Foam/src/waves2FoamSampling/lnInclude     -I/home/abao/foam/abao-4.0/applications/utilities/waves2Foam/src/waves2FoamPorosity/lnInclude     -I/usr/include -IlnInclude -I. -I/home/abao/foam/foam-extend-4.0/src/foam/lnInclude -I/home/abao/foam/foam-extend-4.0/src/OSspecific/POSIX/lnInclude   -fPIC -Xlinker --add-needed -Xlinker --no-as-needed Make/linux64GccDPOpt/porousWaveFoam.o -L/home/abao/foam/foam-extend-4.0/lib/linux64GccDPOpt \
         -linterfaceProperties     -lincompressibleTransportModels     -lincompressibleTurbulenceModel     -lincompressibleRASModels     -lincompressibleLESModels     -lfiniteVolume     -llduSolvers     -L/home/abao/foam/abao-4.0/lib/linux64GccDPOpt     -lwaves2Foam     -lwaves2FoamSampling     -lwaves2FoamPorosity     -L/usr/lib64     -lgsl     -lgslcblas -lfoam -ldl   -lrt -lm -o /home/abao/foam/abao-4.0/applications/bin/linux64GccDPOpt/porousWaveFoam
    /home/abao/foam/foam-extend-4.0/wmake/Makefile:159: recipe for target '/home/abao/foam/abao-4.0/applications/bin/linux64GccDPOpt/porousWaveFoam' failed
    g++-5 -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3  -DNoRepository -ftemplate-depth-200 -I/home/abao/foam/foam-extend-4.0/src/transportModels     -I/home/abao/foam/foam-extend-4.0/src/transportModels/incompressible/lnInclude     -I/home/abao/foam/foam-extend-4.0/src/transportModels/interfaceProperties/lnInclude     -I/home/abao/foam/foam-extend-4.0/src/turbulenceModels/incompressible/turbulenceModel     -I/home/abao/foam/foam-extend-4.0/src/finiteVolume/lnInclude     -DOFVERSION=400     -DEXTBRANCH=1     -DOFPLUSBRANCH=0     -I/home/abao/foam/abao-4.0/applications/utilities/waves2Foam/src/waves2Foam/lnInclude     -I/home/abao/foam/abao-4.0/applications/utilities/waves2Foam/src/waves2FoamSampling/lnInclude     -I/usr/include -IlnInclude -I. -I/home/abao/foam/foam-extend-4.0/src/foam/lnInclude -I/home/abao/foam/foam-extend-4.0/src/OSspecific/POSIX/lnInclude   -fPIC -Xlinker --add-needed -Xlinker --no-as-needed Make/linux64GccDPOpt/waveFoam.o -L/home/abao/foam/foam-extend-4.0/lib/linux64GccDPOpt \
         -linterfaceProperties     -lincompressibleTransportModels     -lincompressibleTurbulenceModel     -lincompressibleRASModels     -lincompressibleLESModels     -lfiniteVolume     -llduSolvers     -L/home/abao/foam/abao-4.0/lib/linux64GccDPOpt     -lwaves2Foam     -lwaves2FoamSampling     -L/usr/lib64     -lgsl     -lgslcblas -lfoam -ldl   -lrt -lm -o /home/abao/foam/abao-4.0/applications/bin/linux64GccDPOpt/waveFoam
    /home/abao/foam/foam-extend-4.0/wmake/Makefile:159: recipe for target '/home/abao/foam/abao-4.0/applications/bin/linux64GccDPOpt/waveFoam' failed
        COMPILE PRE-PROCESSING
    make[1]: '/home/abao/foam/abao-4.0/applications/bin/linux64GccDPOpt/faceSetToSTL' is up to date.
    g++-5 -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3  -DNoRepository -ftemplate-depth-200 -DOFVERSION=400     -DEXTBRANCH=1     -I/home/abao/foam/foam-extend-4.0/src/meshTools/lnInclude     -I/home/abao/foam/foam-extend-4.0/src/finiteVolume/lnInclude     -I/home/abao/foam/abao-4.0/applications/utilities/waves2Foam/src/waves2Foam/lnInclude     -I/home/abao/foam/abao-4.0/applications/utilities/waves2Foam/src/waves2FoamProcessing/lnInclude     -I/usr/include -IlnInclude -I. -I/home/abao/foam/foam-extend-4.0/src/foam/lnInclude -I/home/abao/foam/foam-extend-4.0/src/OSspecific/POSIX/lnInclude   -fPIC -Xlinker --add-needed -Xlinker --no-as-needed Make/linux64GccDPOpt/setWaveParameters.o -L/home/abao/foam/foam-extend-4.0/lib/linux64GccDPOpt \
         -lfiniteVolume     -L/usr/lib64     -lgsl     -lgslcblas     -L/home/abao/foam/abao-4.0/lib/linux64GccDPOpt     -lwaves2Foam     -lwaves2FoamProcessing -lfoam -ldl   -lrt -lm -o /home/abao/foam/abao-4.0/applications/bin/linux64GccDPOpt/setWaveParameters
    g++-5 -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3  -DNoRepository -ftemplate-depth-200 -I/home/abao/foam/foam-extend-4.0/src/foam/lnInclude     -I/home/abao/foam/foam-extend-4.0/src/finiteVolume/lnInclude     -I/home/abao/foam/abao-4.0/applications/utilities/waves2Foam/src/waves2Foam/lnInclude     -I/home/abao/foam/abao-4.0/applications/utilities/waves2Foam/src/waves2FoamProcessing/lnInclude     -I/usr/include     -DOFVERSION=400     -DEXTBRANCH=1 -IlnInclude -I. -I/home/abao/foam/foam-extend-4.0/src/foam/lnInclude -I/home/abao/foam/foam-extend-4.0/src/OSspecific/POSIX/lnInclude   -fPIC -Xlinker --add-needed -Xlinker --no-as-needed Make/linux64GccDPOpt/waveGaugesNProbes.o -L/home/abao/foam/foam-extend-4.0/lib/linux64GccDPOpt \
         -lfoam     -lfiniteVolume     -L/home/abao/foam/abao-4.0/lib/linux64GccDPOpt     -lwaves2Foam     -lwaves2FoamProcessing     -L/usr/lib64     -lgsl     -lgslcblas -lfoam -ldl   -lrt -lm -o /home/abao/foam/abao-4.0/applications/bin/linux64GccDPOpt/waveGaugesNProbes
    g++-5 -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3  -DNoRepository -ftemplate-depth-200 -I/home/abao/foam/foam-extend-4.0/src/meshTools/lnInclude     -I/home/abao/foam/foam-extend-4.0/src/finiteVolume/lnInclude     -DOFVERSION=400     -DEXTBRANCH=1     -I/home/abao/foam/abao-4.0/applications/utilities/waves2Foam/src/waves2Foam/lnInclude     -I/usr/include -IlnInclude -I. -I/home/abao/foam/foam-extend-4.0/src/foam/lnInclude -I/home/abao/foam/foam-extend-4.0/src/OSspecific/POSIX/lnInclude   -fPIC -Xlinker --add-needed -Xlinker --no-as-needed Make/linux64GccDPOpt/setWaveField.o -L/home/abao/foam/foam-extend-4.0/lib/linux64GccDPOpt \
