  4. 关于Ansys三维流体域网格导入openfoam的问题
2 帖子 2 发布者 4.0k 浏览
    Stan同学
    写于 最后由 Stan同学 编辑
    请教各位老师和同学们:
    一、由于计算的流体域形状比较复杂,所以尝试用Ansys划分流体域网格,在Ansys中对流体域进行分块,对复杂形状部分进行网格加密,并且在复杂部分采用四面体网格进行贴合。最终网格数量在八百万左右。通过转化后形成openfoam的网格,在checkMesh中出现网格报错信息。下面为checkMesh的输出信息。请教老师和同学们这种情况如何去调整网格,或者这种网格会影响计算的收敛性吗?
    Create time
    Create polyMesh for time = 0
    Time = 0
    Mesh stats
        internal points:  3796151
        faces:            21129446
        internal faces:   20649965
        cells:            8878252
        faces per cell:   4.70581
        boundary patches: 10
        point zones:      0
        face zones:       0
        cell zones:       0
        hexahedra:     2937143
        prisms:        28266
        wedges:        0
        pyramids:      363851
        tet wedges:    0
        tetrahedra:    5548992
        polyhedra:     0
    Checking topology...
        Boundary definition OK.
        Cell to face addressing OK.
        Point usage OK.
        Upper triangular ordering OK.
        Face vertices OK.
        Number of regions: 1 (OK).
    Checking patch topology for multiply connected surfaces...
        Patch               Faces    Points   Surface topology
        wall-__-2           102854   103255   ok (non-closed singly connected)
        wall-__-6           60678    61164    ok (non-closed singly connected)
        wall-__-3           12304    12645    ok (non-closed singly connected)
        wall-__-10          46213    46721    ok (non-closed singly connected)
        wall-__-7           23224    23830    ok (non-closed singly connected)
        wall-__-8           24985    25355    ok (non-closed singly connected)
        wall-__-4           10978    11907    ok (non-closed singly connected)
        wall-__-5           11537    12317    ok (non-closed singly connected)
        wall-__-__          38084    38454    ok (non-closed singly connected)
        wall-__-9           148624   74571    ok (non-closed singly connected)
    Checking geometry...
        Overall domain bounding box (-150 -5.7e-14 -5.82643e-12) (277.36 65.8 5.8)
        Mesh has 3 geometric (non-empty/wedge) directions (1 1 1)
        Mesh has 3 solution (non-empty) directions (1 1 1)
        Boundary openness (1.18923e-16 -6.74968e-16 -5.50711e-16) OK.
        Max cell openness = 1.04585e-15 OK.
        Max aspect ratio = 262.763 OK.
        Minimum face area = 2.10595e-05. Maximum face area = 3.10956.  Face area magnitudes OK.
        Min volume = 1.0868e-07. Max volume = 1.19771.  Total volume = 93583.6.  Cell volumes OK.
        Mesh non-orthogonality Max: 88.7853 average: 15.3095
       *Number of severely non-orthogonal (> 70 degrees) faces: 25145.
        Non-orthogonality check OK.
      <<Writing 25145 non-orthogonal faces to set nonOrthoFaces
        Face pyramids OK.
     ***Max skewness = 5.26267, 9 highly skew faces detected which may impair the quality of the results
      <<Writing 9 skew faces to set skewFaces
    Failed 1 mesh checks.
    End
    二、在Ansys对流体域划分网格的过程中,由于需要局部加密,将流体域分为若干块,但整体网格共点。将该网格导入openfoam并转化后,发现识别出来的每个面为当时分块时每个块的外表面,这种情况无法进行边界条件的设置。请教各位老师和同学,如何在Ansys中,对整体流体域的各个外表面进行标注,可以在导入openfoam后找到标注的面进行边界条件设置。
    yuky
    同问,我也出现了这个问题,不知道该不该去调整
