  4. 关于轴对称模型blockmesh中出现的错误
4 帖子 3 发布者 5.5k 浏览
  • F 离线
    F 离线
    freeman
    感觉应该是格式问题,但是又看不出。
    Generating mesh for region fluid
    Creating block mesh from
        "/home/dyfluid/OpenFOAM/dyfluid-v1812/run/scrivenWedge/D-4mm-70-nophase-end/system/fluid/blockMeshDict"
    --> FOAM Warning :
        Reading "/home/dyfluid/OpenFOAM/dyfluid-v1812/run/scrivenWedge/D-4mm-70-nophase-end/system/fluid/blockMeshDict" at line 63
        Too many closing ')' ... was a ';' forgotten?
    --> FOAM Warning :
        Reading "/home/dyfluid/OpenFOAM/dyfluid-v1812/run/scrivenWedge/D-4mm-70-nophase-end/system/fluid/blockMeshDict" at line 120
    --> FOAM Warning :
        Reading "/home/dyfluid/OpenFOAM/dyfluid-v1812/run/scrivenWedge/D-4mm-70-nophase-end/system/fluid/blockMeshDict" at line 123
        Imbalanced brackets
    --> FOAM FATAL IO ERROR:
    "ill defined primitiveEntry starting at keyword 'blocks' on line 48 and ending at line 123"
    file: /home/dyfluid/OpenFOAM/dyfluid-v1812/run/scrivenWedge/D-4mm-70-nophase-end/system/fluid/blockMeshDict at line 123.
        From function void Foam::primitiveEntry::readEntry(const Foam::dictionary&, Foam::Istream&)
        in file db/dictionary/primitiveEntry/primitiveEntryIO.C at line 238.
    FOAM exiting
    FoamFile
        version     2.0;
        format      ascii;
        class       dictionary;
        object      blockMeshDict;
    convertToMeters 0.001;
    //D0=3mm,W=1.5D0,H=10D0//
    vertices
        (0 0 0)
        (2 0.1 0)
        (0 0 20)
        (2 0.1 20)
        (6 0.3 20)
        (20 1 20)
        (0 0 40)
        (2 0.1 40)
        (6 0.3 40)
        (20 1 40)
        (0 0 60)
        (2 0.1 60)
        (6 0.3 60)
        (20 1 60)
        (2 -0.1 0)
        (2 -0.1 20)
        (6 -0.3 20)
        (20 -1 20)
        (2 -0.1 40)
        (6 -0.3 40)
        (20 -1 40)
        (2 -0.1 60)
        (6 -0.3 60)
        (20 -1 60)
    blocks
        hex  (0 14 1 0 2 15 3 2) (10 1 50)
        simpleGrading  (1 1 1)
        hex  (2 15 3 2 6 18 7 6) (10 1 50)
        hex  (6 18 7 6 10 21 11 10) (10 1 50)
        hex  (15 16 4 3 18 19 8 7) (20 1 50)
        hex  (18 19 8 7 21 22 12 11)) (20 1 50)
        hex  (16 17 5 4 19 20 9 8) (70 1 50)
        hex  (19 20 9 8 22 23 13 12) (70 1 50)
    patches
        wall faceWall
          (5 17 20 9)
          (9 20 23 13)
        wedge front
          (0 1 3 2)
          (2 3 7 6)
          (6 7 11 10)
          (3 4 8 7)
          (7 8 12 11)
          (4 5 9 8)
          (8 9 13 12)
        wedge back
          (0 14 15 2)
          (2 15 18 6)
          (6 18 21 10)
          (15 16 19 18)
          (18 19 22 21)
          (16 17 20 19)
          (19 20 23 22)
        slip sideWalls
          (1 14 15 3)
          (15 16 4 3)
          (16 17 5 4)
       patch outlet
          (10 21 11 10)
          (21 22 12 11)
          (22 23 13 12)
       patch inlet
          (0 14 1 0)
        empty axis
          (0 2 2 0)
          (2 6 6 2)
          (6 10 10 6)
    @freeman 在 关于轴对称模型blockmesh中出现的错误 中说:
    这多了一个后括号
    F 李东岳李 2 条回复 最后回复
  • F 离线
    F 离线
    freeman
    @bestucan 万分感谢您抽时间回答了这个简单的问题,我之前被报错提示误导了,后面找到了这个小问题!最后再次感谢您!
    @bestucan 厉害厉害!!!