         -lfiniteVolume     -L/home/abao/foam/abao-4.0/lib/linux64GccDPOpt     -lwaves2Foam     -lwaves2FoamGABC     -L/usr/lib64     -lgsl     -lgslcblas -lfoam -ldl   -lrt -lm -o /home/abao/foam/abao-4.0/applications/bin/linux64GccDPOpt/setWaveField
    SOURCE=sampleIncidentWaveField.C ;  g++-5 -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3  -DNoRepository -ftemplate-depth-200 -I/home/abao/foam/foam-extend-4.0/src/meshTools/lnInclude     -I/home/abao/foam/foam-extend-4.0/src/finiteVolume/lnInclude     -DOFVERSION=400     -DEXTBRANCH=1     -I/home/abao/foam/abao-4.0/applications/utilities/waves2Foam/src/waves2Foam/lnInclude     -I/home/abao/foam/abao-4.0/applications/utilities/waves2Foam/src/waves2FoamProcessing/lnInclude     -I/usr/include -IlnInclude -I. -I/home/abao/foam/foam-extend-4.0/src/foam/lnInclude -I/home/abao/foam/foam-extend-4.0/src/OSspecific/POSIX/lnInclude   -fPIC -c $SOURCE -o Make/linux64GccDPOpt/sampleIncidentWaveField.o
    g++-5 -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3  -DNoRepository -ftemplate-depth-200 -I/home/abao/foam/foam-extend-4.0/src/meshTools/lnInclude     -I/home/abao/foam/foam-extend-4.0/src/finiteVolume/lnInclude     -DOFVERSION=400     -DEXTBRANCH=1     -I/home/abao/foam/abao-4.0/applications/utilities/waves2Foam/src/waves2Foam/lnInclude     -I/usr/include -IlnInclude -I. -I/home/abao/foam/foam-extend-4.0/src/foam/lnInclude -I/home/abao/foam/foam-extend-4.0/src/OSspecific/POSIX/lnInclude   -fPIC -Xlinker --add-needed -Xlinker --no-as-needed Make/linux64GccDPOpt/relaxationZoneLayout.o -L/home/abao/foam/foam-extend-4.0/lib/linux64GccDPOpt \
         -lfiniteVolume     -L/home/abao/foam/abao-4.0/lib/linux64GccDPOpt     -lwaves2Foam     -L/usr/lib64     -lgsl     -lgslcblas -lfoam -ldl   -lrt -lm -o /home/abao/foam/abao-4.0/applications/bin/linux64GccDPOpt/relaxationZoneLayout
    sampleIncidentWaveField.dep:702: recipe for target 'Make/linux64GccDPOpt/sampleIncidentWaveField.o' failed
    /home/abao/foam/foam-extend-4.0/wmake/MakefileApps:39: recipe for target 'sampleIncidentWaveField' failed
    /home/abao/foam/foam-extend-4.0/wmake/Makefile:159: recipe for target '/home/abao/foam/abao-4.0/applications/bin/linux64GccDPOpt/setWaveField' failed
    /home/abao/foam/foam-extend-4.0/wmake/Makefile:159: recipe for target '/home/abao/foam/abao-4.0/applications/bin/linux64GccDPOpt/waveGaugesNProbes' failed
    /home/abao/foam/foam-extend-4.0/wmake/Makefile:159: recipe for target '/home/abao/foam/abao-4.0/applications/bin/linux64GccDPOpt/setWaveParameters' failed
    /home/abao/foam/foam-extend-4.0/wmake/MakefileApps:39: recipe for target 'setWaveField' failed
    /home/abao/foam/foam-extend-4.0/wmake/MakefileApps:39: recipe for target 'waveGaugesNProbes' failed
    /home/abao/foam/foam-extend-4.0/wmake/MakefileApps:39: recipe for target 'setWaveParameters' failed
    /home/abao/foam/foam-extend-4.0/wmake/Makefile:159: recipe for target '/home/abao/foam/abao-4.0/applications/bin/linux64GccDPOpt/relaxationZoneLayout' failed
    /home/abao/foam/foam-extend-4.0/wmake/MakefileApps:39: recipe for target 'relaxationZoneLayout' failed
        COMPILE BREEDER
    Nothing available for compilation in the breeder
    directory.
        COMPILATION DONE
    在 中回复了 jlx 最后由 李东岳 编辑
    @jlx 显示你用的还是g++5 https://www.cfd-china.com/topic/4196/ubuntu-20-04-安装-openfoam-v1712/2
    foam-extend4.0和fsiFoam我都安装成功了
    你确定安装成功了foam-extend4.0么,我最近醉了个虚拟机,装的4.1,用的g++4.8,5报错
    J 2 条回复 最后回复
  • J 离线
    J 离线
    jlx
    @李东岳 老师好,我试着运行了extend中的floatingObject算例,能运行,应该表示extend4.0装好了。关于那个g++-4.8,我是先把g++-5.0卸载了,再安装的g++-4.8,我也很纳闷为啥还是g++-5.0版本的,下面是我卸载g++-5.0所用到的命令:
    sudo apt-get remove gcc
    sudo apt-get remove g++
    然后通过以下命令安装g++-4.8:
    sudo apt-get install g++-4.8
    我再重新试一试:135:
  • J 离线
    J 离线
    jlx
    @李东岳 东岳老师,我安装完g++-4.8后把foam-extend4.0重新安装了一遍,再安装waves2foam,还是报一样的错,这次log文件显示g++-4.8编译:
     ENVIRONMENTAL VARIABLES
    EXTBRANCH=1
    FOAMEXTENDPROJECT=1
    OFPLUSBRANCH=0
    WAVES_APPBIN=/home/abao/foam/abao-4.0/applications/bin/linux64GccDPOpt
    WAVES_DIR=/home/abao/foam/abao-4.0/applications/utilities/waves2Foam
    WAVES_GSL_INCLUDE=/home/abao/gsl/include
    WAVES_GSL_LIB=/home/abao/gsl/lib
    WAVES_LIBBIN=/home/abao/foam/abao-4.0/lib/linux64GccDPOpt
    WAVES_POST=/home/abao/foam/abao-4.0/applications/utilities/waves2Foam/applications/utilities/postProcessing
    WAVES_PRE=/home/abao/foam/abao-4.0/applications/utilities/waves2Foam/applications/utilities/preProcessing
    WAVES_SOL=/home/abao/foam/abao-4.0/applications/utilities/waves2Foam/applications/solvers/solvers400_EXT
    WAVES_SRC=/home/abao/foam/abao-4.0/applications/utilities/waves2Foam/src
    WAVES_TUT=/home/abao/foam/abao-4.0/applications/utilities/waves2Foam/tutorials
    WAVES_UTIL=/home/abao/foam/abao-4.0/applications/utilities/waves2Foam/applications/utilities
    WAVES_XVERSION=0
    WM_PROJECT_VERSION_NUMBER=400
        COMPILE LAPACK-3.3.1
    lapack-3.3.1 has already been compiled
        COMPILE SPARSKIT2
    SPARSKIT2 has already been compiled
        COMPILE OCEANWAVE3D
    Already up to date.
