  4. blockMesh 执行出错:lambda=1
2 帖子 2 发布者 3.5k 浏览
  • 李子橙李 离线
    李子橙李 离线
    李子橙
    大家好,我在执行 blockMesh 时出现了如下错误
    Create time
    Creating block mesh from
        "system/blockMeshDict"
    Creating block edges
    No non-planar block faces defined
    Creating topology blocks
    --> FOAM FATAL ERROR:
    Parameter out of range, lambda = 1
        From function virtual Foam::point Foam::blockEdges::lineEdge::position(Foam::scalar) const
        in file blockEdges/lineEdge/lineEdge.C at line 79.
    FOAM aborting
    这个问题已经在我这儿搁置了半个月了,仍未有任何解决办法,下边是出错的 blockMeshDict 文件,针对此问题,请教一下各位老师是否有解决的思路。谢谢!
    FoamFile
        version    2.0;
        format    ascii;
        class       dictionary;
        object      blockMeshDict;
    convertToMeters 1;
    vertices
        (-134.58 -134.574 39.7629)
        (134.58 -134.574 39.7629)
        (134.58 134.574 39.7629)
        (-134.58 134.574 39.7629)
        (-134.58 -134.574 68.1807)
        (134.58 -134.574 68.1807)
        (134.58 134.574 68.1807)
        (-134.58 134.574 68.1807)
    blocks
        hex (0 1 2 3 4 5 6 7) model (527 293 55)
        simpleGrading
                (2.2 8 1.1)
                (2.5001 20 1)
                (4.3009 16 1)
                (2.0991 12 1)
                (1.4999 4 1)
                (4.2 23 1)
                (1.3 4 1)
                (0.7 6 1)
                (1.2 4 1)
                (4.3001 23 1)
                (1.2099 4 1)
                (0.69 7 1)
                (1.202 4 1)
                (4.298 23 1)
                (1.201 4 1)
                (0.799 7 1)
                (1 5 1)
                (4.5 24 1)
                (1.201 5 1)
                (0.649 6 1)
                (1.201 6 1)
                (4.299 23 1)
                (1.2001 5 1)
                (0.7999 7 1)
                (1.01 5 1)
                (4.59 25 1)
                (1.101 5 1)
                (0.649 8 1)
                (1.2001 5 1)
                (4.2999 23 1)
                (1.3 6 1)
                (0.6 8 1)
                (1.2001 5 1)
                (4.4999 25 1)
                (1.1 5 1)
                (0.71 7 1)
                (1.2001 5 1)
                (4.2899 23 1)
                (1.2 5 1)
                (0.71 6 1)
                (1.201 5 1)
                (4.389 24 1)
                (1.1001 5 1)
                (0.7999 7 1)
                (1.21 5 1.001)
                (4.49 25 1)
                (4.001 12 1)
                (2.499 20 1)
                (2.1 8 1)
                (2 10 1)
                (2.5 20 1)
                (1.201 5 1)
                (21.999 80 1)
                (36 60 1)
                (31.5 90 1)
                (2.6 20 1)
                (2.2 8 1)
                (21 11 1.1)
                (10 12 1)
                (18 12 1)
                (51 20 1)
    edges
    boundary
    defaultPatch
        name                                    default;
        type                                    patch;
    在 中回复了 李子橙 最后由 编辑
    @李子橙 simpleGrading都设置为1可以么