    On branch master
    	modified:   common.mk
    	modified:   makefile
    Dropped refs/stash@{0} (0c4b9759497aecbead9156251c2ad1f0f5896e00)
        COMPILE FENTON4FOAM
        COMPILE LIBRARY
        COMPILE SOLVERS
    g++-4.8 -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3  -DNoRepository -ftemplate-depth-200 -I/home/abao/foam/foam-extend-4.0/src/transportModels     -I/home/abao/foam/foam-extend-4.0/src/transportModels/incompressible/lnInclude     -I/home/abao/foam/foam-extend-4.0/src/transportModels/interfaceProperties/lnInclude     -I/home/abao/foam/foam-extend-4.0/src/turbulenceModels/incompressible/turbulenceModel     -I/home/abao/foam/foam-extend-4.0/src/finiteVolume/lnInclude     -DOFVERSION=400     -DEXTBRANCH=1     -DOFPLUSBRANCH=0     -I/home/abao/foam/abao-4.0/applications/utilities/waves2Foam/src/waves2Foam/lnInclude     -I/home/abao/foam/abao-4.0/applications/utilities/waves2Foam/src/waves2FoamSampling/lnInclude     -I/home/abao/foam/abao-4.0/applications/utilities/waves2Foam/src/waves2FoamPorosity/lnInclude     -I/home/abao/gsl/include -IlnInclude -I. -I/home/abao/foam/foam-extend-4.0/src/foam/lnInclude -I/home/abao/foam/foam-extend-4.0/src/OSspecific/POSIX/lnInclude   -fPIC -Xlinker --add-needed -Xlinker --no-as-needed Make/linux64GccDPOpt/porousWaveFoam.o -L/home/abao/foam/foam-extend-4.0/lib/linux64GccDPOpt \
         -linterfaceProperties     -lincompressibleTransportModels     -lincompressibleTurbulenceModel     -lincompressibleRASModels     -lincompressibleLESModels     -lfiniteVolume     -llduSolvers     -L/home/abao/foam/abao-4.0/lib/linux64GccDPOpt     -lwaves2Foam     -lwaves2FoamSampling     -lwaves2FoamPorosity     -L/home/abao/gsl/lib     -lgsl     -lgslcblas -lfoam -ldl   -lrt -lm -o /home/abao/foam/abao-4.0/applications/bin/linux64GccDPOpt/porousWaveFoam
    g++-4.8 -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3  -DNoRepository -ftemplate-depth-200 -I/home/abao/foam/foam-extend-4.0/src/transportModels     -I/home/abao/foam/foam-extend-4.0/src/transportModels/incompressible/lnInclude     -I/home/abao/foam/foam-extend-4.0/src/transportModels/interfaceProperties/lnInclude     -I/home/abao/foam/foam-extend-4.0/src/turbulenceModels/incompressible/turbulenceModel     -I/home/abao/foam/foam-extend-4.0/src/finiteVolume/lnInclude     -DOFVERSION=400     -DEXTBRANCH=1     -DOFPLUSBRANCH=0     -I/home/abao/foam/abao-4.0/applications/utilities/waves2Foam/src/waves2Foam/lnInclude     -I/home/abao/foam/abao-4.0/applications/utilities/waves2Foam/src/waves2FoamSampling/lnInclude     -I/home/abao/gsl/include -IlnInclude -I. -I/home/abao/foam/foam-extend-4.0/src/foam/lnInclude -I/home/abao/foam/foam-extend-4.0/src/OSspecific/POSIX/lnInclude   -fPIC -Xlinker --add-needed -Xlinker --no-as-needed Make/linux64GccDPOpt/waveFoam.o -L/home/abao/foam/foam-extend-4.0/lib/linux64GccDPOpt \
         -linterfaceProperties     -lincompressibleTransportModels     -lincompressibleTurbulenceModel     -lincompressibleRASModels     -lincompressibleLESModels     -lfiniteVolume     -llduSolvers     -L/home/abao/foam/abao-4.0/lib/linux64GccDPOpt     -lwaves2Foam     -lwaves2FoamSampling     -L/home/abao/gsl/lib     -lgsl     -lgslcblas -lfoam -ldl   -lrt -lm -o /home/abao/foam/abao-4.0/applications/bin/linux64GccDPOpt/waveFoam
    g++-4.8 -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3  -DNoRepository -ftemplate-depth-200 -I/home/abao/foam/foam-extend-4.0/src/meshTools/lnInclude     -I/home/abao/foam/foam-extend-4.0/src/finiteVolume/lnInclude     -DOFVERSION=400     -DEXTBRANCH=1     -I/home/abao/foam/abao-4.0/applications/utilities/waves2Foam/src/waves2Foam/lnInclude     -I/home/abao/gsl/include -IlnInclude -I. -I/home/abao/foam/foam-extend-4.0/src/foam/lnInclude -I/home/abao/foam/foam-extend-4.0/src/OSspecific/POSIX/lnInclude   -fPIC -Xlinker --add-needed -Xlinker --no-as-needed Make/linux64GccDPOpt/relaxationZoneLayout.o -L/home/abao/foam/foam-extend-4.0/lib/linux64GccDPOpt \
         -lfiniteVolume     -L/home/abao/foam/abao-4.0/lib/linux64GccDPOpt     -lwaves2Foam     -L/home/abao/gsl/lib     -lgsl     -lgslcblas -lfoam -ldl   -lrt -lm -o /home/abao/foam/abao-4.0/applications/bin/linux64GccDPOpt/relaxationZoneLayout
    g++-4.8 -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3  -DNoRepository -ftemplate-depth-200 -DOFVERSION=400     -DEXTBRANCH=1     -I/home/abao/foam/foam-extend-4.0/src/meshTools/lnInclude     -I/home/abao/foam/foam-extend-4.0/src/finiteVolume/lnInclude     -I/home/abao/foam/abao-4.0/applications/utilities/waves2Foam/src/waves2Foam/lnInclude     -I/home/abao/foam/abao-4.0/applications/utilities/waves2Foam/src/waves2FoamProcessing/lnInclude     -I/home/abao/gsl/include -IlnInclude -I. -I/home/abao/foam/foam-extend-4.0/src/foam/lnInclude -I/home/abao/foam/foam-extend-4.0/src/OSspecific/POSIX/lnInclude   -fPIC -Xlinker --add-needed -Xlinker --no-as-needed Make/linux64GccDPOpt/setWaveParameters.o -L/home/abao/foam/foam-extend-4.0/lib/linux64GccDPOpt \
         -lfiniteVolume     -L/home/abao/gsl/lib     -lgsl     -lgslcblas     -L/home/abao/foam/abao-4.0/lib/linux64GccDPOpt     -lwaves2Foam     -lwaves2FoamProcessing -lfoam -ldl   -lrt -lm -o /home/abao/foam/abao-4.0/applications/bin/linux64GccDPOpt/setWaveParameters
    SOURCE=sampleIncidentWaveField.C ;  g++-4.8 -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3  -DNoRepository -ftemplate-depth-200 -I/home/abao/foam/foam-extend-4.0/src/meshTools/lnInclude     -I/home/abao/foam/foam-extend-4.0/src/finiteVolume/lnInclude     -DOFVERSION=400     -DEXTBRANCH=1     -I/home/abao/foam/abao-4.0/applications/utilities/waves2Foam/src/waves2Foam/lnInclude     -I/home/abao/foam/abao-4.0/applications/utilities/waves2Foam/src/waves2FoamProcessing/lnInclude     -I/home/abao/gsl/include -IlnInclude -I. -I/home/abao/foam/foam-extend-4.0/src/foam/lnInclude -I/home/abao/foam/foam-extend-4.0/src/OSspecific/POSIX/lnInclude   -fPIC -c $SOURCE -o Make/linux64GccDPOpt/sampleIncidentWaveField.o
    g++-4.8 -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3  -DNoRepository -ftemplate-depth-200 -I/home/abao/foam/foam-extend-4.0/src/foam/lnInclude     -I/home/abao/foam/foam-extend-4.0/src/finiteVolume/lnInclude     -I/home/abao/foam/abao-4.0/applications/utilities/waves2Foam/src/waves2Foam/lnInclude     -I/home/abao/foam/abao-4.0/applications/utilities/waves2Foam/src/waves2FoamProcessing/lnInclude     -I/home/abao/gsl/include     -DOFVERSION=400     -DEXTBRANCH=1 -IlnInclude -I. -I/home/abao/foam/foam-extend-4.0/src/foam/lnInclude -I/home/abao/foam/foam-extend-4.0/src/OSspecific/POSIX/lnInclude   -fPIC -Xlinker --add-needed -Xlinker --no-as-needed Make/linux64GccDPOpt/waveGaugesNProbes.o -L/home/abao/foam/foam-extend-4.0/lib/linux64GccDPOpt \
         -lfoam     -lfiniteVolume     -L/home/abao/foam/abao-4.0/lib/linux64GccDPOpt     -lwaves2Foam     -lwaves2FoamProcessing     -L/home/abao/gsl/lib     -lgsl     -lgslcblas -lfoam -ldl   -lrt -lm -o /home/abao/foam/abao-4.0/applications/bin/linux64GccDPOpt/waveGaugesNProbes
    g++-4.8 -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3  -DNoRepository -ftemplate-depth-200 -I/home/abao/foam/foam-extend-4.0/src/meshTools/lnInclude     -I/home/abao/foam/foam-extend-4.0/src/finiteVolume/lnInclude     -DOFVERSION=400     -DEXTBRANCH=1     -I/home/abao/foam/abao-4.0/applications/utilities/waves2Foam/src/waves2Foam/lnInclude     -I/home/abao/gsl/include -IlnInclude -I. -I/home/abao/foam/foam-extend-4.0/src/foam/lnInclude -I/home/abao/foam/foam-extend-4.0/src/OSspecific/POSIX/lnInclude   -fPIC -Xlinker --add-needed -Xlinker --no-as-needed Make/linux64GccDPOpt/setWaveField.o -L/home/abao/foam/foam-extend-4.0/lib/linux64GccDPOpt \
         -lfiniteVolume     -L/home/abao/foam/abao-4.0/lib/linux64GccDPOpt     -lwaves2Foam     -lwaves2FoamGABC     -L/home/abao/gsl/lib     -lgsl     -lgslcblas -lfoam -ldl   -lrt -lm -o /home/abao/foam/abao-4.0/applications/bin/linux64GccDPOpt/setWaveField
        COMPILE BREEDER
    directory.
        COMPILATION DONE
    在 中回复了 jlx 最后由 编辑
    你下载的waves2Foam r2104版本?
    J 1 条回复 最后回复
  • J 离线
    J 离线
    jlx
    @李东岳 东岳老师,我之前用的是最新版2148,经过您提醒后,又下载2104版试了试,结果还是报一样的错。
    李东岳李 洱聿洱 2 条回复 最后回复
    在 中回复了 jlx 最后由 编辑
    @jlx 把你foam-extnd运行./Allwmake编译输出的log贴一下
    J 1 条回复 最后回复
  • J 离线
    J 离线
    jlx
    @李东岳 东岳老师,以下是输出的log文件:
    make: Nothing to be done for 'all'.
    same version as previous build
    '/home/abao/foam/foam-extend-4.0/lib/linux64GccDPOpt/libOSspecific.o' is up to date.
    Note: ignore spurious warnings about missing mpicxx.h headers
    SOURCE=global/global.Cver ; sed -e 's/VERSION_STRING/4.0/' -e 's/BUILD_STRING/4.0-268bb07d15d8/' $SOURCE > Make/linux64GccDPOpt/global.C; g++-4.8 -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3  -DNoRepository -ftemplate-depth-200 -DOMPI_SKIP_MPICXX -I/home/abao/foam/foam-extend-4.0/ThirdParty/packages/openmpi-1.8.8/platforms/linux64GccDPOpt/include    -I/home/abao/foam/foam-extend-4.0/ThirdParty/zlib-1.2.3 -IlnInclude -I. -I/home/abao/foam/foam-extend-4.0/src/foam/lnInclude -I/home/abao/foam/foam-extend-4.0/src/OSspecific/POSIX/lnInclude   -fPIC -c Make/linux64GccDPOpt/global.C -o Make/linux64GccDPOpt/global.o
    '/home/abao/foam/foam-extend-4.0/lib/linux64GccDPOpt/libfoam.so' is up to date.
    '/home/abao/foam/foam-extend-4.0/lib/linux64GccDPOpt/libdecompositionMethods.so' is up to date.
    '/home/abao/foam/foam-extend-4.0/lib/linux64GccDPOpt/libmetisDecomp.so' is up to date.
    '/home/abao/foam/foam-extend-4.0/lib/linux64GccDPOpt/libparMetisDecomp.so' is up to date.
    '/home/abao/foam/foam-extend-4.0/lib/linux64GccDPOpt/libscotchDecomp.so' is up to date.
    '/home/abao/foam/foam-extend-4.0/lib/linux64GccDPOpt/liblagrangian.so' is up to date.
    '/home/abao/foam/foam-extend-4.0/lib/linux64GccDPOpt/libedgeMesh.so' is up to date.
    '/home/abao/foam/foam-extend-4.0/lib/linux64GccDPOpt/libsurfMesh.so' is up to date.
    '/home/abao/foam/foam-extend-4.0/lib/linux64GccDPOpt/libmeshTools.so' is up to date.
    '/home/abao/foam/foam-extend-4.0/lib/linux64GccDPOpt/libfiniteVolume.so' is up to date.
    '/home/abao/foam/foam-extend-4.0/lib/linux64GccDPOpt/libfiniteArea.so' is up to date.
    '/home/abao/foam/foam-extend-4.0/lib/linux64GccDPOpt/liblduSolvers.so' is up to date.
    '/home/abao/foam/foam-extend-4.0/lib/linux64GccDPOpt/libtetFiniteElement.so' is up to date.
    '/home/abao/foam/foam-extend-4.0/lib/linux64GccDPOpt/libdynamicMesh.so' is up to date.
    '/home/abao/foam/foam-extend-4.0/lib/linux64GccDPOpt/libsolidBodyMotion.so' is up to date.
    '/home/abao/foam/foam-extend-4.0/lib/linux64GccDPOpt/libfvMotionSolver.so' is up to date.
    '/home/abao/foam/foam-extend-4.0/lib/linux64GccDPOpt/libRBFMotionSolver.so' is up to date.
    SOURCE=mesquiteMotionSolver.C ;  g++-4.8 -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3  -DNoRepository -ftemplate-depth-200 -I     -I/home/abao/foam/foam-extend-4.0/src/meshTools/lnInclude     -I/home/abao/foam/foam-extend-4.0/src/dynamicMesh/dynamicMesh/lnInclude  -IlnInclude -I. -I/home/abao/foam/foam-extend-4.0/src/foam/lnInclude -I/home/abao/foam/foam-extend-4.0/src/OSspecific/POSIX/lnInclude   -fPIC -c $SOURCE -o Make/linux64GccDPOpt/mesquiteMotionSolver.o
    mesquiteMotionSolver.dep:383: recipe for target 'Make/linux64GccDPOpt/mesquiteMotionSolver.o' failed
    '/home/abao/foam/foam-extend-4.0/lib/linux64GccDPOpt/libtetMotionSolver.so' is up to date.
    '/home/abao/foam/foam-extend-4.0/lib/linux64GccDPOpt/libdynamicFvMesh.so' is up to date.
    '/home/abao/foam/foam-extend-4.0/lib/linux64GccDPOpt/libdynamicTopoFvMesh.so' is up to date.
    '/home/abao/foam/foam-extend-4.0/lib/linux64GccDPOpt/libtopoChangerFvMesh.so' is up to date.
    '/home/abao/foam/foam-extend-4.0/lib/linux64GccDPOpt/libcoupledLduMatrix.so' is up to date.
    '/home/abao/foam/foam-extend-4.0/lib/linux64GccDPOpt/libsampling.so' is up to date.
    '/home/abao/foam/foam-extend-4.0/lib/linux64GccDPOpt/libODE.so' is up to date.
    '/home/abao/foam/foam-extend-4.0/lib/linux64GccDPOpt/libPOD.so' is up to date.
    '/home/abao/foam/foam-extend-4.0/lib/linux64GccDPOpt/librandomProcesses.so' is up to date.
    '/home/abao/foam/foam-extend-4.0/lib/linux64GccDPOpt/libautoMesh.so' is up to date.
    '/home/abao/foam/foam-extend-4.0/lib/linux64GccDPOpt/libblockMesh.so' is up to date.
    '/home/abao/foam/foam-extend-4.0/lib/linux64GccDPOpt/libextrudeModel.so' is up to date.
    '/home/abao/foam/foam-extend-4.0/lib/linux64GccDPOpt/libcfMesh.so' is up to date.
    '/home/abao/foam/foam-extend-4.0/lib/linux64GccDPOpt/libspecie.so' is up to date.
    '/home/abao/foam/foam-extend-4.0/lib/linux64GccDPOpt/libthermophysicalFunctions.so' is up to date.
    '/home/abao/foam/foam-extend-4.0/lib/linux64GccDPOpt/libliquids.so' is up to date.
    '/home/abao/foam/foam-extend-4.0/lib/linux64GccDPOpt/libliquidMixture.so' is up to date.
    '/home/abao/foam/foam-extend-4.0/lib/linux64GccDPOpt/libsolids.so' is up to date.
    '/home/abao/foam/foam-extend-4.0/lib/linux64GccDPOpt/libsolidMixture.so' is up to date.
    '/home/abao/foam/foam-extend-4.0/lib/linux64GccDPOpt/libbasicThermophysicalModels.so' is up to date.
    '/home/abao/foam/foam-extend-4.0/lib/linux64GccDPOpt/libreactionThermophysicalModels.so' is up to date.
    '/home/abao/foam/foam-extend-4.0/lib/linux64GccDPOpt/liblaminarFlameSpeedModels.so' is up to date.
    '/home/abao/foam/foam-extend-4.0/lib/linux64GccDPOpt/libchemistryModel.so' is up to date.
    '/home/abao/foam/foam-extend-4.0/lib/linux64GccDPOpt/libpdf.so' is up to date.
    '/home/abao/foam/foam-extend-4.0/lib/linux64GccDPOpt/libradiation.so' is up to date.
    '/home/abao/foam/foam-extend-4.0/lib/linux64GccDPOpt/libbarotropicCompressibilityModel.so' is up to date.
    '/home/abao/foam/foam-extend-4.0/lib/linux64GccDPOpt/libincompressibleTransportModels.so' is up to date.
    '/home/abao/foam/foam-extend-4.0/lib/linux64GccDPOpt/libinterfaceProperties.so' is up to date.
    '/home/abao/foam/foam-extend-4.0/lib/linux64GccDPOpt/libviscoelasticTransportModels.so' is up to date.
    '/home/abao/foam/foam-extend-4.0/lib/linux64GccDPOpt/libLESfilters.so' is up to date.
    '/home/abao/foam/foam-extend-4.0/lib/linux64GccDPOpt/libLESdeltas.so' is up to date.
    '/home/abao/foam/foam-extend-4.0/lib/linux64GccDPOpt/libincompressibleTurbulenceModel.so' is up to date.
    '/home/abao/foam/foam-extend-4.0/lib/linux64GccDPOpt/libincompressibleRASModels.so' is up to date.
    '/home/abao/foam/foam-extend-4.0/lib/linux64GccDPOpt/libincompressibleLESModels.so' is up to date.
    '/home/abao/foam/foam-extend-4.0/lib/linux64GccDPOpt/libcompressibleTurbulenceModel.so' is up to date.
    '/home/abao/foam/foam-extend-4.0/lib/linux64GccDPOpt/libcompressibleRASModels.so' is up to date.
    '/home/abao/foam/foam-extend-4.0/lib/linux64GccDPOpt/libcompressibleLESModels.so' is up to date.
    '/home/abao/foam/foam-extend-4.0/lib/linux64GccDPOpt/libsolidParticle.so' is up to date.
    '/home/abao/foam/foam-extend-4.0/lib/linux64GccDPOpt/liblagrangianIntermediate.so' is up to date.
    '/home/abao/foam/foam-extend-4.0/lib/linux64GccDPOpt/libdieselSpray.so' is up to date.
    '/home/abao/foam/foam-extend-4.0/lib/linux64GccDPOpt/libdsmc.so' is up to date.
    '/home/abao/foam/foam-extend-4.0/lib/linux64GccDPOpt/libcoalCombustion.so' is up to date.
    '/home/abao/foam/foam-extend-4.0/lib/linux64GccDPOpt/libpotential.so' is up to date.
    '/home/abao/foam/foam-extend-4.0/lib/linux64GccDPOpt/libmolecularMeasurements.so' is up to date.
    '/home/abao/foam/foam-extend-4.0/lib/linux64GccDPOpt/libmolecule.so' is up to date.
    '/home/abao/foam/foam-extend-4.0/lib/linux64GccDPOpt/libconjugateHeatTransfer.so' is up to date.
    '/home/abao/foam/foam-extend-4.0/lib/linux64GccDPOpt/postCalc.o' is up to date.
    '/home/abao/foam/foam-extend-4.0/lib/linux64GccDPOpt/libfoamCalcFunctions.so' is up to date.
    '/home/abao/foam/foam-extend-4.0/lib/linux64GccDPOpt/libcheckFunctionObjects.so' is up to date.
    '/home/abao/foam/foam-extend-4.0/lib/linux64GccDPOpt/libfieldFunctionObjects.so' is up to date.
    '/home/abao/foam/foam-extend-4.0/lib/linux64GccDPOpt/libforces.so' is up to date.
    '/home/abao/foam/foam-extend-4.0/lib/linux64GccDPOpt/libIOFunctionObjects.so' is up to date.
    '/home/abao/foam/foam-extend-4.0/lib/linux64GccDPOpt/libutilityFunctionObjects.so' is up to date.
    '/home/abao/foam/foam-extend-4.0/lib/linux64GccDPOpt/libsystemCall.so' is up to date.
    '/home/abao/foam/foam-extend-4.0/lib/linux64GccDPOpt/libconversion.so' is up to date.
    '/home/abao/foam/foam-extend-4.0/lib/linux64GccDPOpt/liberrorEstimation.so' is up to date.
    '/home/abao/foam/foam-extend-4.0/lib/linux64GccDPOpt/libMGridGenGAMGAgglomeration.so' is up to date.
    '/home/abao/foam/foam-extend-4.0/lib/linux64GccDPOpt/libengine.so' is up to date.
    '/home/abao/foam/foam-extend-4.0/lib/linux64GccDPOpt/libequationReader.so' is up to date.
    '/home/abao/foam/foam-extend-4.0/lib/linux64GccDPOpt/libmultiSolver.so' is up to date.
    '/home/abao/foam/foam-extend-4.0/lib/linux64GccDPOpt/libsolidModels.so' is up to date.
    '/home/abao/foam/foam-extend-4.0/lib/linux64GccDPOpt/libdbns.so' is up to date.
    '/home/abao/foam/foam-extend-4.0/lib/linux64GccDPOpt/libimmersedBoundary.so' is up to date.
    '/home/abao/foam/foam-extend-4.0/lib/linux64GccDPOpt/libimmersedBoundaryTurbulence.so' is up to date.
    '/home/abao/foam/foam-extend-4.0/lib/linux64GccDPOpt/libimmersedBoundaryForceFunctionObject.so' is up to date.
    '/home/abao/foam/foam-extend-4.0/lib/linux64GccDPOpt/libimmersedBoundaryDynamicFvMesh.so' is up to date.
    No nvcc - CUDA not available.
    make[2]: '/home/abao/foam/foam-extend-4.0/applications/bin/linux64GccDPOpt/dbnsFoam' is up to date.
    make[2]: '/home/abao/foam/foam-extend-4.0/applications/bin/linux64GccDPOpt/PODSolver' is up to date.
    make[2]: '/home/abao/foam/foam-extend-4.0/applications/bin/linux64GccDPOpt/dnsFoam' is up to date.
    make[3]: '/home/abao/foam/foam-extend-4.0/applications/bin/linux64GccDPOpt/dsmcFoam' is up to date.
    make[2]: '/home/abao/foam/foam-extend-4.0/applications/bin/linux64GccDPOpt/MRFPorousFoam' is up to date.
    make[2]: '/home/abao/foam/foam-extend-4.0/applications/bin/linux64GccDPOpt/electrostaticFoam' is up to date.
    make[2]: '/home/abao/foam/foam-extend-4.0/applications/bin/linux64GccDPOpt/dbnsTurbFoam' is up to date.
    make[2]: '/home/abao/foam/foam-extend-4.0/applications/bin/linux64GccDPOpt/XiFoam' is up to date.
    make[2]: '/home/abao/foam/foam-extend-4.0/applications/bin/linux64GccDPOpt/mhdFoam' is up to date.
    make[2]: '/home/abao/foam/foam-extend-4.0/applications/bin/linux64GccDPOpt/laplacianFoam' is up to date.
    make[2]: '/home/abao/foam/foam-extend-4.0/applications/bin/linux64GccDPOpt/PDRFoam' is up to date.
    make[3]: '/home/abao/foam/foam-extend-4.0/applications/bin/linux64GccDPOpt/mdEquilibrationFoam' is up to date.
    make[2]: '/home/abao/foam/foam-extend-4.0/applications/bin/linux64GccDPOpt/realFluidPisoFoam' is up to date.
    make[2]: '/home/abao/foam/foam-extend-4.0/applications/bin/linux64GccDPOpt/blockCoupledScalarTransportFoam' is up to date.
    make[2]: '/home/abao/foam/foam-extend-4.0/applications/bin/linux64GccDPOpt/conjugateHeatFoam' is up to date.
    make[2]: '/home/abao/foam/foam-extend-4.0/applications/bin/linux64GccDPOpt/potentialDyMFoam' is up to date.
    make[2]: '/home/abao/foam/foam-extend-4.0/applications/bin/linux64GccDPOpt/sonicTurbDyMEngineFoam' is up to date.
    make[3]: '/home/abao/foam/foam-extend-4.0/applications/bin/linux64GccDPOpt/mdFoam' is up to date.
    make[2]: '/home/abao/foam/foam-extend-4.0/applications/bin/linux64GccDPOpt/coldEngineFoam' is up to date.
    make[2]: '/home/abao/foam/foam-extend-4.0/applications/bin/linux64GccDPOpt/rhoPimpleFoam' is up to date.
    '/home/abao/foam/foam-extend-4.0/lib/linux64GccDPOpt/librhoCentralFoam.so' is up to date.
    make[2]: '/home/abao/foam/foam-extend-4.0/applications/bin/linux64GccDPOpt/sixDOFSolver' is up to date.
    make[2]: '/home/abao/foam/foam-extend-4.0/applications/bin/linux64GccDPOpt/potentialFoam' is up to date.
    make[2]: '/home/abao/foam/foam-extend-4.0/applications/bin/linux64GccDPOpt/conjugateHeatSimpleFoam' is up to date.
    make[2]: '/home/abao/foam/foam-extend-4.0/applications/bin/linux64GccDPOpt/scalarTransportFoam' is up to date.
    make[2]: '/home/abao/foam/foam-extend-4.0/applications/bin/linux64GccDPOpt/rhoCentralFoam' is up to date.
    make[2]: '/home/abao/foam/foam-extend-4.0/applications/bin/linux64GccDPOpt/icoDyMEngineFoam' is up to date.
    make[2]: '/home/abao/foam/foam-extend-4.0/applications/bin/linux64GccDPOpt/dieselEngineFoam' is up to date.
    make[2]: '/home/abao/foam/foam-extend-4.0/applications/bin/linux64GccDPOpt/turbDyMEngineFoam' is up to date.
    make[2]: '/home/abao/foam/foam-extend-4.0/applications/bin/linux64GccDPOpt/pUCoupledFoam' is up to date.
    make[2]: '/home/abao/foam/foam-extend-4.0/applications/bin/linux64GccDPOpt/rhoPisoFoam' is up to date.
    make[2]: '/home/abao/foam/foam-extend-4.0/applications/bin/linux64GccDPOpt/financialFoam' is up to date.
    make[1]: '/home/abao/foam/foam-extend-4.0/applications/bin/linux64GccDPOpt/equationReaderDemo' is up to date.
    make[2]: '/home/abao/foam/foam-extend-4.0/applications/bin/linux64GccDPOpt/rhoPorousMRFPimpleFoam' is up to date.
    make[2]: '/home/abao/foam/foam-extend-4.0/applications/bin/linux64GccDPOpt/engineFoam' is up to date.
    make[2]: '/home/abao/foam/foam-extend-4.0/applications/bin/linux64GccDPOpt/dieselFoam' is up to date.
    '/home/abao/foam/foam-extend-4.0/lib/linux64GccDPOpt/libcombustionModels.so' is up to date.
    make[2]: '/home/abao/foam/foam-extend-4.0/applications/bin/linux64GccDPOpt/rhoPorousSimpleFoam' is up to date.
    make[2]: '/home/abao/foam/foam-extend-4.0/applications/bin/linux64GccDPOpt/rhoReactingFoam' is up to date.
    make[2]: '/home/abao/foam/foam-extend-4.0/applications/bin/linux64GccDPOpt/rhoSimpleFoam' is up to date.
    make[2]: '/home/abao/foam/foam-extend-4.0/applications/bin/linux64GccDPOpt/rhoSonicFoam' is up to date.
    make[2]: '/home/abao/foam/foam-extend-4.0/applications/bin/linux64GccDPOpt/reactingFoam' is up to date.
    '/home/abao/foam/foam-extend-4.0/lib/linux64GccDPOpt/librhopSonicFoam.so' is up to date.
    make[2]: '/home/abao/foam/foam-extend-4.0/applications/bin/linux64GccDPOpt/sonicDyMFoam' is up to date.
    make[2]: '/home/abao/foam/foam-extend-4.0/applications/bin/linux64GccDPOpt/fireFoam' is up to date.
    make[2]: '/home/abao/foam/foam-extend-4.0/applications/bin/linux64GccDPOpt/sonicFoam' is up to date.
    make[2]: '/home/abao/foam/foam-extend-4.0/applications/bin/linux64GccDPOpt/liquidFilmFoam' is up to date.
    make[2]: '/home/abao/foam/foam-extend-4.0/applications/bin/linux64GccDPOpt/boussinesqBuoyantFoam' is up to date.
    make[2]: '/home/abao/foam/foam-extend-4.0/applications/bin/linux64GccDPOpt/surfactantFoam' is up to date.
    make[2]: '/home/abao/foam/foam-extend-4.0/applications/bin/linux64GccDPOpt/sonicLiquidFoam' is up to date.
    make[2]: '/home/abao/foam/foam-extend-4.0/applications/bin/linux64GccDPOpt/rhopSonicFoam' is up to date.
    make[2]: '/home/abao/foam/foam-extend-4.0/applications/bin/linux64GccDPOpt/icoDyMIbFoam' is up to date.
    make[2]: '/home/abao/foam/foam-extend-4.0/applications/bin/linux64GccDPOpt/MRFSimpleFoam' is up to date.
    make[2]: '/home/abao/foam/foam-extend-4.0/applications/bin/linux64GccDPOpt/steadyCompressibleFoam' is up to date.
    make[2]: '/home/abao/foam/foam-extend-4.0/applications/bin/linux64GccDPOpt/icoIbFoam' is up to date.
    make[2]: '/home/abao/foam/foam-extend-4.0/applications/bin/linux64GccDPOpt/steadyCompressibleMRFFoam' is up to date.
    make[2]: '/home/abao/foam/foam-extend-4.0/applications/bin/linux64GccDPOpt/buoyantBoussinesqPisoFoam' is up to date.
    make[2]: '/home/abao/foam/foam-extend-4.0/applications/bin/linux64GccDPOpt/steadyUniversalFoam' is up to date.
    make[2]: '/home/abao/foam/foam-extend-4.0/applications/bin/linux64GccDPOpt/steadyCompressibleSRFFoam' is up to date.
    make[2]: '/home/abao/foam/foam-extend-4.0/applications/bin/linux64GccDPOpt/boundaryFoam' is up to date.
    make[2]: '/home/abao/foam/foam-extend-4.0/applications/bin/linux64GccDPOpt/buoyantBoussinesqSimpleFoam' is up to date.
    make[2]: '/home/abao/foam/foam-extend-4.0/applications/bin/linux64GccDPOpt/steadyUniversalMRFFoam' is up to date.
    make[2]: '/home/abao/foam/foam-extend-4.0/applications/bin/linux64GccDPOpt/multiSolverDemo' is up to date.
    make[2]: '/home/abao/foam/foam-extend-4.0/applications/bin/linux64GccDPOpt/interIbFoam' is up to date.
    make[2]: '/home/abao/foam/foam-extend-4.0/applications/bin/linux64GccDPOpt/potentialIbFoam' is up to date.
    make[2]: '/home/abao/foam/foam-extend-4.0/applications/bin/linux64GccDPOpt/porousSimpleIbFoam' is up to date.
    make[2]: '/home/abao/foam/foam-extend-4.0/applications/bin/linux64GccDPOpt/coalChemistryFoam' is up to date.
    make[2]: '/home/abao/foam/foam-extend-4.0/applications/bin/linux64GccDPOpt/channelFoam' is up to date.
    make[2]: '/home/abao/foam/foam-extend-4.0/applications/bin/linux64GccDPOpt/buoyantPisoFoam' is up to date.
    make[2]: '/home/abao/foam/foam-extend-4.0/applications/bin/linux64GccDPOpt/buoyantSimpleRadiationFoam' is up to date.
    make[2]: '/home/abao/foam/foam-extend-4.0/applications/bin/linux64GccDPOpt/buoyantSimpleFoam' is up to date.
    make[2]: '/home/abao/foam/foam-extend-4.0/applications/bin/linux64GccDPOpt/icoDyMFoam' is up to date.
    make[2]: '/home/abao/foam/foam-extend-4.0/applications/bin/linux64GccDPOpt/simpleIbFoam' is up to date.
    make[2]: '/home/abao/foam/foam-extend-4.0/applications/bin/linux64GccDPOpt/chtMultiRegionFoam' is up to date.
    make[2]: '/home/abao/foam/foam-extend-4.0/applications/bin/linux64GccDPOpt/icoDyMSimpleFoam' is up to date.
    make[2]: '/home/abao/foam/foam-extend-4.0/applications/bin/linux64GccDPOpt/porousExplicitSourceReactingParcelFoam' is up to date.
    make[2]: '/home/abao/foam/foam-extend-4.0/applications/bin/linux64GccDPOpt/MRFInterFoam' is up to date.
    make[2]: '/home/abao/foam/foam-extend-4.0/applications/bin/linux64GccDPOpt/icoFoam' is up to date.
    make[2]: '/home/abao/foam/foam-extend-4.0/applications/bin/linux64GccDPOpt/nonNewtonianIcoFoam' is up to date.
    make[2]: '/home/abao/foam/foam-extend-4.0/applications/bin/linux64GccDPOpt/pimpleFoam' is up to date.
    make[2]: '/home/abao/foam/foam-extend-4.0/applications/bin/linux64GccDPOpt/pimpleDyMFoam' is up to date.
    make[2]: '/home/abao/foam/foam-extend-4.0/applications/bin/linux64GccDPOpt/barotropicCavitatingFoam' is up to date.
    make[1]: '/home/abao/foam/foam-extend-4.0/applications/bin/linux64GccDPOpt/elasticAcpSolidFoam' is up to date.
    make[2]: '/home/abao/foam/foam-extend-4.0/applications/bin/linux64GccDPOpt/reactingParcelFoam' is up to date.
    make[2]: '/home/abao/foam/foam-extend-4.0/applications/bin/linux64GccDPOpt/chtMultiRegionSimpleFoam' is up to date.
    make[2]: '/home/abao/foam/foam-extend-4.0/applications/bin/linux64GccDPOpt/porousSimpleFoam' is up to date.
    make[2]: '/home/abao/foam/foam-extend-4.0/applications/bin/linux64GccDPOpt/pisoFoam' is up to date.
    make[2]: '/home/abao/foam/foam-extend-4.0/applications/bin/linux64GccDPOpt/viscoelasticFluidFoam' is up to date.
    make[2]: '/home/abao/foam/foam-extend-4.0/applications/bin/linux64GccDPOpt/cavitatingFoam' is up to date.
    make[2]: '/home/abao/foam/foam-extend-4.0/applications/bin/linux64GccDPOpt/bubbleFoam' is up to date.
    make[2]: '/home/abao/foam/foam-extend-4.0/applications/bin/linux64GccDPOpt/shallowWaterFoam' is up to date.
    make[1]: '/home/abao/foam/foam-extend-4.0/applications/bin/linux64GccDPOpt/elasticIncrAcpSolidFoam' is up to date.
    make[2]: '/home/abao/foam/foam-extend-4.0/applications/bin/linux64GccDPOpt/uncoupledKinematicParcelFoam' is up to date.
    make[2]: '/home/abao/foam/foam-extend-4.0/applications/bin/linux64GccDPOpt/simpleSRFFoam' is up to date.
    '/home/abao/foam/foam-extend-4.0/lib/linux64GccDPOpt/libfreeSurface.so' is up to date.
    make[2]: '/home/abao/foam/foam-extend-4.0/applications/bin/linux64GccDPOpt/simpleFoam' is up to date.
    make[2]: '/home/abao/foam/foam-extend-4.0/applications/bin/linux64GccDPOpt/compressibleInterFoam' is up to date.
    make[2]: '/home/abao/foam/foam-extend-4.0/applications/bin/linux64GccDPOpt/interFoam' is up to date.
    make[2]: '/home/abao/foam/foam-extend-4.0/applications/bin/linux64GccDPOpt/compressibleInterDyMFoam' is up to date.
    make[2]: '/home/abao/foam/foam-extend-4.0/applications/bin/linux64GccDPOpt/interDyMFoam' is up to date.
    make[2]: '/home/abao/foam/foam-extend-4.0/applications/bin/linux64GccDPOpt/interMixingFoam' is up to date.
    make[1]: '/home/abao/foam/foam-extend-4.0/applications/bin/linux64GccDPOpt/elasticIncrSolidFoam' is up to date.
    make[2]: '/home/abao/foam/foam-extend-4.0/applications/bin/linux64GccDPOpt/porousInterFoam' is up to date.
    make[2]: '/home/abao/foam/foam-extend-4.0/applications/bin/linux64GccDPOpt/interPhaseChangeFoam' is up to date.
    '/home/abao/foam/foam-extend-4.0/lib/linux64GccDPOpt/libphaseModel.so' is up to date.
    make[2]: '/home/abao/foam/foam-extend-4.0/applications/bin/linux64GccDPOpt/settlingFoam' is up to date.
    make[2]: '/home/abao/foam/foam-extend-4.0/applications/bin/linux64GccDPOpt/twoLiquidMixingFoam' is up to date.
    make[1]: '/home/abao/foam/foam-extend-4.0/applications/bin/linux64GccDPOpt/interTrackFoam' is up to date.
    make[1]: '/home/abao/foam/foam-extend-4.0/applications/bin/linux64GccDPOpt/elasticNonLinIncrTLSolidFoam' is up to date.
    '/home/abao/foam/foam-extend-4.0/lib/linux64GccDPOpt/libEulerianInterfacialModels.so' is up to date.
    make[2]: '/home/abao/foam/foam-extend-4.0/applications/bin/linux64GccDPOpt/multiphaseInterFoam' is up to date.
    make[1]: '/home/abao/foam/foam-extend-4.0/applications/bin/linux64GccDPOpt/bubbleInterTrackFoam' is up to date.
    make[1]: '/home/abao/foam/foam-extend-4.0/applications/bin/linux64GccDPOpt/elasticNonLinTLSolidFoam' is up to date.
    '/home/abao/foam/foam-extend-4.0/lib/linux64GccDPOpt/libkineticTheoryModel.so' is up to date.
    make[1]: '/home/abao/foam/foam-extend-4.0/applications/bin/linux64GccDPOpt/elasticNonLinULSolidFoam' is up to date.
    make[1]: '/home/abao/foam/foam-extend-4.0/applications/bin/linux64GccDPOpt/elasticOrthoAcpSolidFoam' is up to date.
    make[2]: '/home/abao/foam/foam-extend-4.0/applications/bin/linux64GccDPOpt/twoPhaseEulerFoam' is up to date.
    make[1]: '/home/abao/foam/foam-extend-4.0/applications/bin/linux64GccDPOpt/elasticOrthoNonLinULSolidFoam' is up to date.
    make[1]: '/home/abao/foam/foam-extend-4.0/applications/bin/linux64GccDPOpt/elasticOrthoSolidFoam' is up to date.
    make[1]: '/home/abao/foam/foam-extend-4.0/applications/bin/linux64GccDPOpt/elasticPlasticSolidFoam' is up to date.
    make[1]: '/home/abao/foam/foam-extend-4.0/applications/bin/linux64GccDPOpt/elasticPlasticNonLinTLSolidFoam' is up to date.
    make[1]: '/home/abao/foam/foam-extend-4.0/applications/bin/linux64GccDPOpt/elasticPlasticNonLinULSolidFoam' is up to date.
    make[1]: '/home/abao/foam/foam-extend-4.0/applications/bin/linux64GccDPOpt/elasticSolidFoam' is up to date.
    make[1]: '/home/abao/foam/foam-extend-4.0/applications/bin/linux64GccDPOpt/elasticThermalSolidFoam' is up to date.
    make[1]: '/home/abao/foam/foam-extend-4.0/applications/bin/linux64GccDPOpt/icoFsiElasticNonLinULSolidFoam' is up to date.
    make[1]: '/home/abao/foam/foam-extend-4.0/applications/bin/linux64GccDPOpt/viscoElasticSolidFoam' is up to date.
    make[1]: '/home/abao/foam/foam-extend-4.0/applications/bin/linux64GccDPOpt/stressFemFoam' is up to date.
    make[2]: '/home/abao/foam/foam-extend-4.0/applications/bin/linux64GccDPOpt/smoothMesh' is up to date.
    make[2]: '/home/abao/foam/foam-extend-4.0/applications/bin/linux64GccDPOpt/patchStressIntegrate' is up to date.
    make[2]: '/home/abao/foam/foam-extend-4.0/applications/bin/linux64GccDPOpt/forceDisp' is up to date.
    make[2]: '/home/abao/foam/foam-extend-4.0/applications/bin/linux64GccDPOpt/calculateCourantNumber' is up to date.
    make[2]: '/home/abao/foam/foam-extend-4.0/applications/bin/linux64GccDPOpt/surfaceTractions' is up to date.
    '/home/abao/foam/foam-extend-4.0/lib/linux64GccDPOpt/libmaterialModels.so' is up to date.
    make[1]: '/home/abao/foam/foam-extend-4.0/applications/bin/linux64GccDPOpt/stressedFoam' is up to date.
    make[1]: '/home/abao/foam/foam-extend-4.0/applications/bin/linux64GccDPOpt/contactStressFoam' is up to date.
    make[1]: '/home/abao/foam/foam-extend-4.0/applications/bin/linux64GccDPOpt/newStressedFoam' is up to date.
    make[1]: '/home/abao/foam/foam-extend-4.0/applications/bin/linux64GccDPOpt/newContactStressFoam' is up to date.
    make[1]: '/home/abao/foam/foam-extend-4.0/applications/bin/linux64GccDPOpt/icoFsiFoam' is up to date.
    make[1]: '/home/abao/foam/foam-extend-4.0/applications/bin/linux64GccDPOpt/solidDisplacementFoam' is up to date.
    make[1]: '/home/abao/foam/foam-extend-4.0/applications/bin/linux64GccDPOpt/solidEquilibriumDisplacementFoam' is up to date.
    make[3]: '/home/abao/foam/foam-extend-4.0/applications/bin/linux64GccDPOpt/autoRefineMesh' is up to date.
    make[2]: '/home/abao/foam/foam-extend-4.0/applications/bin/linux64GccDPOpt/checkFaMesh' is up to date.
    make[2]: '/home/abao/foam/foam-extend-4.0/applications/bin/linux64GccDPOpt/ibContinuityError' is up to date.
    make[2]: '/home/abao/foam/foam-extend-4.0/applications/bin/linux64GccDPOpt/estimateScalarError' is up to date.
    make[3]: '/home/abao/foam/foam-extend-4.0/applications/bin/linux64GccDPOpt/scalarSnapshots' is up to date.
    make[3]: '/home/abao/foam/foam-extend-4.0/applications/bin/linux64GccDPOpt/testFad' is up to date.
    make[2]: '/home/abao/foam/foam-extend-4.0/applications/bin/linux64GccDPOpt/applyBoundaryLayer' is up to date.
    make[3]: '/home/abao/foam/foam-extend-4.0/applications/bin/linux64GccDPOpt/collapseEdges' is up to date.
    make[2]: '/home/abao/foam/foam-extend-4.0/applications/bin/linux64GccDPOpt/decomposePar' is up to date.
    make[2]: '/home/abao/foam/foam-extend-4.0/applications/bin/linux64GccDPOpt/applyWallFunctionBoundaryConditions' is up to date.
    make[3]: '/home/abao/foam/foam-extend-4.0/applications/bin/linux64GccDPOpt/testFadField' is up to date.
    make[2]: '/home/abao/foam/foam-extend-4.0/applications/bin/linux64GccDPOpt/createFaMeshFromStl' is up to date.
    make[2]: '/home/abao/foam/foam-extend-4.0/applications/bin/linux64GccDPOpt/icoErrorEstimate' is up to date.
    make[2]: '/home/abao/foam/foam-extend-4.0/applications/bin/linux64GccDPOpt/makeTriSurfaceMesh' is up to date.
    make[2]: '/home/abao/foam/foam-extend-4.0/applications/bin/linux64GccDPOpt/boxTurb' is up to date.
    make[2]: '/home/abao/foam/foam-extend-4.0/applications/bin/linux64GccDPOpt/expandDictionary' is up to date.
    make[3]: '/home/abao/foam/foam-extend-4.0/applications/bin/linux64GccDPOpt/vectorSnapshots' is up to date.
    make[3]: '/home/abao/foam/foam-extend-4.0/applications/bin/linux64GccDPOpt/combinePatchFaces' is up to date.
    make[2]: '/home/abao/foam/foam-extend-4.0/applications/bin/linux64GccDPOpt/decomposeSets' is up to date.
    make[2]: '/home/abao/foam/foam-extend-4.0/applications/bin/linux64GccDPOpt/makeFaMesh' is up to date.
    make[2]: '/home/abao/foam/foam-extend-4.0/applications/bin/linux64GccDPOpt/findRoot' is up to date.
    make[2]: '/home/abao/foam/foam-extend-4.0/applications/bin/linux64GccDPOpt/changeDictionary' is up to date.
    make[2]: '/home/abao/foam/foam-extend-4.0/applications/bin/linux64GccDPOpt/refineImmersedBoundaryMesh' is up to date.
    make[2]: '/home/abao/foam/foam-extend-4.0/applications/bin/linux64GccDPOpt/icoMomentError' is up to date.
    make[3]: '/home/abao/foam/foam-extend-4.0/applications/bin/linux64GccDPOpt/modifyMesh' is up to date.
    make[3]: '/home/abao/foam/foam-extend-4.0/applications/bin/linux64GccDPOpt/foamDataToFluent' is up to date.
    make[2]: '/home/abao/foam/foam-extend-4.0/applications/bin/linux64GccDPOpt/surfaceInvertNormal' is up to date.
    make[2]: '/home/abao/foam/foam-extend-4.0/applications/bin/linux64GccDPOpt/foamFormatConvert' is up to date.
    make[2]: '/home/abao/foam/foam-extend-4.0/applications/bin/linux64GccDPOpt/momentScalarError' is up to date.
    make[2]: '/home/abao/foam/foam-extend-4.0/applications/bin/linux64GccDPOpt/convertPhi' is up to date.
    make[3]: '/home/abao/foam/foam-extend-4.0/applications/bin/linux64GccDPOpt/refineHexMesh' is up to date.
    make[2]: '/home/abao/foam/foam-extend-4.0/applications/bin/linux64GccDPOpt/surfaceNormal' is up to date.
    make[2]: '/home/abao/foam/foam-extend-4.0/applications/bin/linux64GccDPOpt/foamInfoExec' is up to date.
    make[2]: '/home/abao/foam/foam-extend-4.0/applications/bin/linux64GccDPOpt/reconstructParMesh' is up to date.
    make[2]: '/home/abao/foam/foam-extend-4.0/applications/bin/linux64GccDPOpt/reconstructPar' is up to date.
    make[2]: '/home/abao/foam/foam-extend-4.0/applications/bin/linux64GccDPOpt/simpleFoamResidual' is up to date.
    make[2]: '/home/abao/foam/foam-extend-4.0/applications/bin/linux64GccDPOpt/dsmcInitialise' is up to date.
    make[2]: '/home/abao/foam/foam-extend-4.0/applications/bin/linux64GccDPOpt/engineSwirl' is up to date.
    make[3]: '/home/abao/foam/foam-extend-4.0/applications/bin/linux64GccDPOpt/refineWallLayer' is up to date.
    make[3]: '/home/abao/foam/foam-extend-4.0/applications/bin/linux64GccDPOpt/foamToEnsight' is up to date.
    make[2]: '/home/abao/foam/foam-extend-4.0/applications/bin/linux64GccDPOpt/writeIbMasks' is up to date.
    make[2]: '/home/abao/foam/foam-extend-4.0/applications/bin/linux64GccDPOpt/patchSummary' is up to date.
    make[3]: '/home/abao/foam/foam-extend-4.0/applications/bin/linux64GccDPOpt/refinementLevel' is up to date.
    make[3]: '/home/abao/foam/foam-extend-4.0/applications/bin/linux64GccDPOpt/removeFaces' is up to date.
    make[2]: '/home/abao/foam/foam-extend-4.0/applications/bin/linux64GccDPOpt/redistributeMeshPar' is up to date.
    make[2]: '/home/abao/foam/foam-extend-4.0/applications/bin/linux64GccDPOpt/mapFields' is up to date.
    make[3]: '/home/abao/foam/foam-extend-4.0/applications/bin/linux64GccDPOpt/foamToEnsightParts' is up to date.
    make[2]: '/home/abao/foam/foam-extend-4.0/applications/bin/linux64GccDPOpt/fluentDataToFoam' is up to date.
    make[3]: '/home/abao/foam/foam-extend-4.0/applications/bin/linux64GccDPOpt/particleTracks' is up to date.
    make[3]: '/home/abao/foam/foam-extend-4.0/applications/bin/linux64GccDPOpt/foamToFieldview9' is up to date.
    .......... up to date
    字数有限制,没有全放上来
    H 1 条回复 最后回复
  • 洱聿洱 离线
    洱聿洱 离线
    洱聿
    在 中回复了 jlx 最后由 编辑
    你好,我想问一下,你成功编译interFluid了吗?有些问题想求助一下。
    卑以自牧,温润如玉。
    haozhibin
    在 中回复了 jlx 最后由 编辑
    @jlx 请问您在fe40中安装好wave2foam了没
